RTEMS 6.1-rc4
USART HAL module driver. This file provides firmware functions to manage the following functionalities of the Universal Synchronous/Asynchronous Receiver Transmitter Peripheral (USART). More...
#include "stm32h7xx_hal.h"
=============================================================================== ##### How to use this driver ##### =============================================================================== [..] The USART HAL driver can be used as follows: (#) Declare a USART_HandleTypeDef handle structure (eg. USART_HandleTypeDef husart). (#) Initialize the USART low level resources by implementing the HAL_USART_MspInit() API: (++) Enable the USARTx interface clock. (++) USART pins configuration: (+++) Enable the clock for the USART GPIOs. (+++) Configure these USART pins as alternate function pull-up. (++) NVIC configuration if you need to use interrupt process (HAL_USART_Transmit_IT(), HAL_USART_Receive_IT() and HAL_USART_TransmitReceive_IT() APIs): (+++) Configure the USARTx interrupt priority. (+++) Enable the NVIC USART IRQ handle. (++) USART interrupts handling: -@@- The specific USART interrupts (Transmission complete interrupt, RXNE interrupt and Error Interrupts) will be managed using the macros __HAL_USART_ENABLE_IT() and __HAL_USART_DISABLE_IT() inside the transmit and receive process. (++) DMA Configuration if you need to use DMA process (HAL_USART_Transmit_DMA() HAL_USART_Receive_DMA() and HAL_USART_TransmitReceive_DMA() APIs): (+++) Declare a DMA handle structure for the Tx/Rx channel. (+++) Enable the DMAx interface clock. (+++) Configure the declared DMA handle structure with the required Tx/Rx parameters. (+++) Configure the DMA Tx/Rx channel. (+++) Associate the initialized DMA handle to the USART DMA Tx/Rx handle. (+++) Configure the priority and enable the NVIC for the transfer complete interrupt on the DMA Tx/Rx channel. (#) Program the Baud Rate, Word Length, Stop Bit, Parity, and Mode (Receiver/Transmitter) in the husart handle Init structure. (#) Initialize the USART registers by calling the HAL_USART_Init() API: (++) This API configures also the low level Hardware GPIO, CLOCK, CORTEX...etc) by calling the customized HAL_USART_MspInit(&husart) API. [..] (@) To configure and enable/disable the USART to wake up the MCU from stop mode, resort to UART API's HAL_UARTEx_StopModeWakeUpSourceConfig(), HAL_UARTEx_EnableStopMode() and HAL_UARTEx_DisableStopMode() in casting the USART handle to UART type UART_HandleTypeDef. ##### Callback registration ##### ================================== [..] The compilation define USE_HAL_USART_REGISTER_CALLBACKS when set to 1 allows the user to configure dynamically the driver callbacks. [..] Use Function HAL_USART_RegisterCallback() to register a user callback. Function HAL_USART_RegisterCallback() allows to register following callbacks: (+) TxHalfCpltCallback : Tx Half Complete Callback. (+) TxCpltCallback : Tx Complete Callback. (+) RxHalfCpltCallback : Rx Half Complete Callback. (+) RxCpltCallback : Rx Complete Callback. (+) TxRxCpltCallback : Tx Rx Complete Callback. (+) ErrorCallback : Error Callback. (+) AbortCpltCallback : Abort Complete Callback. (+) RxFifoFullCallback : Rx Fifo Full Callback. (+) TxFifoEmptyCallback : Tx Fifo Empty Callback. (+) MspInitCallback : USART MspInit. (+) MspDeInitCallback : USART MspDeInit. This function takes as parameters the HAL peripheral handle, the Callback ID and a pointer to the user callback function. [..] Use function HAL_USART_UnRegisterCallback() to reset a callback to the default weak function. HAL_USART_UnRegisterCallback() takes as parameters the HAL peripheral handle, and the Callback ID. This function allows to reset following callbacks: (+) TxHalfCpltCallback : Tx Half Complete Callback. (+) TxCpltCallback : Tx Complete Callback. (+) RxHalfCpltCallback : Rx Half Complete Callback. (+) RxCpltCallback : Rx Complete Callback. (+) TxRxCpltCallback : Tx Rx Complete Callback. (+) ErrorCallback : Error Callback. (+) AbortCpltCallback : Abort Complete Callback. (+) RxFifoFullCallback : Rx Fifo Full Callback. (+) TxFifoEmptyCallback : Tx Fifo Empty Callback. (+) MspInitCallback : USART MspInit. (+) MspDeInitCallback : USART MspDeInit. [..] By default, after the HAL_USART_Init() and when the state is HAL_USART_STATE_RESET all callbacks are set to the corresponding weak functions: examples HAL_USART_TxCpltCallback(), HAL_USART_RxHalfCpltCallback(). Exception done for MspInit and MspDeInit functions that are respectively reset to the legacy weak functions in the HAL_USART_Init() and HAL_USART_DeInit() only when these callbacks are null (not registered beforehand). If not, MspInit or MspDeInit are not null, the HAL_USART_Init() and HAL_USART_DeInit() keep and use the user MspInit/MspDeInit callbacks (registered beforehand). [..] Callbacks can be registered/unregistered in HAL_USART_STATE_READY state only. Exception done MspInit/MspDeInit that can be registered/unregistered in HAL_USART_STATE_READY or HAL_USART_STATE_RESET state, thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit. In that case first register the MspInit/MspDeInit user callbacks using HAL_USART_RegisterCallback() before calling HAL_USART_DeInit() or HAL_USART_Init() function. [..] When The compilation define USE_HAL_USART_REGISTER_CALLBACKS is set to 0 or not defined, the callback registration feature is not available and weak callbacks are used.
