RTEMS 6.1-rc4
Header file of RTC HAL Extension module. More...
#include "stm32h7xx_hal_def.h"
struct | RTC_TamperTypeDef |
#define | BKP_REG_NUMBER RTC_BKP_NUMBER |
#define | RTC_BKP_DR0 0x00u |
#define | RTC_BKP_DR1 0x01u |
#define | RTC_BKP_DR2 0x02u |
#define | RTC_BKP_DR3 0x03u |
#define | RTC_BKP_DR4 0x04u |
#define | RTC_BKP_DR5 0x05u |
#define | RTC_BKP_DR6 0x06u |
#define | RTC_BKP_DR7 0x07u |
#define | RTC_BKP_DR8 0x08u |
#define | RTC_BKP_DR9 0x09u |
#define | RTC_BKP_DR10 0x0Au |
#define | RTC_BKP_DR11 0x0Bu |
#define | RTC_BKP_DR12 0x0Cu |
#define | RTC_BKP_DR13 0x0Du |
#define | RTC_BKP_DR14 0x0Eu |
#define | RTC_BKP_DR15 0x0Fu |
#define | RTC_BKP_DR16 0x10u |
#define | RTC_BKP_DR17 0x11u |
#define | RTC_BKP_DR18 0x12u |
#define | RTC_BKP_DR19 0x13u |
#define | RTC_BKP_DR20 0x14u |
#define | RTC_BKP_DR21 0x15u |
#define | RTC_BKP_DR22 0x16u |
#define | RTC_BKP_DR23 0x17u |
#define | RTC_BKP_DR24 0x18u |
#define | RTC_BKP_DR25 0x19u |
#define | RTC_BKP_DR26 0x1Au |
#define | RTC_BKP_DR27 0x1Bu |
#define | RTC_BKP_DR28 0x1Cu |
#define | RTC_BKP_DR29 0x1Du |
#define | RTC_BKP_DR30 0x1Eu |
#define | RTC_BKP_DR31 0x1Fu |
#define | RTC_TIMESTAMPEDGE_RISING 0x00000000u |
#define | RTC_TIMESTAMPEDGE_FALLING RTC_CR_TSEDGE |
#define | RTC_TIMESTAMPPIN_DEFAULT 0x00000000u |
#define | RTC_TAMPER_1 RTC_TAMPCR_TAMP1E |
#define | RTC_TAMPER_2 RTC_TAMPCR_TAMP2E |
#define | RTC_TAMPER_3 RTC_TAMPCR_TAMP3E |
#define | RTC_TAMPER_ALL (RTC_TAMPER_1 | RTC_TAMPER_2 | RTC_TAMPER_3) |
#define | RTC_IT_TAMP1 RTC_TAMPCR_TAMP1IE |
#define | RTC_IT_TAMP2 RTC_TAMPCR_TAMP2IE |
#define | RTC_IT_TAMP3 RTC_TAMPCR_TAMP3IE |
#define | RTC_IT_TAMP RTC_TAMPCR_TAMPIE |
#define | RTC_IT_TAMPALL RTC_IT_TAMP |
#define | RTC_TAMPERTRIGGER_RISINGEDGE 0x01u |
#define | RTC_TAMPERTRIGGER_FALLINGEDGE 0x02u |
#define | RTC_TAMPERTRIGGER_LOWLEVEL 0x04u |
#define | RTC_TAMPERTRIGGER_HIGHLEVEL 0x08u |
#define | RTC_TAMPER_1_TRIGGER RTC_TAMPCR_TAMP1TRG |
#define | RTC_TAMPER_2_TRIGGER RTC_TAMPCR_TAMP2TRG |
#define | RTC_TAMPER_3_TRIGGER RTC_TAMPCR_TAMP3TRG |
#define | RTC_TAMPER_X_TRIGGER |
#define | RTC_TAMPER_ERASE_BACKUP_ENABLE 0x00000000u |
#define | RTC_TAMPER_ERASE_BACKUP_DISABLE RTC_TAMPCR_TAMP1NOERASE |
#define | RTC_DISABLE_BKP_ERASE_ON_TAMPER_1 RTC_TAMPCR_TAMP1NOERASE |
#define | RTC_DISABLE_BKP_ERASE_ON_TAMPER_2 RTC_TAMPCR_TAMP2NOERASE |
#define | RTC_DISABLE_BKP_ERASE_ON_TAMPER_3 RTC_TAMPCR_TAMP3NOERASE |
#define | RTC_DISABLE_BKP_ERASE_ON_TAMPER_MASK |
#define | RTC_TAMPERMASK_FLAG_DISABLE 0x00000000u |
#define | RTC_TAMPERMASK_FLAG_ENABLE RTC_TAMPCR_TAMP1MF |
#define | RTC_TAMPER_1_MASK_FLAG RTC_TAMPCR_TAMP1MF |
#define | RTC_TAMPER_2_MASK_FLAG RTC_TAMPCR_TAMP2MF |
#define | RTC_TAMPER_3_MASK_FLAG RTC_TAMPCR_TAMP3MF |
#define | RTC_TAMPER_X_MASK_FLAG |
#define | RTC_TAMPERFILTER_DISABLE 0x00000000u |
#define | RTC_TAMPERFILTER_2SAMPLE RTC_TAMPCR_TAMPFLT_0 |
#define | RTC_TAMPERFILTER_4SAMPLE RTC_TAMPCR_TAMPFLT_1 |
#define | RTC_TAMPERFILTER_8SAMPLE RTC_TAMPCR_TAMPFLT |
#define | RTC_TAMPERFILTER_MASK RTC_TAMPCR_TAMPFLT |
