RTEMS 6.1-rc4
stm32h7xx_hal_i2c.c File Reference
I2C HAL module driver. This file provides firmware functions to manage the following functionalities of the Inter Integrated Circuit (I2C) peripheral: More...
#include "stm32h7xx_hal.h"
Author
MCD Application Team
  • Initialization and de-initialization functions
  • IO operation functions
  • Peripheral State and Errors functions
Attention
                      ##### How to use this driver #####
  The I2C HAL driver can be used as follows:
  (#) Declare a I2C_HandleTypeDef handle structure, for example:
      I2C_HandleTypeDef  hi2c;
  (#)Initialize the I2C low level resources by implementing the HAL_I2C_MspInit() API:
      (##) Enable the I2Cx interface clock
      (##) I2C pins configuration
          (+++) Enable the clock for the I2C GPIOs
          (+++) Configure I2C pins as alternate function open-drain
      (##) NVIC configuration if you need to use interrupt process
          (+++) Configure the I2Cx interrupt priority
          (+++) Enable the NVIC I2C IRQ Channel
      (##) DMA Configuration if you need to use DMA process
          (+++) Declare a DMA_HandleTypeDef handle structure for
                the transmit or receive stream or channel depends on Instance
          (+++) Enable the DMAx interface clock using
          (+++) Configure the DMA handle parameters
          (+++) Configure the DMA Tx or Rx stream or channel depends on Instance
          (+++) Associate the initialized DMA handle to the hi2c DMA Tx or Rx handle
          (+++) Configure the priority and enable the NVIC for the transfer complete interrupt on
  (#) Configure the Communication Clock Timing, Own Address1, Master Addressing mode, Dual Addressing mode,
      Own Address2, Own Address2 Mask, General call and Nostretch mode in the hi2c Init structure.
  (#) Initialize the I2C registers by calling the HAL_I2C_Init(), configures also the low level Hardware
      (GPIO, CLOCK, NVIC...etc) by calling the customized HAL_I2C_MspInit(&hi2c) API.
  (#) To check if target device is ready for communication, use the function HAL_I2C_IsDeviceReady()
  (#) For I2C IO and IO MEM operations, three operation modes are available within this driver :
  *** Polling mode IO operation ***
    (+) Transmit in master mode an amount of data in blocking mode using HAL_I2C_Master_Transmit()
    (+) Receive in master mode an amount of data in blocking mode using HAL_I2C_Master_Receive()
    (+) Transmit in slave mode an amount of data in blocking mode using HAL_I2C_Slave_Transmit()
    (+) Receive in slave mode an amount of data in blocking mode using HAL_I2C_Slave_Receive()
  *** Polling mode IO MEM operation ***
    (+) Write an amount of data in blocking mode to a specific memory address using HAL_I2C_Mem_Write()
    (+) Read an amount of data in blocking mode from a specific memory address using HAL_I2C_Mem_Read()
  *** Interrupt mode IO operation ***
    (+) Transmit in master mode an amount of data in non-blocking mode using HAL_I2C_Master_Transmit_IT()
    (+) At transmission end of transfer, HAL_I2C_MasterTxCpltCallback() is executed and users can
         add their own code by customization of function pointer HAL_I2C_MasterTxCpltCallback()
    (+) Receive in master mode an amount of data in non-blocking mode using HAL_I2C_Master_Receive_IT()
    (+) At reception end of transfer, HAL_I2C_MasterRxCpltCallback() is executed and users can
         add their own code by customization of function pointer HAL_I2C_MasterRxCpltCallback()
    (+) Transmit in slave mode an amount of data in non-blocking mode using HAL_I2C_Slave_Transmit_IT()
    (+) At transmission end of transfer, HAL_I2C_SlaveTxCpltCallback() is executed and users can
         add their own code by customization of function pointer HAL_I2C_SlaveTxCpltCallback()
    (+) Receive in slave mode an amount of data in non-blocking mode using HAL_I2C_Slave_Receive_IT()
    (+) At reception end of transfer, HAL_I2C_SlaveRxCpltCallback() is executed and users can
         add their own code by customization of function pointer HAL_I2C_SlaveRxCpltCallback()
    (+) In case of transfer Error, HAL_I2C_ErrorCallback() function is executed and users can
         add their own code by customization of function pointer HAL_I2C_ErrorCallback()
    (+) Abort a master I2C process communication with Interrupt using HAL_I2C_Master_Abort_IT()
    (+) End of abort process, HAL_I2C_AbortCpltCallback() is executed and users can
         add their own code by customization of function pointer HAL_I2C_AbortCpltCallback()
    (+) Discard a slave I2C process communication using __HAL_I2C_GENERATE_NACK() macro.
         This action will inform Master to generate a Stop condition to discard the communication.
