RTEMS 6.1-rc4
Extended USART HAL module driver. This file provides firmware functions to manage the following extended functionalities of the Universal Synchronous Receiver Transmitter Peripheral (USART). More...
#include "stm32h7xx_hal.h"
============================================================================== ##### USART peripheral extended features ##### ============================================================================== (#) FIFO mode enabling/disabling and RX/TX FIFO threshold programming. -@- When USART operates in FIFO mode, FIFO mode must be enabled prior starting RX/TX transfers. Also RX/TX FIFO thresholds must be configured prior starting RX/TX transfers. (#) Slave mode enabling/disabling and NSS pin configuration. -@- When USART operates in Slave mode, Slave mode must be enabled prior starting RX/TX transfers.