#define | RTC_TAMPERSAMPLINGFREQ_RTCCLK_DIV32768 0x00000000u |
#define | RTC_TAMPERSAMPLINGFREQ_RTCCLK_DIV16384 RTC_TAMPCR_TAMPFREQ_0 |
#define | RTC_TAMPERSAMPLINGFREQ_RTCCLK_DIV8192 RTC_TAMPCR_TAMPFREQ_1 |
#define | RTC_TAMPERSAMPLINGFREQ_RTCCLK_DIV4096 (RTC_TAMPCR_TAMPFREQ_0 | RTC_TAMPCR_TAMPFREQ_1) |
#define | RTC_TAMPERSAMPLINGFREQ_RTCCLK_DIV2048 RTC_TAMPCR_TAMPFREQ_2 |
#define | RTC_TAMPERSAMPLINGFREQ_RTCCLK_DIV1024 (RTC_TAMPCR_TAMPFREQ_0 | RTC_TAMPCR_TAMPFREQ_2) |
#define | RTC_TAMPERSAMPLINGFREQ_RTCCLK_DIV512 (RTC_TAMPCR_TAMPFREQ_1 | RTC_TAMPCR_TAMPFREQ_2) |
#define | RTC_TAMPERSAMPLINGFREQ_RTCCLK_DIV256 RTC_TAMPCR_TAMPFREQ |
#define | RTC_TAMPERSAMPLINGFREQ_RTCCLK_MASK RTC_TAMPCR_TAMPFREQ |
#define | RTC_TAMPERPRECHARGEDURATION_1RTCCLK 0x00000000u |
#define | RTC_TAMPERPRECHARGEDURATION_2RTCCLK RTC_TAMPCR_TAMPPRCH_0 |
#define | RTC_TAMPERPRECHARGEDURATION_4RTCCLK RTC_TAMPCR_TAMPPRCH_1 |
#define | RTC_TAMPERPRECHARGEDURATION_8RTCCLK RTC_TAMPCR_TAMPPRCH |
#define | RTC_TAMPERPRECHARGEDURATION_MASK RTC_TAMPCR_TAMPPRCH |
#define | RTC_TIMESTAMPONTAMPERDETECTION_DISABLE 0x00000000u |
#define | RTC_TIMESTAMPONTAMPERDETECTION_ENABLE RTC_TAMPCR_TAMPTS |
#define | RTC_TIMESTAMPONTAMPERDETECTION_MASK RTC_TAMPCR_TAMPTS |
#define | RTC_TAMPER_PULLUP_ENABLE 0x00000000u |
#define | RTC_TAMPER_PULLUP_DISABLE RTC_TAMPCR_TAMPPUDIS |
#define | RTC_TAMPER_PULLUP_MASK RTC_TAMPCR_TAMPPUDIS |
#define | RTC_FLAG_TAMP1F RTC_ISR_TAMP1F |
#define | RTC_FLAG_TAMP2F RTC_ISR_TAMP2F |
#define | RTC_FLAG_TAMP3F RTC_ISR_TAMP3F |
#define | RTC_ATAMP_ENABLE 1u |
#define | RTC_ATAMP_DISABLE 0u |
#define | RTC_ATAMP_INTERRUPT_ENABLE 1u |
#define | RTC_ATAMP_INTERRUPT_DISABLE 0u |
#define | RTC_ATAMP_FILTER_ENABLE TAMP_ATCR1_FLTEN |
#define | RTC_ATAMP_FILTER_DISABLE 0u |
#define | RTC_ATAMP_ASYNCPRES_RTCCLK 0u |
#define | RTC_ATAMP_ASYNCPRES_RTCCLK_2 TAMP_ATCR1_ATCKSEL_0 |
#define | RTC_ATAMP_ASYNCPRES_RTCCLK_4 TAMP_ATCR1_ATCKSEL_1 |
#define | RTC_ATAMP_ASYNCPRES_RTCCLK_8 (TAMP_ATCR1_ATCKSEL_1 | TAMP_ATCR1_ATCKSEL_0) |
#define | RTC_ATAMP_ASYNCPRES_RTCCLK_16 TAMP_ATCR1_ATCKSEL_2 |
#define | RTC_ATAMP_ASYNCPRES_RTCCLK_32 (TAMP_ATCR1_ATCKSEL_2 | TAMP_ATCR1_ATCKSEL_0) |
#define | RTC_ATAMP_ASYNCPRES_RTCCLK_64 (TAMP_ATCR1_ATCKSEL_2 | TAMP_ATCR1_ATCKSEL_1) |
#define | RTC_ATAMP_ASYNCPRES_RTCCLK_128 (TAMP_ATCR1_ATCKSEL_2 | TAMP_ATCR1_ATCKSEL_1 | TAMP_ATCR1_ATCKSEL_0) |
#define | RTC_ATAMP_1 0u |
#define | RTC_ATAMP_2 1u |
#define | RTC_ATAMP_3 2u |
#define | RTC_ATAMP_4 3u |
#define | RTC_ATAMP_5 4u |
#define | RTC_ATAMP_6 5u |
#define | RTC_ATAMP_7 6u |
#define | RTC_ATAMP_8 7u |
#define | RTC_MONOTONIC_COUNTER_1 0u |
#define | RTC_WAKEUPCLOCK_RTCCLK_DIV16 0x00000000u |
#define | RTC_WAKEUPCLOCK_RTCCLK_DIV8 RTC_CR_WUCKSEL_0 |
#define | RTC_WAKEUPCLOCK_RTCCLK_DIV4 RTC_CR_WUCKSEL_1 |
#define | RTC_WAKEUPCLOCK_RTCCLK_DIV2 (RTC_CR_WUCKSEL_0 | RTC_CR_WUCKSEL_1) |
#define | RTC_WAKEUPCLOCK_CK_SPRE_16BITS RTC_CR_WUCKSEL_2 |
#define | RTC_WAKEUPCLOCK_CK_SPRE_17BITS (RTC_CR_WUCKSEL_1 | RTC_CR_WUCKSEL_2) |
#define | RTC_SMOOTHCALIB_PERIOD_32SEC 0x00000000u |
#define | RTC_SMOOTHCALIB_PERIOD_16SEC RTC_CALR_CALW16 |
