RTEMS 6.1-rc4
stm32h7xx_hal_spdifrx.c File Reference
This file provides firmware functions to manage the following functionalities of the SPDIFRX audio interface: More...
#include "stm32h7xx_hal.h"
Author
MCD Application Team
  • Initialization and Configuration
  • Data transfers functions
  • DMA transfers management
  • Interrupts and flags management
Attention
                 ##### How to use this driver #####
   The SPDIFRX HAL driver can be used as follow:
   (#) Declare SPDIFRX_HandleTypeDef handle structure.
   (#) Initialize the SPDIFRX low level resources by implement the HAL_SPDIFRX_MspInit() API:
       (##) Enable the SPDIFRX interface clock.
       (##) SPDIFRX pins configuration:
           (+++) Enable the clock for the SPDIFRX GPIOs.
           (+++) Configure these SPDIFRX pins as alternate function pull-up.
       (##) NVIC configuration if you need to use interrupt process (HAL_SPDIFRX_ReceiveCtrlFlow_IT() and
            HAL_SPDIFRX_ReceiveDataFlow_IT() API's).
           (+++) Configure the SPDIFRX interrupt priority.
           (+++) Enable the NVIC SPDIFRX IRQ handle.
       (##) DMA Configuration if you need to use DMA process (HAL_SPDIFRX_ReceiveDataFlow_DMA() and
            HAL_SPDIFRX_ReceiveCtrlFlow_DMA() API's).
           (+++) Declare a DMA handle structure for the reception of the Data Flow channel.
           (+++) Declare a DMA handle structure for the reception of the Control Flow channel.
           (+++) Enable the DMAx interface clock.
           (+++) Configure the declared DMA handle structure CtrlRx/DataRx with the required parameters.
           (+++) Configure the DMA Channel.
           (+++) Associate the initialized DMA handle to the SPDIFRX DMA CtrlRx/DataRx handle.
           (+++) Configure the priority and enable the NVIC for the transfer complete interrupt on the
               DMA CtrlRx/DataRx channel.
  (#) Program the input selection, re-tries number, wait for activity, channel status selection, data format,
      stereo mode and masking of user bits using HAL_SPDIFRX_Init() function.
  -@- The specific SPDIFRX interrupts (RXNE/CSRNE and Error Interrupts) will be managed using the macros
      __SPDIFRX_ENABLE_IT() and __SPDIFRX_DISABLE_IT() inside the receive process.
  -@- Make sure that ck_spdif clock is configured.
  (#) Three operation modes are available within this driver :
  *** Polling mode for reception operation (for debug purpose) ***
    (+) Receive data flow in blocking mode using HAL_SPDIFRX_ReceiveDataFlow()
    (+) Receive control flow of data in blocking mode using HAL_SPDIFRX_ReceiveCtrlFlow()
  *** Interrupt mode for reception operation ***
    (+) Receive an amount of data (Data Flow) in non blocking mode using HAL_SPDIFRX_ReceiveDataFlow_IT()
    (+) Receive an amount of data (Control Flow) in non blocking mode using HAL_SPDIFRX_ReceiveCtrlFlow_IT()
    (+) At reception end of half transfer HAL_SPDIFRX_RxHalfCpltCallback is executed and user can
        add his own code by customization of function pointer HAL_SPDIFRX_RxHalfCpltCallback
    (+) At reception end of transfer HAL_SPDIFRX_RxCpltCallback is executed and user can
        add his own code by customization of function pointer HAL_SPDIFRX_RxCpltCallback
    (+) In case of transfer Error, HAL_SPDIFRX_ErrorCallback() function is executed and user can
        add his own code by customization of function pointer HAL_SPDIFRX_ErrorCallback
  *** DMA mode for reception operation ***
    (+) Receive an amount of data (Data Flow) in non blocking mode (DMA) using HAL_SPDIFRX_ReceiveDataFlow_DMA()
    (+) Receive an amount of data (Control Flow) in non blocking mode (DMA) using HAL_SPDIFRX_ReceiveCtrlFlow_DMA()
    (+) Stop the DMA Transfer using HAL_SPDIFRX_DMAStop()
  *** SPDIFRX HAL driver macros list ***
    Below the list of most used macros in SPDIFRX HAL driver.
