RTEMS
6.1-rc4
libmisc
monitor
symbols.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
* COPYRIGHT (c) 1989-2022. On-Line Applications Research Corporation (OAR).
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef _INCLUDE_SYMBOLS_H
37
#define _INCLUDE_SYMBOLS_H
38
39
rtems/monitor.h
40
41
#ifdef __cplusplus
42
extern
"C"
43
#endif
44
45
struct
_rtems_symbol_t
46
uint32_t value;
47
char
*name;
48
49
50
#define SYMBOL_STRING_BLOCK_SIZE 4080
51
typedef
struct
rtems_symbol_string_block_s
52
struct
*next;
53
char
buffer[SYMBOL_STRING_BLOCK_SIZE];
54
rtems_symbol_string_block_t
55
56
struct
_rtems_symbol_table_t
57
58
uint32_t sorted;
/* are symbols sorted right now? */
59
uint32_t growth_factor;
/* % to grow by when needed */
60
uint32_t next;
/* next symbol slot to use when adding */
61
uint32_t size;
/* max # of symbols */
62
63
64
* Symbol list -- sorted by address (when we do a lookup)
65
66
67
rtems_symbol_t
*addresses;
/* symbol array by address */
68
69
70
* String pool, unsorted, a list of blocks of string data
71
72
73
*string_buffer_head;
74
*string_buffer_current;
75
uint32_t strings_next;
/* next byte to use in this block */
76
77
78
79
#define rtems_symbol_name(sp) ((sp)->name)
80
#define rtems_symbol_value(sp) ((sp)->value)
81
82
#ifdef __cplusplus
83
84
#endif
85
86
#endif
/* ! _INCLUDE_SYMBOLS_H */
monitor.h
The RTEMS Monitor Task.
_rtems_symbol_t
Definition:
symbols.h:45
Definition:
symbols.h:56
Definition:
symbols.h:51