#define | RTC_SMOOTHCALIB_PERIOD_8SEC RTC_CALR_CALW8 |
#define | RTC_SMOOTHCALIB_PLUSPULSES_SET RTC_CALR_CALP |
#define | RTC_SMOOTHCALIB_PLUSPULSES_RESET 0x00000000u |
#define | RTC_CALIBOUTPUT_512HZ 0x00000000u |
#define | RTC_CALIBOUTPUT_1HZ RTC_CR_COSEL |
#define | RTC_SHIFTADD1S_RESET 0x00000000u |
#define | RTC_SHIFTADD1S_SET RTC_SHIFTR_ADD1S |
#define | __HAL_RTC_WAKEUPTIMER_ENABLE(__HANDLE__) ((__HANDLE__)->Instance->CR |= (RTC_CR_WUTE)) |
Enable the RTC WakeUp Timer peripheral. | |
#define | __HAL_RTC_WAKEUPTIMER_DISABLE(__HANDLE__) ((__HANDLE__)->Instance->CR &= ~(RTC_CR_WUTE)) |
Disable the RTC WakeUp Timer peripheral. | |
#define | __HAL_RTC_WAKEUPTIMER_ENABLE_IT(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->CR |= (__INTERRUPT__)) |
Enable the RTC WakeUpTimer interrupt. | |
#define | __HAL_RTC_WAKEUPTIMER_DISABLE_IT(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->CR &= ~(__INTERRUPT__)) |
Disable the RTC WakeUpTimer interrupt. | |
#define | __HAL_RTC_WAKEUPTIMER_GET_IT(__HANDLE__, __INTERRUPT__) (((((__HANDLE__)->Instance->ISR) & (__INTERRUPT__)) != 0U) ? 1U : 0U) |
Check whether the specified RTC WakeUpTimer interrupt has occurred or not. | |
#define | __HAL_RTC_WAKEUPTIMER_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__) (((((__HANDLE__)->Instance->CR) & (__INTERRUPT__)) != 0U) ? 1U : 0U) |
Check whether the specified RTC Wake Up timer interrupt has been enabled or not. | |
#define | __HAL_RTC_WAKEUPTIMER_GET_FLAG(__HANDLE__, __FLAG__) (((((__HANDLE__)->Instance->ISR) & (__FLAG__)) != 0U) ? 1U : 0U) |
Get the selected RTC WakeUpTimer's flag status. | |
#define | __HAL_RTC_WAKEUPTIMER_CLEAR_FLAG(__HANDLE__, __FLAG__) ((__HANDLE__)->Instance->ISR) = (~((__FLAG__) | RTC_ISR_INIT)|((__HANDLE__)->Instance->ISR & RTC_ISR_INIT)) |
Clear the RTC Wake Up timer's pending flags. | |
#define | __HAL_RTC_TAMPER1_ENABLE(__HANDLE__) ((__HANDLE__)->Instance->TAMPCR |= (RTC_TAMPCR_TAMP1E)) |
Enable the RTC Tamper1 input detection. | |
#define | __HAL_RTC_TAMPER1_DISABLE(__HANDLE__) ((__HANDLE__)->Instance->TAMPCR &= ~(RTC_TAMPCR_TAMP1E)) |
Disable the RTC Tamper1 input detection. | |
#define | __HAL_RTC_TAMPER2_ENABLE(__HANDLE__) ((__HANDLE__)->Instance->TAMPCR |= (RTC_TAMPCR_TAMP2E)) |
Enable the RTC Tamper2 input detection. | |
#define | __HAL_RTC_TAMPER2_DISABLE(__HANDLE__) ((__HANDLE__)->Instance->TAMPCR &= ~(RTC_TAMPCR_TAMP2E)) |
Disable the RTC Tamper2 input detection. | |
#define | __HAL_RTC_TAMPER3_ENABLE(__HANDLE__) ((__HANDLE__)->Instance->TAMPCR |= (RTC_TAMPCR_TAMP3E)) |
Enable the RTC Tamper3 input detection. | |
#define | __HAL_RTC_TAMPER3_DISABLE(__HANDLE__) ((__HANDLE__)->Instance->TAMPCR &= ~(RTC_TAMPCR_TAMP3E)) |
Disable the RTC Tamper3 input detection. | |
#define | __HAL_RTC_TAMPER_ENABLE_IT(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->TAMPCR |= (__INTERRUPT__)) |
Enable the RTC Tamper interrupt. | |
#define | __HAL_RTC_TAMPER_DISABLE_IT(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->TAMPCR &= ~(__INTERRUPT__)) |
Disable the RTC Tamper interrupt. | |
