RTEMS 6.1-rc4
system_sams70.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
30#ifndef SYSTEM_SAMS70_H_INCLUDED
31#define SYSTEM_SAMS70_H_INCLUDED
32#ifdef __rtems__
33#include <bsp/atsam-clock-config.h>
34#endif /* __rtems__ */
35
36/* @cond 0 */
38#ifdef __cplusplus
39extern "C" {
40#endif
42/* @endcond */
43
44#include <stdint.h>
45
46extern uint32_t SystemCoreClock; /* System Clock Frequency (Core Clock) */
47
52#ifndef __rtems__
53void SystemInit(void);
54#else /* __rtems__ */
55void ATSAM_START_SRAM_SECTION SystemInit(void);
56#endif /* __rtems__ */
57
62void SystemCoreClockUpdate(void);
63
67void system_init_flash(uint32_t dw_clk);
68
69/* @cond 0 */
71#ifdef __cplusplus
72}
73#endif
75/* @endcond */
76
77#endif /* SYSTEM_SAMS70_H_INCLUDED */
System clock frequency (core clock)
Definition: system_samv71.c:69
Setup the microcontroller system. Initialize the System and update the SystemCoreClock variable.
Definition: system_samv71.c:82
Updates the SystemCoreClock with current core Clock retrieved from cpu registers.
Definition: system_samv71.c:158
