RTEMS 6.1-rc4
ALT_I2C_s Struct Reference
volatile ALT_I2C_CON_t ic_con
volatile ALT_I2C_TAR_t ic_tar
volatile ALT_I2C_SAR_t ic_sar
volatile uint32_t _pad_0xc_0xf
volatile ALT_I2C_DATA_CMD_t ic_data_cmd
volatile ALT_I2C_SS_SCL_HCNT_t ic_ss_scl_hcnt
volatile ALT_I2C_SS_SCL_LCNT_t ic_ss_scl_lcnt
volatile ALT_I2C_FS_SCL_HCNT_t ic_fs_scl_hcnt
volatile ALT_I2C_FS_SCL_LCNT_t ic_fs_scl_lcnt
volatile uint32_t _pad_0x24_0x2b [2]
volatile ALT_I2C_INTR_STAT_t ic_intr_stat
volatile ALT_I2C_INTR_MSK_t ic_intr_mask
volatile ALT_I2C_RAW_INTR_STAT_t ic_raw_intr_stat
volatile ALT_I2C_RX_TL_t ic_rx_tl
volatile ALT_I2C_TX_TL_t ic_tx_tl
volatile ALT_I2C_CLR_INTR_t ic_clr_intr
volatile ALT_I2C_CLR_RX_UNDER_t ic_clr_rx_under
volatile ALT_I2C_CLR_RX_OVER_t ic_clr_rx_over
volatile ALT_I2C_CLR_TX_OVER_t ic_clr_tx_over
volatile ALT_I2C_CLR_RD_REQ_t ic_clr_rd_req
volatile ALT_I2C_CLR_TX_ABRT_t ic_clr_tx_abrt
volatile ALT_I2C_CLR_RX_DONE_t ic_clr_rx_done
volatile ALT_I2C_CLR_ACTIVITY_t ic_clr_activity
volatile ALT_I2C_CLR_STOP_DET_t ic_clr_stop_det
volatile ALT_I2C_CLR_START_DET_t ic_clr_start_det
volatile ALT_I2C_CLR_GEN_CALL_t ic_clr_gen_call
volatile ALT_I2C_EN_t ic_enable
volatile ALT_I2C_STAT_t ic_status
volatile ALT_I2C_TXFLR_t ic_txflr
volatile ALT_I2C_RXFLR_t ic_rxflr
volatile ALT_I2C_SDA_HOLD_t ic_sda_hold
volatile ALT_I2C_TX_ABRT_SRC_t ic_tx_abrt_source
volatile ALT_I2C_SLV_DATA_NACK_ONLY_t ic_slv_data_nack_only
volatile ALT_I2C_DMA_CR_t ic_dma_cr
volatile ALT_I2C_DMA_TDLR_t ic_dma_tdlr
volatile ALT_I2C_DMA_RDLR_t ic_dma_rdlr
volatile ALT_I2C_SDA_SETUP_t ic_sda_setup
volatile ALT_I2C_ACK_GENERAL_CALL_t ic_ack_general_call
volatile ALT_I2C_EN_STAT_t ic_enable_status
volatile ALT_I2C_FS_SPKLEN_t ic_fs_spklen
volatile uint32_t _pad_0xa4_0xf3 [20]
volatile ALT_I2C_COMP_PARAM_1_t ic_comp_param_1
volatile ALT_I2C_COMP_VER_t ic_comp_version
volatile ALT_I2C_COMP_TYPE_t ic_comp_type