#define | __HAL_RTC_TAMPER_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__) (((((__HANDLE__)->Instance->TAMPCR) & (__INTERRUPT__)) != 0U) ? 1U : 0U) |
Check whether the specified RTC Tamper interrupt has been enabled or not. | |
#define | __HAL_RTC_TAMPER_GET_FLAG(__HANDLE__, __FLAG__) (((((__HANDLE__)->Instance->ISR) & (__FLAG__)) != 0U) ? 1U : 0U) |
Get the selected RTC Tamper's flag status. | |
#define | __HAL_RTC_TAMPER_CLEAR_FLAG(__HANDLE__, __FLAG__) ((__HANDLE__)->Instance->ISR) = (~((__FLAG__) | RTC_ISR_INIT)|((__HANDLE__)->Instance->ISR & RTC_ISR_INIT)) |
Clear the RTC Tamper's pending flags. | |
#define | __HAL_RTC_TAMPER_GET_SAMPLING_FREQ(__HANDLE__) ((uint32_t)(((__HANDLE__)->Instance->TAMPCR) & (RTC_TAMPERSAMPLINGFREQ_RTCCLK_MASK))) |
Get the frequency at which each of the Tamper inputs are sampled. | |
#define | __HAL_RTC_TAMPER_GET_SAMPLES_COUNT(__HANDLE__) ((uint32_t)(((__HANDLE__)->Instance->TAMPCR) & (RTC_TAMPERFILTER_MASK))) |
Get the number of consecutive samples at the specified level needed to activate a Tamper event. | |
#define | __HAL_RTC_TAMPER_GET_PRCHRG_DURATION(__HANDLE__) ((uint32_t)(((__HANDLE__)->Instance->TAMPCR) & (RTC_TAMPERPRECHARGEDURATION_MASK))) |
Get the pull-up resistors precharge duration. | |
#define | __HAL_RTC_TAMPER_GET_PULLUP_STATUS(__HANDLE__) ((uint32_t)(((__HANDLE__)->Instance->TAMPCR) & (RTC_TAMPER_PULLUP_MASK))) |
Get the pull-up resistors status. | |
#define | __HAL_RTC_TIMESTAMP_ENABLE(__HANDLE__) ((__HANDLE__)->Instance->CR |= (RTC_CR_TSE)) |
Enable the RTC TimeStamp peripheral. | |
#define | __HAL_RTC_TIMESTAMP_DISABLE(__HANDLE__) ((__HANDLE__)->Instance->CR &= ~(RTC_CR_TSE)) |
Disable the RTC TimeStamp peripheral. | |
#define | __HAL_RTC_TIMESTAMP_ENABLE_IT(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->CR |= (__INTERRUPT__)) |
Enable the RTC TimeStamp interrupt. | |
#define | __HAL_RTC_TIMESTAMP_DISABLE_IT(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->CR &= ~(__INTERRUPT__)) |
Disable the RTC TimeStamp interrupt. | |
#define | __HAL_RTC_TIMESTAMP_GET_IT(__HANDLE__, __INTERRUPT__) (((((__HANDLE__)->Instance->ISR) & (__INTERRUPT__)) != 0U) ? 1U : 0U) |
Check whether the specified RTC TimeStamp interrupt has occurred or not. | |
#define | __HAL_RTC_TIMESTAMP_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__) (((((__HANDLE__)->Instance->CR) & (__INTERRUPT__)) != 0U) ? 1U : 0U) |
Check whether the specified RTC Time Stamp interrupt has been enabled or not. | |
#define | __HAL_RTC_TIMESTAMP_GET_FLAG(__HANDLE__, __FLAG__) (((((__HANDLE__)->Instance->ISR) & (__FLAG__)) != 0U) ? 1U : 0U) |
Get the selected RTC TimeStamp's flag status. | |
#define | __HAL_RTC_TIMESTAMP_CLEAR_FLAG(__HANDLE__, __FLAG__) ((__HANDLE__)->Instance->ISR = (~((__FLAG__) | RTC_ISR_INIT)|((__HANDLE__)->Instance->ISR & RTC_ISR_INIT))) |
Clear the RTC Time Stamp's pending flags. | |
#define | __HAL_RTC_INTERNAL_TIMESTAMP_ENABLE(__HANDLE__) ((__HANDLE__)->Instance->CR |= (RTC_CR_ITSE)) |
Enable the RTC internal TimeStamp peripheral. | |
