RTEMS 6.1-rc4
stm32h7xx_hal_pssi.c File Reference
PSSI HAL module driver. This file provides firmware functions to manage the following functionalities of the Parallel Synchronous Slave Interface (PSSI) peripheral: More...
#include "stm32h7xx_hal.h"
Author
MCD Application Team
  • Initialization and de-initialization functions
  • IO operation functions
  • Peripheral State and Errors functions
Attention
Copyright (c) 2019 STMicroelectronics. All rights reserved.
                      ##### How to use this driver #####
  The PSSI HAL driver can be used as follows:
  (#) Declare a PSSI_HandleTypeDef handle structure, for example:
      PSSI_HandleTypeDef  hpssi;
  (#) Initialize the PSSI low level resources by implementing the @ref HAL_PSSI_MspInit() API:
      (##) Enable the PSSIx interface clock
      (##) PSSI pins configuration
          (+++) Enable the clock for the PSSI GPIOs
          (+++) Configure PSSI pins as alternate function open-drain
      (##) NVIC configuration if you need to use interrupt process
          (+++) Configure the PSSIx interrupt priority
          (+++) Enable the NVIC PSSI IRQ Channel
      (##) DMA Configuration if you need to use DMA process
          (+++) Declare  DMA_HandleTypeDef handles structure for the transmit and receive
          (+++) Enable the DMAx interface clock
          (+++) Configure the DMA handle parameters
          (+++) Configure the DMA Tx and Rx
          (+++) Associate the initialized DMA handle to the hpssi DMA Tx and Rx handle
          (+++) Configure the priority and enable the NVIC for the transfer complete interrupt on
                the DMA Tx and Rx
  (#) Configure the Communication Bus Width,  Control Signals, Input Polarity and Output Polarity
       in the hpssi Init structure.
  (#) Initialize the PSSI registers by calling the @ref HAL_PSSI_Init(), configure also the low level Hardware
      (GPIO, CLOCK, NVIC...etc) by calling the customized @ref HAL_PSSI_MspInit(&hpssi) API.
  (#) For PSSI IO operations, two operation modes are available within this driver :
  *** Polling mode IO operation ***
    (+) Transmit an amount of data by byte in blocking mode using @ref HAL_PSSI_Transmit()
    (+) Receive an amount of data by byte in blocking mode using @ref HAL_PSSI_Receive()
  *** DMA mode IO operation ***
    (+) Transmit an amount of data in non-blocking mode (DMA) using
        @ref HAL_PSSI_Transmit_DMA()
    (+) At transmission end of transfer, @ref HAL_PSSI_TxCpltCallback() is executed and user can
         add his own code by customization of function pointer @ref HAL_PSSI_TxCpltCallback()
    (+) Receive an amount of data in non-blocking mode (DMA) using
        @ref HAL_PSSI_Receive_DMA()
    (+) At reception end of transfer, @ref HAL_PSSI_RxCpltCallback() is executed and user can
         add his own code by customization of function pointer @ref HAL_PSSI_RxCpltCallback()
    (+) In case of transfer Error, @ref HAL_PSSI_ErrorCallback() function is executed and user can
         add his own code by customization of function pointer @ref HAL_PSSI_ErrorCallback()
    (+) Abort a  PSSI process communication with Interrupt using @ref HAL_PSSI_Abort_IT()
    (+) End of abort process, @ref HAL_PSSI_AbortCpltCallback() is executed and user can
         add his own code by customization of function pointer @ref HAL_PSSI_AbortCpltCallback()
   *** PSSI HAL driver macros list ***
     Below the list of most used macros in PSSI HAL driver.
    (+) @ref HAL_PSSI_ENABLE     : Enable the PSSI peripheral
    (+) @ref HAL_PSSI_DISABLE    : Disable the PSSI peripheral
    (+) @ref HAL_PSSI_GET_FLAG   : Check whether the specified PSSI flag is set or not
    (+) @ref HAL_PSSI_CLEAR_FLAG : Clear the specified PSSI pending flag
    (+) @ref HAL_PSSI_ENABLE_IT  : Enable the specified PSSI interrupt
    (+) @ref HAL_PSSI_DISABLE_IT : Disable the specified PSSI interrupt
   *** Callback registration ***
   Use Functions @ref HAL_PSSI_RegisterCallback() or @ref HAL_PSSI_RegisterAddrCallback()
   to register an interrupt callback.
   Function @ref HAL_PSSI_RegisterCallback() allows to register following callbacks:
     (+) TxCpltCallback       : callback for transmission end of transfer.
     (+) RxCpltCallback       : callback for reception end of transfer.
     (+) ErrorCallback        : callback for error detection.
     (+) AbortCpltCallback    : callback for abort completion process.
     (+) MspInitCallback      : callback for Msp Init.
     (+) MspDeInitCallback    : callback for Msp DeInit.
   This function takes as parameters the HAL peripheral handle, the Callback ID
   and a pointer to the user callback function.
   Use function @ref HAL_PSSI_UnRegisterCallback to reset a callback to the default
   weak function.
   @ref HAL_PSSI_UnRegisterCallback takes as parameters the HAL peripheral handle,
   and the Callback ID.
   This function allows to reset following callbacks:
   By default, after the @ref HAL_PSSI_Init() and when the state is @ref HAL_PSSI_STATE_RESET
   all callbacks are set to the corresponding weak functions:
   examples @ref HAL_PSSI_TxCpltCallback(), @ref HAL_PSSI_RxCpltCallback().
   Exception done for MspInit and MspDeInit functions that are
   reset to the legacy weak functions in the @ref HAL_PSSI_Init()/ @ref HAL_PSSI_DeInit() only when
   these callbacks are null (not registered beforehand).
   If MspInit or MspDeInit are not null, the @ref HAL_PSSI_Init()/ @ref HAL_PSSI_DeInit()
   keep and use the user MspInit/MspDeInit callbacks (registered beforehand) whatever the state.
   Callbacks can be registered/unregistered in @ref HAL_PSSI_STATE_READY state only.
   Exception done MspInit/MspDeInit functions that can be registered/unregistered
   in @ref HAL_PSSI_STATE_READY or @ref HAL_PSSI_STATE_RESET state,
   thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit.
   Then, the user first registers the MspInit/MspDeInit user callbacks
   using @ref HAL_PSSI_RegisterCallback() before calling @ref HAL_PSSI_DeInit()
   or @ref HAL_PSSI_Init() function.
     (@) You can refer to the PSSI HAL driver header file for more useful macros