  *** Interrupt mode or DMA mode IO sequential operation ***
    (@) These interfaces allow to manage a sequential transfer with a repeated start condition
        when a direction change during transfer
    (+) A specific option field manage the different steps of a sequential transfer
    (+) Option field values are defined through I2C_XFEROPTIONS and are listed below:
    (++) I2C_FIRST_AND_LAST_FRAME: No sequential usage, functional is same as associated interfaces in
         no sequential mode
    (++) I2C_FIRST_FRAME: Sequential usage, this option allow to manage a sequence with start condition, address
                          and data to transfer without a final stop condition
    (++) I2C_FIRST_AND_NEXT_FRAME: Sequential usage (Master only), this option allow to manage a sequence with
                          start condition, address and data to transfer without a final stop condition,
                          an then permit a call the same master sequential interface several times
                          (like HAL_I2C_Master_Seq_Transmit_IT() then HAL_I2C_Master_Seq_Transmit_IT()
                          or HAL_I2C_Master_Seq_Transmit_DMA() then HAL_I2C_Master_Seq_Transmit_DMA())
    (++) I2C_NEXT_FRAME: Sequential usage, this option allow to manage a sequence with a restart condition, address
                          and with new data to transfer if the direction change or manage only the new data to
                          transfer
                          if no direction change and without a final stop condition in both cases
    (++) I2C_LAST_FRAME: Sequential usage, this option allow to manage a sequance with a restart condition, address
                          transfer
                          if no direction change and with a final stop condition in both cases
    (++) I2C_LAST_FRAME_NO_STOP: Sequential usage (Master only), this option allow to manage a restart condition
                          after several call of the same master sequential interface several times
                          (link with option I2C_FIRST_AND_NEXT_FRAME).
                          Usage can, transfer several bytes one by one using
                            or HAL_I2C_Master_Seq_Receive_IT
                            or HAL_I2C_Master_Seq_Receive_DMA
                            with option I2C_FIRST_AND_NEXT_FRAME then I2C_NEXT_FRAME.
                           Then usage of this option I2C_LAST_FRAME_NO_STOP at the last Transmit or
                            Receive sequence permit to call the opposite interface Receive or Transmit
                            without stopping the communication and so generate a restart condition.
    (++) I2C_OTHER_FRAME: Sequential usage (Master only), this option allow to manage a restart condition after
                          each call of the same master sequential
                          interface.
                          Usage can, transfer several bytes one by one with a restart with slave address between
                          each bytes using
                            with option I2C_FIRST_FRAME then I2C_OTHER_FRAME.
                          Then usage of this option I2C_OTHER_AND_LAST_FRAME at the last frame to help automatic
                          generation of STOP condition.
    (+) Different sequential I2C interfaces are listed below:
    (++) Sequential transmit in master I2C mode an amount of data in non-blocking mode using
          HAL_I2C_Master_Seq_Transmit_IT() or using HAL_I2C_Master_Seq_Transmit_DMA()
    (+++) At transmission end of current frame transfer, HAL_I2C_MasterTxCpltCallback() is executed and
          users can add their own code by customization of function pointer HAL_I2C_MasterTxCpltCallback()
    (++) Sequential receive in master I2C mode an amount of data in non-blocking mode using
          HAL_I2C_Master_Seq_Receive_IT() or using HAL_I2C_Master_Seq_Receive_DMA()
    (+++) At reception end of current frame transfer, HAL_I2C_MasterRxCpltCallback() is executed and users can
    (++) Abort a master IT or DMA I2C process communication with Interrupt using HAL_I2C_Master_Abort_IT()
    (+++) End of abort process, HAL_I2C_AbortCpltCallback() is executed and users can
    (++) Enable/disable the Address listen mode in slave I2C mode using HAL_I2C_EnableListen_IT()
          HAL_I2C_DisableListen_IT()
    (+++) When address slave I2C match, HAL_I2C_AddrCallback() is executed and users can
         add their own code to check the Address Match Code and the transmission direction request by master
         (Write/Read).
    (+++) At Listen mode end HAL_I2C_ListenCpltCallback() is executed and users can
        add their own code by customization of function pointer HAL_I2C_ListenCpltCallback()
    (++) Sequential transmit in slave I2C mode an amount of data in non-blocking mode using
          HAL_I2C_Slave_Seq_Transmit_IT() or using HAL_I2C_Slave_Seq_Transmit_DMA()
    (+++) At transmission end of current frame transfer, HAL_I2C_SlaveTxCpltCallback() is executed and
          users can add their own code by customization of function pointer HAL_I2C_SlaveTxCpltCallback()
    (++) Sequential receive in slave I2C mode an amount of data in non-blocking mode using
          HAL_I2C_Slave_Seq_Receive_IT() or using HAL_I2C_Slave_Seq_Receive_DMA()
    (+++) At reception end of current frame transfer, HAL_I2C_SlaveRxCpltCallback() is executed and users can
    (++) In case of transfer Error, HAL_I2C_ErrorCallback() function is executed and users can
    (++) Discard a slave I2C process communication using __HAL_I2C_GENERATE_NACK() macro.
