RTEMS 6.1-rc4
Public Member Functions | |
SPIN_DECLARE (devlock) | |
Data Fields | |
struct drvmgr_dev * | dev |
char | prefix [20] |
pci_dev_t | pcidev |
struct pci_dev_info * | devinfo |
uint32_t | ahbmst2pci_map |
int | eirq |
genirq_t | genirq |
unsigned int | amba_freq_hz |
unsigned int | cg_en_mask |
struct irqmp_regs * | irq |
struct l4n2x_grcg_regs * | cg |
struct grpci2_regs * | grpci2 |
struct drvmgr_map_entry | bus_maps_up [2] |
struct drvmgr_map_entry | bus_maps_down [4] |
struct ambapp_bus | abus |
struct ambapp_mmap | amba_maps [5] |
struct ambapp_config | config |