     (+) __HAL_SPDIFRX_IDLE: Disable the specified SPDIFRX peripheral (IDLE State)
     (+) __HAL_SPDIFRX_SYNC: Enable the synchronization state of the specified SPDIFRX peripheral (SYNC State)
     (+) __HAL_SPDIFRX_RCV: Enable the receive state of the specified SPDIFRX peripheral (RCV State)
     (+) __HAL_SPDIFRX_ENABLE_IT : Enable the specified SPDIFRX interrupts
     (+) __HAL_SPDIFRX_DISABLE_IT : Disable the specified SPDIFRX interrupts
     (+) __HAL_SPDIFRX_GET_FLAG: Check whether the specified SPDIFRX flag is set or not.
     (@) You can refer to the SPDIFRX HAL driver header file for more useful macros
 *** Callback registration ***
 The compilation define  USE_HAL_SPDIFRX_REGISTER_CALLBACKS when set to 1
 allows the user to configure dynamically the driver callbacks.
 Use HAL_SPDIFRX_RegisterCallback() function to register an interrupt callback.
 The HAL_SPDIFRX_RegisterCallback() function allows to register the following callbacks:
   (+) RxHalfCpltCallback  : SPDIFRX Data flow half completed callback.
   (+) RxCpltCallback      : SPDIFRX Data flow completed callback.
   (+) CxHalfCpltCallback  : SPDIFRX Control flow half completed callback.
   (+) CxCpltCallback      : SPDIFRX Control flow completed callback.
   (+) ErrorCallback       : SPDIFRX error callback.
   (+) MspInitCallback     : SPDIFRX MspInit.
   (+) MspDeInitCallback   : SPDIFRX MspDeInit.
 This function takes as parameters the HAL peripheral handle, the Callback ID
 and a pointer to the user callback function.
 Use HAL_SPDIFRX_UnRegisterCallback() function to reset a callback to the default
 weak function.
 The HAL_SPDIFRX_UnRegisterCallback() function takes as parameters the HAL peripheral handle,
 and the Callback ID.
 This function allows to reset the following callbacks:
 By default, after the HAL_SPDIFRX_Init() and when the state is HAL_SPDIFRX_STATE_RESET
 all callbacks are set to the corresponding weak functions :
 HAL_SPDIFRX_RxHalfCpltCallback() , HAL_SPDIFRX_RxCpltCallback(), HAL_SPDIFRX_CxHalfCpltCallback(),
 HAL_SPDIFRX_CxCpltCallback() and HAL_SPDIFRX_ErrorCallback()
 Exception done for MspInit and MspDeInit functions that are
 reset to the legacy weak function in the HAL_SPDIFRX_Init()/ HAL_SPDIFRX_DeInit() only when
 these callbacks pointers are NULL (not registered beforehand).
 If not, MspInit or MspDeInit callbacks pointers are not null, the HAL_SPDIFRX_Init() / HAL_SPDIFRX_DeInit()
 keep and use the user MspInit/MspDeInit functions (registered beforehand)
 Callbacks can be registered/unregistered in HAL_SPDIFRX_STATE_READY state only.
 Exception done MspInit/MspDeInit callbacks that can be registered/unregistered
 in HAL_SPDIFRX_STATE_READY or HAL_SPDIFRX_STATE_RESET state,
 thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit.
 In that case first register the MspInit/MspDeInit user callbacks
 using HAL_SPDIFRX_RegisterCallback() before calling HAL_SPDIFRX_DeInit()
 or HAL_SPDIFRX_Init() function.
 When The compilation define USE_HAL_SPDIFRX_REGISTER_CALLBACKS is set to 0 or
 not defined, the callback registration feature is not available and all callbacks
 are set to the corresponding weak functions.
