RTEMS 6.1-rc4
stm32h7xx_hal_smartcard.c File Reference
SMARTCARD HAL module driver. This file provides firmware functions to manage the following functionalities of the SMARTCARD peripheral: More...
#include "stm32h7xx_hal.h"
Author
MCD Application Team
  • Initialization and de-initialization functions
  • IO operation functions
  • Peripheral Control functions
  • Peripheral State and Error functions
Attention
                      ##### How to use this driver #####
  The SMARTCARD HAL driver can be used as follows:
  (#) Declare a SMARTCARD_HandleTypeDef handle structure (eg. SMARTCARD_HandleTypeDef hsmartcard).
  (#) Associate a USART to the SMARTCARD handle hsmartcard.
  (#) Initialize the SMARTCARD low level resources by implementing the HAL_SMARTCARD_MspInit() API:
      (++) Enable the USARTx interface clock.
      (++) USART pins configuration:
           (+++) Enable the clock for the USART GPIOs.
           (+++) Configure the USART pins (TX as alternate function pull-up, RX as alternate function Input).
      (++) NVIC configuration if you need to use interrupt process (HAL_SMARTCARD_Transmit_IT()
           and HAL_SMARTCARD_Receive_IT() APIs):
           (+++) Configure the USARTx interrupt priority.
           (+++) Enable the NVIC USART IRQ handle.
      (++) DMA Configuration if you need to use DMA process (HAL_SMARTCARD_Transmit_DMA()
           and HAL_SMARTCARD_Receive_DMA() APIs):
           (+++) Declare a DMA handle structure for the Tx/Rx channel.
           (+++) Enable the DMAx interface clock.
           (+++) Configure the declared DMA handle structure with the required Tx/Rx parameters.
           (+++) Configure the DMA Tx/Rx channel.
           (+++) Associate the initialized DMA handle to the SMARTCARD DMA Tx/Rx handle.
           (+++) Configure the priority and enable the NVIC for the transfer complete
                 interrupt on the DMA Tx/Rx channel.
  (#) Program the Baud Rate, Parity, Mode(Receiver/Transmitter), clock enabling/disabling and accordingly,
      the clock parameters (parity, phase, last bit), prescaler value, guard time and NACK on transmission
      error enabling or disabling in the hsmartcard handle Init structure.
  (#) If required, program SMARTCARD advanced features (TX/RX pins swap, TimeOut, auto-retry counter,...)
      in the hsmartcard handle AdvancedInit structure.
  (#) Initialize the SMARTCARD registers by calling the HAL_SMARTCARD_Init() API:
      (++) This API configures also the low level Hardware GPIO, CLOCK, CORTEX...etc)
           by calling the customized HAL_SMARTCARD_MspInit() API.
      (@) The specific SMARTCARD interrupts (Transmission complete interrupt,
           RXNE interrupt and Error Interrupts) will be managed using the macros
           __HAL_SMARTCARD_ENABLE_IT() and __HAL_SMARTCARD_DISABLE_IT() inside the transmit and receive process.
  [..] Three operation modes are available within this driver :
   *** Polling mode IO operation ***
     (+) Send an amount of data in blocking mode using HAL_SMARTCARD_Transmit()
     (+) Receive an amount of data in blocking mode using HAL_SMARTCARD_Receive()
   *** Interrupt mode IO operation ***
     (+) Send an amount of data in non-blocking mode using HAL_SMARTCARD_Transmit_IT()
     (+) At transmission end of transfer HAL_SMARTCARD_TxCpltCallback() is executed and user can
          add his own code by customization of function pointer HAL_SMARTCARD_TxCpltCallback()
     (+) Receive an amount of data in non-blocking mode using HAL_SMARTCARD_Receive_IT()
     (+) At reception end of transfer HAL_SMARTCARD_RxCpltCallback() is executed and user can
          add his own code by customization of function pointer HAL_SMARTCARD_RxCpltCallback()
     (+) In case of transfer Error, HAL_SMARTCARD_ErrorCallback() function is executed and user can
          add his own code by customization of function pointer HAL_SMARTCARD_ErrorCallback()
   *** DMA mode IO operation ***
     (+) Send an amount of data in non-blocking mode (DMA) using HAL_SMARTCARD_Transmit_DMA()
     (+) Receive an amount of data in non-blocking mode (DMA) using HAL_SMARTCARD_Receive_DMA()
   *** SMARTCARD HAL driver macros list ***
     Below the list of most used macros in SMARTCARD HAL driver.
