RTEMS 6.1-rc4
stm32h7xx_hal_nor.c File Reference
NOR HAL module driver. This file provides a generic firmware to drive NOR memories mounted as external device. More...
#include "stm32h7xx_hal.h"
Author
MCD Application Team
Attention
                   ##### How to use this driver #####
    This driver is a generic layered driver which contains a set of APIs used to
    control NOR flash memories. It uses the FMC layer functions to interface
    with NOR devices. This driver is used as follows:
    (+) NOR flash memory configuration sequence using the function HAL_NOR_Init()
        with control and timing parameters for both normal and extended mode.
    (+) Read NOR flash memory manufacturer code and device IDs using the function
        HAL_NOR_Read_ID(). The read information is stored in the NOR_ID_TypeDef
        structure declared by the function caller.
    (+) Access NOR flash memory by read/write data unit operations using the functions
        HAL_NOR_Read(), HAL_NOR_Program().
    (+) Perform NOR flash erase block/chip operations using the functions
        HAL_NOR_Erase_Block() and HAL_NOR_Erase_Chip().
    (+) Read the NOR flash CFI (common flash interface) IDs using the function
        HAL_NOR_Read_CFI(). The read information is stored in the NOR_CFI_TypeDef
    (+) You can also control the NOR device by calling the control APIs HAL_NOR_WriteOperation_Enable()/
        HAL_NOR_WriteOperation_Disable() to respectively enable/disable the NOR write operation
    (+) You can monitor the NOR device HAL state by calling the function
        HAL_NOR_GetState()
   (@) This driver is a set of generic APIs which handle standard NOR flash operations.
       If a NOR flash device contains different operations and/or implementations,
       it should be implemented separately.
   *** NOR HAL driver macros list ***
     Below the list of most used macros in NOR HAL driver.
    (+) NOR_WRITE : NOR memory write data to specified address
  *** Callback registration ***
    The compilation define  USE_HAL_NOR_REGISTER_CALLBACKS when set to 1
    allows the user to configure dynamically the driver callbacks.
    Use Functions HAL_NOR_RegisterCallback() to register a user callback,
    it allows to register following callbacks:
      (+) MspInitCallback    : NOR MspInit.
      (+) MspDeInitCallback  : NOR MspDeInit.
    This function takes as parameters the HAL peripheral handle, the Callback ID
    and a pointer to the user callback function.
    Use function HAL_NOR_UnRegisterCallback() to reset a callback to the default
    weak (overridden) function. It allows to reset following callbacks:
    This function) takes as parameters the HAL peripheral handle and the Callback ID.
    By default, after the HAL_NOR_Init and if the state is HAL_NOR_STATE_RESET
    all callbacks are reset to the corresponding legacy weak (overridden) functions.
    Exception done for MspInit and MspDeInit callbacks that are respectively
    reset to the legacy weak (overridden) functions in the HAL_NOR_Init
    and  HAL_NOR_DeInit only when these callbacks are null (not registered beforehand).
    If not, MspInit or MspDeInit are not null, the HAL_NOR_Init and HAL_NOR_DeInit
    keep and use the user MspInit/MspDeInit callbacks (registered beforehand)
    Callbacks can be registered/unregistered in READY state only.
    Exception done for MspInit/MspDeInit callbacks that can be registered/unregistered
    in READY or RESET state, thus registered (user) MspInit/DeInit callbacks can be used
    during the Init/DeInit.
    In that case first register the MspInit/MspDeInit user callbacks
    using HAL_NOR_RegisterCallback before calling HAL_NOR_DeInit
    or HAL_NOR_Init function.
    When The compilation define USE_HAL_NOR_REGISTER_CALLBACKS is set to 0 or
    not defined, the callback registering feature is not available
    and weak (overridden) callbacks are used.