  *** Interrupt mode IO MEM operation ***
    (+) Write an amount of data in non-blocking mode with Interrupt to a specific memory address using
        HAL_I2C_Mem_Write_IT()
    (+) At Memory end of write transfer, HAL_I2C_MemTxCpltCallback() is executed and users can
         add their own code by customization of function pointer HAL_I2C_MemTxCpltCallback()
    (+) Read an amount of data in non-blocking mode with Interrupt from a specific memory address using
        HAL_I2C_Mem_Read_IT()
    (+) At Memory end of read transfer, HAL_I2C_MemRxCpltCallback() is executed and users can
         add their own code by customization of function pointer HAL_I2C_MemRxCpltCallback()
  *** DMA mode IO operation ***
    (+) Transmit in master mode an amount of data in non-blocking mode (DMA) using
        HAL_I2C_Master_Transmit_DMA()
    (+) Receive in master mode an amount of data in non-blocking mode (DMA) using
        HAL_I2C_Master_Receive_DMA()
    (+) Transmit in slave mode an amount of data in non-blocking mode (DMA) using
        HAL_I2C_Slave_Transmit_DMA()
    (+) Receive in slave mode an amount of data in non-blocking mode (DMA) using
        HAL_I2C_Slave_Receive_DMA()
  *** DMA mode IO MEM operation ***
    (+) Write an amount of data in non-blocking mode with DMA to a specific memory address using
        HAL_I2C_Mem_Write_DMA()
    (+) Read an amount of data in non-blocking mode with DMA from a specific memory address using
        HAL_I2C_Mem_Read_DMA()
   *** I2C HAL driver macros list ***
     Below the list of most used macros in I2C HAL driver.
    (+) __HAL_I2C_ENABLE: Enable the I2C peripheral
    (+) __HAL_I2C_DISABLE: Disable the I2C peripheral
    (+) __HAL_I2C_GENERATE_NACK: Generate a Non-Acknowledge I2C peripheral in Slave mode
    (+) __HAL_I2C_GET_FLAG: Check whether the specified I2C flag is set or not
    (+) __HAL_I2C_CLEAR_FLAG: Clear the specified I2C pending flag
    (+) __HAL_I2C_ENABLE_IT: Enable the specified I2C interrupt
    (+) __HAL_I2C_DISABLE_IT: Disable the specified I2C interrupt
   *** Callback registration ***
   The compilation flag USE_HAL_I2C_REGISTER_CALLBACKS when set to 1
   allows the user to configure dynamically the driver callbacks.
   Use Functions HAL_I2C_RegisterCallback() or HAL_I2C_RegisterAddrCallback()
   to register an interrupt callback.
   Function HAL_I2C_RegisterCallback() allows to register following callbacks:
     (+) MasterTxCpltCallback : callback for Master transmission end of transfer.
     (+) MasterRxCpltCallback : callback for Master reception end of transfer.
     (+) SlaveTxCpltCallback  : callback for Slave transmission end of transfer.
     (+) SlaveRxCpltCallback  : callback for Slave reception end of transfer.
     (+) ListenCpltCallback   : callback for end of listen mode.
     (+) MemTxCpltCallback    : callback for Memory transmission end of transfer.
     (+) MemRxCpltCallback    : callback for Memory reception end of transfer.
     (+) ErrorCallback        : callback for error detection.
     (+) AbortCpltCallback    : callback for abort completion process.
     (+) MspInitCallback      : callback for Msp Init.
     (+) MspDeInitCallback    : callback for Msp DeInit.
   This function takes as parameters the HAL peripheral handle, the Callback ID
   and a pointer to the user callback function.
   For specific callback AddrCallback use dedicated register callbacks : HAL_I2C_RegisterAddrCallback().
   Use function HAL_I2C_UnRegisterCallback to reset a callback to the default
   weak function.
   HAL_I2C_UnRegisterCallback takes as parameters the HAL peripheral handle,
   and the Callback ID.
   This function allows to reset following callbacks:
   For callback AddrCallback use dedicated register callbacks : HAL_I2C_UnRegisterAddrCallback().
   By default, after the HAL_I2C_Init() and when the state is HAL_I2C_STATE_RESET
   all callbacks are set to the corresponding weak functions:
   examples HAL_I2C_MasterTxCpltCallback(), HAL_I2C_MasterRxCpltCallback().
   Exception done for MspInit and MspDeInit functions that are
   reset to the legacy weak functions in the HAL_I2C_Init()/ HAL_I2C_DeInit() only when
   these callbacks are null (not registered beforehand).
   If MspInit or MspDeInit are not null, the HAL_I2C_Init()/ HAL_I2C_DeInit()
   keep and use the user MspInit/MspDeInit callbacks (registered beforehand) whatever the state.
   Callbacks can be registered/unregistered in HAL_I2C_STATE_READY state only.
   Exception done MspInit/MspDeInit functions that can be registered/unregistered
   in HAL_I2C_STATE_READY or HAL_I2C_STATE_RESET state,
   thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit.
   Then, the user first registers the MspInit/MspDeInit user callbacks
   using HAL_I2C_RegisterCallback() before calling HAL_I2C_DeInit()
   or HAL_I2C_Init() function.
   When the compilation flag USE_HAL_I2C_REGISTER_CALLBACKS is set to 0 or
   not defined, the callback registration feature is not available and all callbacks
   are set to the corresponding weak functions.
     (@) You can refer to the I2C HAL driver header file for more useful macros