     (+) __HAL_SMARTCARD_GET_FLAG : Check whether or not the specified SMARTCARD flag is set
     (+) __HAL_SMARTCARD_CLEAR_FLAG : Clear the specified SMARTCARD pending flag
     (+) __HAL_SMARTCARD_ENABLE_IT: Enable the specified SMARTCARD interrupt
     (+) __HAL_SMARTCARD_DISABLE_IT: Disable the specified SMARTCARD interrupt
     (+) __HAL_SMARTCARD_GET_IT_SOURCE: Check whether or not the specified SMARTCARD interrupt is enabled
     (@) You can refer to the SMARTCARD HAL driver header file for more useful macros
  ##### Callback registration #####
  The compilation define USE_HAL_SMARTCARD_REGISTER_CALLBACKS when set to 1
  allows the user to configure dynamically the driver callbacks.
  Use Function HAL_SMARTCARD_RegisterCallback() to register a user callback.
  Function HAL_SMARTCARD_RegisterCallback() allows to register following callbacks:
  (+) TxCpltCallback            : Tx Complete Callback.
  (+) RxCpltCallback            : Rx Complete Callback.
  (+) ErrorCallback             : Error Callback.
  (+) AbortCpltCallback         : Abort Complete Callback.
  (+) AbortTransmitCpltCallback : Abort Transmit Complete Callback.
  (+) AbortReceiveCpltCallback  : Abort Receive Complete Callback.
  (+) RxFifoFullCallback        : Rx Fifo Full Callback.
  (+) TxFifoEmptyCallback       : Tx Fifo Empty Callback.
  (+) MspInitCallback           : SMARTCARD MspInit.
  (+) MspDeInitCallback         : SMARTCARD MspDeInit.
  This function takes as parameters the HAL peripheral handle, the Callback ID
  and a pointer to the user callback function.
  Use function HAL_SMARTCARD_UnRegisterCallback() to reset a callback to the default
  weak function.
  HAL_SMARTCARD_UnRegisterCallback() takes as parameters the HAL peripheral handle,
  and the Callback ID.
  This function allows to reset following callbacks:
  By default, after the HAL_SMARTCARD_Init() and when the state is HAL_SMARTCARD_STATE_RESET
  all callbacks are set to the corresponding weak functions:
  examples HAL_SMARTCARD_TxCpltCallback(), HAL_SMARTCARD_RxCpltCallback().
  Exception done for MspInit and MspDeInit functions that are respectively
  reset to the legacy weak functions in the HAL_SMARTCARD_Init()
  and HAL_SMARTCARD_DeInit() only when these callbacks are null (not registered beforehand).
  If not, MspInit or MspDeInit are not null, the HAL_SMARTCARD_Init() and HAL_SMARTCARD_DeInit()
  keep and use the user MspInit/MspDeInit callbacks (registered beforehand).
  Callbacks can be registered/unregistered in HAL_SMARTCARD_STATE_READY state only.
  Exception done MspInit/MspDeInit that can be registered/unregistered
  in HAL_SMARTCARD_STATE_READY or HAL_SMARTCARD_STATE_RESET state, thus registered (user)
  MspInit/DeInit callbacks can be used during the Init/DeInit.
  In that case first register the MspInit/MspDeInit user callbacks
  using HAL_SMARTCARD_RegisterCallback() before calling HAL_SMARTCARD_DeInit()
  or HAL_SMARTCARD_Init() function.
  When The compilation define USE_HAL_SMARTCARD_REGISTER_CALLBACKS is set to 0 or
  not defined, the callback registration feature is not available
  and weak callbacks are used.
