RTEMS 6.1-rc4
stm32h7xx_hal_pcd.c File Reference
PCD HAL module driver. This file provides firmware functions to manage the following functionalities of the USB Peripheral Controller: More...
#include "stm32h7xx_hal.h"
Author
MCD Application Team
  • Initialization and de-initialization functions
  • IO operation functions
  • Peripheral Control functions
  • Peripheral State functions
Attention
                  ##### How to use this driver #####
    The PCD HAL driver can be used as follows:
   (#) Declare a PCD_HandleTypeDef handle structure, for example:
       PCD_HandleTypeDef  hpcd;
   (#) Fill parameters of Init structure in HCD handle
   (#) Call HAL_PCD_Init() API to initialize the PCD peripheral (Core, Device core, ...)
   (#) Initialize the PCD low level resources through the HAL_PCD_MspInit() API:
       (##) Enable the PCD/USB Low Level interface clock using
            (+++) __HAL_RCC_USB_OTG_FS_CLK_ENABLE();
            (+++) __HAL_RCC_USB_OTG_HS_CLK_ENABLE(); (For High Speed Mode)
       (##) Initialize the related GPIO clocks
       (##) Configure PCD pin-out
       (##) Configure PCD NVIC interrupt
   (#)Associate the Upper USB device stack to the HAL PCD Driver:
       (##) hpcd.pData = pdev;
   (#)Enable PCD transmission and reception:
       (##) HAL_PCD_Start();