#define | __HAL_RTC_INTERNAL_TIMESTAMP_DISABLE(__HANDLE__) ((__HANDLE__)->Instance->CR &= ~(RTC_CR_ITSE)) |
Disable the RTC internal TimeStamp peripheral. | |
#define | __HAL_RTC_INTERNAL_TIMESTAMP_GET_FLAG(__HANDLE__, __FLAG__) (((((__HANDLE__)->Instance->ISR) & (__FLAG__)) != 0U) ? 1U : 0U) |
Get the selected RTC Internal Time Stamp's flag status. | |
#define | __HAL_RTC_INTERNAL_TIMESTAMP_CLEAR_FLAG(__HANDLE__, __FLAG__) ((__HANDLE__)->Instance->ISR = (~((__FLAG__) | RTC_ISR_INIT)|((__HANDLE__)->Instance->ISR & RTC_ISR_INIT))) |
Clear the RTC Internal Time Stamp's pending flags. | |
#define | __HAL_RTC_TAMPTS_ENABLE(__HANDLE__) ((__HANDLE__)->Instance->TAMPCR |= (RTC_TIMESTAMPONTAMPERDETECTION_MASK)) |
Enable the RTC TimeStamp on Tamper detection. | |
#define | __HAL_RTC_TAMPTS_DISABLE(__HANDLE__) ((__HANDLE__)->Instance->TAMPCR &= ~(RTC_TIMESTAMPONTAMPERDETECTION_MASK)) |
Disable the RTC TimeStamp on Tamper detection. | |
#define | __HAL_RTC_TAMPTS_GET_STATUS(__HANDLE__) ((__HANDLE__)->Instance->TAMPCR &= RTC_TIMESTAMPONTAMPERDETECTION_MASK) |
Get activation status of the RTC TimeStamp on Tamper detection. | |
#define | __HAL_RTC_CALIBRATION_OUTPUT_ENABLE(__HANDLE__) ((__HANDLE__)->Instance->CR |= (RTC_CR_COE)) |
Enable the RTC calibration output. | |
#define | __HAL_RTC_CALIBRATION_OUTPUT_DISABLE(__HANDLE__) ((__HANDLE__)->Instance->CR &= ~(RTC_CR_COE)) |
Disable the calibration output. | |
#define | __HAL_RTC_CLOCKREF_DETECTION_ENABLE(__HANDLE__) ((__HANDLE__)->Instance->CR |= (RTC_CR_REFCKON)) |
Enable the clock reference detection. | |
#define | __HAL_RTC_CLOCKREF_DETECTION_DISABLE(__HANDLE__) ((__HANDLE__)->Instance->CR &= ~(RTC_CR_REFCKON)) |
Disable the clock reference detection. | |
#define | __HAL_RTC_SHIFT_GET_FLAG(__HANDLE__, __FLAG__) (((((__HANDLE__)->Instance->ISR) & (__FLAG__)) != 0U) ? 1U : 0U) |
Get the selected RTC shift operation's flag status. | |
#define | __HAL_RTC_WAKEUPTIMER_EXTI_ENABLE_IT() (EXTI->IMR1 |= RTC_EXTI_LINE_WAKEUPTIMER_EVENT) |
Enable interrupt on the RTC WakeUp Timer associated Exti line. | |
#define | __HAL_RTC_WAKEUPTIMER_EXTI_DISABLE_IT() (EXTI->IMR1 &= ~(RTC_EXTI_LINE_WAKEUPTIMER_EVENT)) |
Disable interrupt on the RTC WakeUp Timer associated Exti line. | |
#define | __HAL_RTC_WAKEUPTIMER_EXTI_ENABLE_EVENT() (EXTI->EMR1 |= RTC_EXTI_LINE_WAKEUPTIMER_EVENT) |
Enable event on the RTC WakeUp Timer associated Exti line. | |
#define | __HAL_RTC_WAKEUPTIMER_EXTI_DISABLE_EVENT() (EXTI->EMR1 &= ~(RTC_EXTI_LINE_WAKEUPTIMER_EVENT)) |
Disable event on the RTC WakeUp Timer associated Exti line. | |
#define | __HAL_RTC_WAKEUPTIMER_EXTID3_ENABLE_EVENT() (EXTI->D3PMR1 |= RTC_EXTI_LINE_WAKEUPTIMER_EVENT) |
Enable event on the RTC WakeUp Timer associated D3 Exti line. | |
#define | __HAL_RTC_WAKEUPTIMER_EXTID3_DISABLE_EVENT() (EXTI->D3PMR1 &= ~(RTC_EXTI_LINE_WAKEUPTIMER_EVENT)) |
Disable event on the RTC WakeUp Timer associated D3 Exti line. | |
#define | __HAL_RTC_WAKEUPTIMER_EXTI_ENABLE_FALLING_EDGE() (EXTI->FTSR1 |= RTC_EXTI_LINE_WAKEUPTIMER_EVENT) |
Enable falling edge trigger on the RTC WakeUp Timer associated Exti line. | |
