RTEMS 6.1-rc4
rtems_debugger_target Struct Reference
#include <rtems-debugger-target.h>
int capabilities
size_t reg_num
const size_t * reg_offset
const uint8_t * breakpoint
size_t breakpoint_size
rtems_debugger_block swbreaks
rtems_debugger_target_code_writer code_writer
bool memory_access
jmp_buf access_return
uintptr_t step_bp_address
rtems_id step_tid
The target data.
reg_offset: Table of size_t offset of a register in the register table. The table has one more entry than reg_num where the last entry is the size of the register table.
