RTEMS 6.1-rc4
stm32h7xx_hal_mdios.c File Reference
MDIOS HAL module driver. This file provides firmware functions to manage the following functionalities of the MDIOS Peripheral. More...
#include "stm32h7xx_hal.h"
Author
MCD Application Team
  • Initialization and de-initialization functions
  • IO operation functions
  • Peripheral Control functions
Attention
                       ##### How to use this driver #####
   The MDIOS HAL driver can be used as follow:
   (#) Declare a MDIOS_HandleTypeDef handle structure.
   (#) Initialize the MDIOS low level resources by implementing the HAL_MDIOS_MspInit() API:
       (##) Enable the MDIOS interface clock.
       (##) MDIOS pins configuration:
           (+++) Enable clocks for the MDIOS GPIOs.
           (+++) Configure the MDIOS pins as alternate function.
       (##) NVIC configuration if you need to use interrupt process:
           (+++) Configure the MDIOS interrupt priority.
           (+++) Enable the NVIC MDIOS IRQ handle.
   (#) Program the Port Address and the Preamble Check in the Init structure.
   (#) Initialize the MDIOS registers by calling the HAL_MDIOS_Init() API.
   (#) Perform direct slave read/write operations using the following APIs:
       (##) Read the value of a DINn register: HAL_MDIOS_ReadReg()
       (##) Write a value to a DOUTn register: HAL_MDIOS_WriteReg()
   (#) Get the Master read/write operations flags using the following APIs:
       (##) Bit map of DOUTn registers read by Master: HAL_MDIOS_GetReadRegAddress()
       (##) Bit map of DINn registers written by Master : HAL_MDIOS_GetWrittenRegAddress()
   (#) Clear the read/write flags using the following APIs:
       (##) Clear read flags of a set of registers: HAL_MDIOS_ClearReadRegAddress()
       (##) Clear write flags of a set of registers: HAL_MDIOS_ClearWriteRegAddress()
   (#) Enable interrupts on events using HAL_MDIOS_EnableEvents(), when called
       the MDIOS will generate an interrupt in the following cases:
       (##) a DINn register written by the Master
       (##) a DOUTn register read by the Master
       (##) an error occur
       (@) A callback is executed for each genereted interrupt, so the driver provide the following
           HAL_MDIOS_WriteCpltCallback(), HAL_MDIOS_ReadCpltCallback() and HAL_MDIOS_ErrorCallback()
       (@) HAL_MDIOS_IRQHandler() must be called from the MDIOS IRQ Handler, to handle the interrupt
           and execute the previous callbacks
   (#) Reset the MDIOS peripheral and all related resources by calling the HAL_MDIOS_DeInit() API.
       (##) HAL_MDIOS_MspDeInit() must be implemented to reset low level resources
           (GPIO, Clocks, NVIC configuration ...)
 *** Callback registration ***
 The compilation define  USE_HAL_MDIOS_REGISTER_CALLBACKS when set to 1
 allows the user to configure dynamically the driver callbacks.
 Use Function @ref HAL_MDIOS_RegisterCallback() to register an interrupt callback.
 Function @ref HAL_MDIOS_RegisterCallback() allows to register following callbacks:
   (+) WriteCpltCallback  : Write Complete Callback.
   (+) ReadCpltCallback   : Read Complete Callback.
   (+) ErrorCallback      : Error Callback.
   (+) WakeUpCallback     : Wake UP Callback
   (+) MspInitCallback    : MspInit Callback.
   (+) MspDeInitCallback  : MspDeInit Callback.
 This function takes as parameters the HAL peripheral handle, the Callback ID
 and a pointer to the user callback function.
 Use function @ref HAL_MDIOS_UnRegisterCallback() to reset a callback to the default
 weak function.
 @ref HAL_MDIOS_UnRegisterCallback takes as parameters the HAL peripheral handle,
 and the Callback ID.
 This function allows to reset following callbacks:
 By default, after the HAL_MDIOS_Init and when the state is HAL_MDIOS_STATE_RESET
 all callbacks are set to the corresponding weak functions:
 examples @ref HAL_MDIOS_WriteCpltCallback(), @ref HAL_MDIOS_ReadCpltCallback().
 Exception done for MspInit and MspDeInit functions that are
 reset to the legacy weak function in the HAL_MDIOS_Init/ @ref HAL_MDIOS_DeInit only when
 these callbacks are null (not registered beforehand).
 if not, MspInit or MspDeInit are not null, the HAL_MDIOS_Init/ @ref HAL_MDIOS_DeInit
 keep and use the user MspInit/MspDeInit callbacks (registered beforehand)
 Callbacks can be registered/unregistered in HAL_MDIOS_STATE_READY state only.
 Exception done MspInit/MspDeInit that can be registered/unregistered
 in HAL_MDIOS_STATE_READY or HAL_MDIOS_STATE_RESET state,
 thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit.
 In that case first register the MspInit/MspDeInit user callbacks
 using @ref HAL_MDIOS_RegisterCallback() before calling @ref HAL_MDIOS_DeInit
 or HAL_MDIOS_Init function.
 When The compilation define USE_HAL_MDIOS_REGISTER_CALLBACKS is set to 0 or
 not defined, the callback registration feature is not available and all callbacks
 are set to the corresponding weak functions.