#define | __HAL_RTC_WAKEUPTIMER_EXTI_DISABLE_FALLING_EDGE() (EXTI->FTSR1 &= ~(RTC_EXTI_LINE_WAKEUPTIMER_EVENT)) |
Disable falling edge trigger on the RTC WakeUp Timer associated Exti line. | |
#define | __HAL_RTC_WAKEUPTIMER_EXTI_ENABLE_RISING_EDGE() (EXTI->RTSR1 |= RTC_EXTI_LINE_WAKEUPTIMER_EVENT) |
Enable rising edge trigger on the RTC WakeUp Timer associated Exti line. | |
#define | __HAL_RTC_WAKEUPTIMER_EXTI_DISABLE_RISING_EDGE() (EXTI->RTSR1 &= ~(RTC_EXTI_LINE_WAKEUPTIMER_EVENT)) |
Disable rising edge trigger on the RTC WakeUp Timer associated Exti line. | |
#define | __HAL_RTC_WAKEUPTIMER_EXTI_ENABLE_RISING_FALLING_EDGE() |
Enable rising & falling edge trigger on the RTC WakeUp Timer associated Exti line. | |
#define | __HAL_RTC_WAKEUPTIMER_EXTI_DISABLE_RISING_FALLING_EDGE() |
Disable rising & falling edge trigger on the RTC WakeUp Timer associated Exti line. This parameter can be: | |
#define | __HAL_RTC_WAKEUPTIMER_EXTI_GET_FLAG() (EXTI->PR1 & RTC_EXTI_LINE_WAKEUPTIMER_EVENT) |
Check whether the RTC WakeUp Timer associated Exti line interrupt flag is set or not. | |
#define | __HAL_RTC_WAKEUPTIMER_EXTI_CLEAR_FLAG() (EXTI->PR1 = RTC_EXTI_LINE_WAKEUPTIMER_EVENT) |
Clear the RTC WakeUp Timer associated Exti line flag. | |
#define | __HAL_RTC_WAKEUPTIMER_EXTID3_GET_FLAG() (EXTI_D3->PR1 & RTC_EXTI_LINE_WAKEUPTIMER_EVENT) |
Check whether the RTC WakeUp Timer associated D3 Exti line interrupt flag is set or not. | |
#define | __HAL_RTC_WAKEUPTIMER_EXTID3_CLEAR_FLAG() (EXTI_D3->PR1 = RTC_EXTI_LINE_WAKEUPTIMER_EVENT) |
Clear the RTC WakeUp Timer associated D3 Exti line flag. | |
#define | __HAL_RTC_WAKEUPTIMER_EXTI_GENERATE_SWIT() (EXTI->SWIER1 |= RTC_EXTI_LINE_WAKEUPTIMER_EVENT) |
Generate a Software interrupt on the RTC WakeUp Timer associated Exti line. | |
#define | __HAL_RTC_TAMPER_TIMESTAMP_EXTI_ENABLE_IT() (EXTI->IMR1 |= RTC_EXTI_LINE_TAMPER_TIMESTAMP_EVENT) |
Enable interrupt on the RTC Tamper and Timestamp associated Exti line. | |
#define | __HAL_RTC_TAMPER_TIMESTAMP_EXTI_DISABLE_IT() (EXTI->IMR1 &= ~(RTC_EXTI_LINE_TAMPER_TIMESTAMP_EVENT)) |
Disable interrupt on the RTC Tamper and Timestamp associated Exti line. | |
#define | __HAL_RTC_TAMPER_TIMESTAMP_EXTI_ENABLE_EVENT() (EXTI->EMR1 |= RTC_EXTI_LINE_TAMPER_TIMESTAMP_EVENT) |
Enable event on the RTC Tamper and Timestamp associated Exti line. | |
#define | __HAL_RTC_TAMPER_TIMESTAMP_EXTI_DISABLE_EVENT() (EXTI->EMR1 &= ~(RTC_EXTI_LINE_TAMPER_TIMESTAMP_EVENT)) |
Disable event on the RTC Tamper and Timestamp associated Exti line. | |
#define | __HAL_RTC_TAMPER_TIMESTAMP_EXTI_ENABLE_FALLING_EDGE() (EXTI->FTSR1 |= RTC_EXTI_LINE_TAMPER_TIMESTAMP_EVENT) |
Enable falling edge trigger on the RTC Tamper and Timestamp associated Exti line. | |
#define | __HAL_RTC_TAMPER_TIMESTAMP_EXTI_DISABLE_FALLING_EDGE() (EXTI->FTSR1 &= ~(RTC_EXTI_LINE_TAMPER_TIMESTAMP_EVENT)) |
Disable falling edge trigger on the RTC Tamper and Timestamp associated Exti line. | |
#define | __HAL_RTC_TAMPER_TIMESTAMP_EXTI_ENABLE_RISING_EDGE() (EXTI->RTSR1 |= RTC_EXTI_LINE_TAMPER_TIMESTAMP_EVENT) |
