RTEMS 6.1-rc4
stm32h7xx_hal_pwr.c File Reference
PWR HAL module driver. This file provides firmware functions to manage the following functionalities of the Power Controller (PWR) peripheral: More...
#include "stm32h7xx_hal.h"
Author
MCD Application Team
  • Initialization and de-initialization functions.
  • Peripheral Control functions.
  • Interrupt Handling functions.
Attention
                      ##### PWR peripheral overview #####
 (#) The Power control (PWR) provides an overview of the supply architecture
     for the different power domains and of the supply configuration
     controller.
     In the H7 family, the number of power domains is different between
     device lines. This difference is due to characteristics of each device.
 (#) Domain architecture overview for the different H7 lines:
    (+) Dual core lines are STM32H745, STM32H747, STM32H755 and STM32H757.
        These devices have 3 power domains (D1, D2 and D3).
        The domain D1 contains a CPU (Cortex-M7), a Flash memory and some
        peripherals. The D2 domain contains peripherals and a CPU
        (Cortex-M4). The D3 domain contains the system control, I/O logic
        and low-power peripherals.
    (+) STM32H72x, STM32H73x, STM32H742, STM32H743, STM32H750 and STM32H753
        peripherals. The D2 domain contains peripherals. The D3 domains
        contains the system control, I/O logic and low-power peripherals.
    (+) STM32H7Axxx and STM32H7Bxxx devices have 2 power domains (CD and SRD).
        The core domain (CD) contains a CPU (Cortex-M7), a Flash
        memory and peripherals. The SmartRun domain contains the system
 (#) Every entity have low power mode as described below :
 (#) The CPU low power modes are :
    (+) CPU CRUN.
    (+) CPU CSLEEP.
    (+) CPU CSTOP.
 (#) The domain low power modes are :
    (+) DRUN.
    (+) DSTOP.
    (+) DSTANDBY.
 (#) The SYSTEM low power modes are :
    (+) RUN* : The Run* mode is entered after a POR reset and a wakeup from
               Standby. In Run* mode, the performance is limited and the
               system supply configuration shall be programmed. The system
               enters Run mode only when the ACTVOSRDY bit in PWR control
               status register 1 (PWR_CSR1) is set to 1.
    (+) RUN.
    (+) STOP.
    (+) STANDBY.
                      ##### How to use this driver #####
 (#) Power management peripheral is active by default at startup level in
     STM32h7xx lines.
 (#) Call HAL_PWR_EnableBkUpAccess() and HAL_PWR_DisableBkUpAccess() functions
     to enable/disable access to the backup domain (RTC registers, RTC backup
     data registers and backup SRAM).
 (#) Call HAL_PWR_ConfigPVD() after setting parameters to be configured (event
     mode and voltage threshold) in order to set up the Power Voltage Detector,
     then use HAL_PWR_EnablePVD() and  HAL_PWR_DisablePVD() functions to start
     and stop the PVD detection.
     (+) PVD level could be one of the following values :
           (++) 1V95
           (++) 2V1
           (++) 2V25
           (++) 2V4
           (++) 2V55
           (++) 2V7
           (++) 2V85
           (++) External voltage level
 (#) Call HAL_PWR_EnableWakeUpPin() and HAL_PWR_DisableWakeUpPin() functions
     with the right parameter to configure the wake up pin polarity (Low or
     High) and to enable and disable it.
 (#) Call HAL_PWR_EnterSLEEPMode() function to enter the current Core in SLEEP
     mode. Wake-up from SLEEP mode could be following to an event or an
     interrupt according to low power mode intrinsic request called (__WFI()
     or __WFE()).
     Please ensure to clear all CPU pending events by calling
     HAL_PWREx_ClearPendingEvent() function when trying to enter the Cortex-Mx
     in SLEEP mode with __WFE() entry.
 (#) Call HAL_PWR_EnterSTOPMode() function to enter the whole system to Stop 0
     mode for single core devices. For dual core devices, this API will enter
     the domain (containing Cortex-Mx that executing this function) in DSTOP
     mode. According to the used parameter, user could select the regulator to
     be kept actif in low power mode and wake-up event type.
     in CSTOP mode with __WFE() entry.
 (#) Call HAL_PWR_EnterSTANDBYMode() function to enter the whole system in
     STANDBY mode for single core devices. For dual core devices, this API
     will enter the domain (containing Cortex-Mx that executing this function)
     in DSTANDBY mode.
 (#) Call HAL_PWR_EnableSleepOnExit() and HAL_PWR_DisableSleepOnExit() APIs to
     enable and disable the Cortex-Mx re-entring in SLEEP mode after an
     interruption handling is over.
 (#) Call HAL_PWR_EnableSEVOnPend() and HAL_PWR_DisableSEVOnPend() functions
     to configure the Cortex-Mx to wake-up after any pending event / interrupt
     even if it's disabled or has insufficient priority to cause exception
     entry.
 (#) Call HAL_PWR_PVD_IRQHandler() function to handle the PWR PVD interrupt
     request.
   *** PWR HAL driver macros list ***
     Below the list of most used macros in PWR HAL driver.
    (+) __HAL_PWR_VOLTAGESCALING_CONFIG() : Configure the main internal
                                            regulator output voltage.
    (+) __HAL_PWR_GET_FLAG()              : Get the PWR pending flags.
    (+) __HAL_PWR_CLEAR_FLAG()            : Clear the PWR pending flags.
