RTEMS
6.1-rc4
testsuites
validation
tr-fatal-init-task-construct-failed.h File Reference
Test Suites
Validation Test Suites
spec:/testsuites/fatal-init-task-construct-failed
spec:/acfg/val/fatal-init-task-construct-failed
rtems.h
void
AcfgValFatalInitTaskConstructFailed_Run
rtems_fatal_source
source,
rtems_fatal_code
code
Runs the parameterized test case.