Enable rising edge trigger on the RTC Tamper and Timestamp associated Exti line. | |
#define | __HAL_RTC_TAMPER_TIMESTAMP_EXTI_DISABLE_RISING_EDGE() (EXTI->RTSR1 &= ~(RTC_EXTI_LINE_TAMPER_TIMESTAMP_EVENT)) |
Disable rising edge trigger on the RTC Tamper and Timestamp associated Exti line. | |
#define | __HAL_RTC_TAMPER_TIMESTAMP_EXTI_ENABLE_RISING_FALLING_EDGE() |
Enable rising & falling edge trigger on the RTC Tamper and Timestamp associated Exti line. | |
#define | __HAL_RTC_TAMPER_TIMESTAMP_EXTI_DISABLE_RISING_FALLING_EDGE() |
Disable rising & falling edge trigger on the RTC Tamper and Timestamp associated Exti line. | |
#define | __HAL_RTC_TAMPER_TIMESTAMP_EXTI_GET_FLAG() (EXTI->PR1 & RTC_EXTI_LINE_TAMPER_TIMESTAMP_EVENT) |
Check whether the RTC Tamper and Timestamp associated Exti line interrupt flag is set or not. | |
#define | __HAL_RTC_TAMPER_TIMESTAMP_EXTI_CLEAR_FLAG() (EXTI->PR1 = RTC_EXTI_LINE_TAMPER_TIMESTAMP_EVENT) |
Clear the RTC Tamper and Timestamp associated Exti line flag. | |
#define | __HAL_RTC_TAMPER_TIMESTAMP_EXTI_GENERATE_SWIT() (EXTI->SWIER1 |= RTC_EXTI_LINE_TAMPER_TIMESTAMP_EVENT) |
Generate a Software interrupt on the RTC Tamper and Timestamp associated Exti line. | |
#define | RTC_EXTI_LINE_TAMPER_TIMESTAMP_EVENT EXTI_IMR1_IM18 |
#define | RTC_EXTI_LINE_WAKEUPTIMER_EVENT EXTI_IMR1_IM19 |
#define | RTC_TAMPER_X ((uint32_t) (RTC_TAMPER_1 | RTC_TAMPER_2 | RTC_TAMPER_3)) |
#define | RTC_TAMPER_X_INTERRUPT ((uint32_t) (RTC_IT_TAMP1 | RTC_IT_TAMP2 | RTC_IT_TAMP3)) |
#define | IS_RTC_BKP(__BKP__) ((__BKP__) < BKP_REG_NUMBER) |
#define | IS_TIMESTAMP_EDGE(EDGE) |
#define | IS_RTC_TIMESTAMP_PIN(PIN) (((PIN) == RTC_TIMESTAMPPIN_DEFAULT)) |
#define | IS_RTC_WAKEUP_CLOCK(CLOCK) |
#define | IS_RTC_WAKEUP_COUNTER(COUNTER) ((COUNTER) <= RTC_WUTR_WUT) |
#define | IS_RTC_SMOOTH_CALIB_PERIOD(PERIOD) |
#define | IS_RTC_SMOOTH_CALIB_PLUS(PLUS) |
#define | IS_RTC_SMOOTH_CALIB_MINUS(VALUE) ((VALUE) <= RTC_CALR_CALM) |
#define | IS_RTC_SHIFT_ADD1S(SEL) |
#define | IS_RTC_SHIFT_SUBFS(FS) ((FS) <= RTC_SHIFTR_SUBFS) |
#define | IS_RTC_CALIB_OUTPUT(OUTPUT) |
#define | IS_RTC_TAMPER(__TAMPER__) |
#define | IS_RTC_TAMPER_INTERRUPT(__INTERRUPT__) |
#define | IS_RTC_TAMPER_TRIGGER(__TRIGGER__) |
#define | IS_RTC_TAMPER_ERASE_MODE(__MODE__) |
#define | IS_RTC_TAMPER_MASKFLAG_STATE(__STATE__) |
#define | IS_RTC_TAMPER_FILTER(__FILTER__) |
#define | IS_RTC_TAMPER_SAMPLING_FREQ(__FREQ__) |
#define | IS_RTC_TAMPER_PRECHARGE_DURATION(__DURATION__) |
#define | IS_RTC_TAMPER_PULLUP_STATE(__STATE__) |
#define | IS_RTC_TAMPER_TIMESTAMPONTAMPER_DETECTION(__DETECTION__) |
#define | IS_RTC_TAMPER_FILTER_CONFIG_CORRECT(FILTER, TRIGGER) |
#define | IS_RTC_INTERNAL_TAMPER(__INT_TAMPER__) |
HAL_StatusTypeDef | HAL_RTCEx_SetTimeStamp (RTC_HandleTypeDef *hrtc, uint32_t TimeStampEdge, uint32_t RTC_TimeStampPin) |
HAL_StatusTypeDef | HAL_RTCEx_SetTimeStamp_IT (RTC_HandleTypeDef *hrtc, uint32_t TimeStampEdge, uint32_t RTC_TimeStampPin) |
HAL_StatusTypeDef | HAL_RTCEx_DeactivateTimeStamp (RTC_HandleTypeDef *hrtc) |
