RTEMS 6.1-rc4
UTILS LL module driver. More...
#define | assert_param(expr) ((void)0U) |
#define | UTILS_PLLVCO_INPUT_MIN1 1000000U |
#define | UTILS_PLLVCO_INPUT_MAX1 2000000U |
#define | UTILS_PLLVCO_INPUT_MIN2 2000000U |
#define | UTILS_PLLVCO_INPUT_MAX2 4000000U |
#define | UTILS_PLLVCO_INPUT_MIN3 4000000U |
#define | UTILS_PLLVCO_INPUT_MAX3 8000000U |
#define | UTILS_PLLVCO_INPUT_MIN4 8000000U |
#define | UTILS_PLLVCO_INPUT_MAX4 16000000U |
#define | UTILS_PLLVCO_MEDIUM_OUTPUT_MIN 150000000U |
#define | UTILS_PLLVCO_WIDE_OUTPUT_MIN 128000000U |
#define | UTILS_PLLVCO_MEDIUM_OUTPUT_MAX 420000000U |
#define | UTILS_PLLVCO_WIDE_OUTPUT_MAX 560000000U |
#define | UTILS_HSE_FREQUENCY_MIN 4000000U |
#define | UTILS_HSE_FREQUENCY_MAX 48000000U |
#define | IS_LL_UTILS_SYSCLK_DIV(__VALUE__) |
#define | IS_LL_UTILS_AHB_DIV(__VALUE__) |
#define | IS_LL_UTILS_APB1_DIV(__VALUE__) |
#define | IS_LL_UTILS_APB2_DIV(__VALUE__) |
#define | IS_LL_UTILS_APB3_DIV(__VALUE__) |
#define | IS_LL_UTILS_APB4_DIV(__VALUE__) |
#define | IS_LL_UTILS_PLLM_VALUE(__VALUE__) ((1U <= (__VALUE__)) && ((__VALUE__) <= 63U)) |
#define | IS_LL_UTILS_PLLN_VALUE(__VALUE__) ((8U <= (__VALUE__)) && ((__VALUE__) <= 420U)) |
#define | IS_LL_UTILS_PLLP_VALUE(__VALUE__) ((1U <= (__VALUE__)) && ((__VALUE__) <= 128U)) |
#define | IS_LL_UTILS_FRACN_VALUE(__VALUE__) ((__VALUE__) <= 0x1FFFU) |
#define | IS_LL_UTILS_PLLVCO_INPUT(__VALUE__, __RANGE__) |
#define | IS_LL_UTILS_PLLVCO_OUTPUT(__VALUE__, __RANGE__) |
#define | IS_LL_UTILS_CHECK_VCO_RANGES(__RANGEIN__, __RANGEOUT__) |
#define | IS_LL_UTILS_PLL_FREQUENCY(__VALUE__) |
#define | IS_LL_UTILS_HSE_BYPASS(__STATE__) |
#define | IS_LL_UTILS_HSE_FREQUENCY(__FREQUENCY__) (((__FREQUENCY__) >= UTILS_HSE_FREQUENCY_MIN) && ((__FREQUENCY__) <= UTILS_HSE_FREQUENCY_MAX)) |
void | LL_Init1msTick (uint32_t CPU_Frequency) |
This function configures the Cortex-M SysTick source to have 1ms time base. | |
void | LL_mDelay (uint32_t Delay) |
This function provides accurate delay (in milliseconds) based on SysTick counter flag. | |
void | LL_SetSystemCoreClock (uint32_t CPU_Frequency) |
This function sets directly SystemCoreClock CMSIS variable. | |
ErrorStatus | LL_PLL_ConfigSystemClock_HSI (LL_UTILS_PLLInitTypeDef *UTILS_PLLInitStruct, LL_UTILS_ClkInitTypeDef *UTILS_ClkInitStruct) |
This function configures system clock at maximum frequency with HSI as clock source of the PLL. | |
ErrorStatus | LL_PLL_ConfigSystemClock_HSE (uint32_t HSEFrequency, uint32_t HSEBypass, LL_UTILS_PLLInitTypeDef *UTILS_PLLInitStruct, LL_UTILS_ClkInitTypeDef *UTILS_ClkInitStruct) |
This function configures system clock with HSE as clock source of the PLL. | |
ErrorStatus | LL_SetFlashLatency (uint32_t HCLK_Frequency) |
Update number of Flash wait states in line with new frequency and current voltage range. | |