HAL_StatusTypeDef | HAL_RTCEx_SetInternalTimeStamp (RTC_HandleTypeDef *hrtc) |
HAL_StatusTypeDef | HAL_RTCEx_DeactivateInternalTimeStamp (RTC_HandleTypeDef *hrtc) |
HAL_StatusTypeDef | HAL_RTCEx_GetTimeStamp (RTC_HandleTypeDef *hrtc, RTC_TimeTypeDef *sTimeStamp, RTC_DateTypeDef *sTimeStampDate, uint32_t Format) |
void | HAL_RTCEx_TamperTimeStampIRQHandler (RTC_HandleTypeDef *hrtc) |
void | HAL_RTCEx_TimeStampEventCallback (RTC_HandleTypeDef *hrtc) |
HAL_StatusTypeDef | HAL_RTCEx_PollForTimeStampEvent (RTC_HandleTypeDef *hrtc, uint32_t Timeout) |
HAL_StatusTypeDef | HAL_RTCEx_SetTamper (RTC_HandleTypeDef *hrtc, RTC_TamperTypeDef *sTamper) |
HAL_StatusTypeDef | HAL_RTCEx_SetTamper_IT (RTC_HandleTypeDef *hrtc, RTC_TamperTypeDef *sTamper) |
HAL_StatusTypeDef | HAL_RTCEx_DeactivateTamper (RTC_HandleTypeDef *hrtc, uint32_t Tamper) |
HAL_StatusTypeDef | HAL_RTCEx_PollForTamper1Event (RTC_HandleTypeDef *hrtc, uint32_t Timeout) |
HAL_StatusTypeDef | HAL_RTCEx_PollForTamper2Event (RTC_HandleTypeDef *hrtc, uint32_t Timeout) |
HAL_StatusTypeDef | HAL_RTCEx_PollForTamper3Event (RTC_HandleTypeDef *hrtc, uint32_t Timeout) |
void | HAL_RTCEx_Tamper1EventCallback (RTC_HandleTypeDef *hrtc) |
void | HAL_RTCEx_Tamper2EventCallback (RTC_HandleTypeDef *hrtc) |
void | HAL_RTCEx_Tamper3EventCallback (RTC_HandleTypeDef *hrtc) |
HAL_StatusTypeDef | HAL_RTCEx_SetWakeUpTimer (RTC_HandleTypeDef *hrtc, uint32_t WakeUpCounter, uint32_t WakeUpClock) |
HAL_StatusTypeDef | HAL_RTCEx_SetWakeUpTimer_IT (RTC_HandleTypeDef *hrtc, uint32_t WakeUpCounter, uint32_t WakeUpClock) |
HAL_StatusTypeDef | HAL_RTCEx_DeactivateWakeUpTimer (RTC_HandleTypeDef *hrtc) |
uint32_t | HAL_RTCEx_GetWakeUpTimer (RTC_HandleTypeDef *hrtc) |
void | HAL_RTCEx_WakeUpTimerIRQHandler (RTC_HandleTypeDef *hrtc) |
void | HAL_RTCEx_WakeUpTimerEventCallback (RTC_HandleTypeDef *hrtc) |
Wake Up Timer Event Callback in non blocking mode. | |
HAL_StatusTypeDef | HAL_RTCEx_PollForWakeUpTimerEvent (RTC_HandleTypeDef *hrtc, uint32_t Timeout) |
void | HAL_RTCEx_BKUPWrite (RTC_HandleTypeDef *hrtc, uint32_t BackupRegister, uint32_t Data) |
uint32_t | HAL_RTCEx_BKUPRead (RTC_HandleTypeDef *hrtc, uint32_t BackupRegister) |
HAL_StatusTypeDef | HAL_RTCEx_SetSmoothCalib (RTC_HandleTypeDef *hrtc, uint32_t SmoothCalibPeriod, uint32_t SmoothCalibPlusPulses, uint32_t SmoothCalibMinusPulsesValue) |
HAL_StatusTypeDef | HAL_RTCEx_SetSynchroShift (RTC_HandleTypeDef *hrtc, uint32_t ShiftAdd1S, uint32_t ShiftSubFS) |
HAL_StatusTypeDef | HAL_RTCEx_SetCalibrationOutPut (RTC_HandleTypeDef *hrtc, uint32_t CalibOutput) |
HAL_StatusTypeDef | HAL_RTCEx_DeactivateCalibrationOutPut (RTC_HandleTypeDef *hrtc) |
HAL_StatusTypeDef | HAL_RTCEx_SetRefClock (RTC_HandleTypeDef *hrtc) |
HAL_StatusTypeDef | HAL_RTCEx_DeactivateRefClock (RTC_HandleTypeDef *hrtc) |
HAL_StatusTypeDef | HAL_RTCEx_EnableBypassShadow (RTC_HandleTypeDef *hrtc) |
HAL_StatusTypeDef | HAL_RTCEx_DisableBypassShadow (RTC_HandleTypeDef *hrtc) |
void | HAL_RTCEx_AlarmBEventCallback (RTC_HandleTypeDef *hrtc) |
HAL_StatusTypeDef | HAL_RTCEx_PollForAlarmBEvent (RTC_HandleTypeDef *hrtc, uint32_t Timeout) |
