RTEMS 6.1-rc4
Extended HASH HAL module driver. This file provides firmware functions to manage the following functionalities of the HASH peripheral for SHA-224 and SHA-256 algorithms: More...
#include "stm32h7xx_hal.h"
=============================================================================== ##### HASH peripheral extended features ##### =============================================================================== [..] The SHA-224 and SHA-256 HASH and HMAC processing can be carried out exactly the same way as for SHA-1 or MD-5 algorithms. (#) Three modes are available. (##) Polling mode: processing APIs are blocking functions i.e. they process the data and wait till the digest computation is finished, e.g. HAL_HASHEx_xxx_Start() (##) Interrupt mode: processing APIs are not blocking functions i.e. they process the data under interrupt, e.g. HAL_HASHEx_xxx_Start_IT() (##) DMA mode: processing APIs are not blocking functions and the CPU is not used for data transfer i.e. the data transfer is ensured by DMA, e.g. HAL_HASHEx_xxx_Start_DMA(). Note that in DMA mode, a call to HAL_HASHEx_xxx_Finish() is then required to retrieve the digest. (#)Multi-buffer processing is possible in polling, interrupt and DMA modes. (##) In polling mode, only multi-buffer HASH processing is possible. API HAL_HASHEx_xxx_Accumulate() must be called for each input buffer, except for the last one. User must resort to HAL_HASHEx_xxx_Accumulate_End() to enter the last one and retrieve as well the computed digest. (##) In interrupt mode, API HAL_HASHEx_xxx_Accumulate_IT() must be called for each input buffer, except for the last one. User must resort to HAL_HASHEx_xxx_Accumulate_End_IT() to enter the last one and retrieve as well the computed digest. (##) In DMA mode, multi-buffer HASH and HMAC processing are possible. (+++) HASH processing: once initialization is done, MDMAT bit must be set through __HAL_HASH_SET_MDMAT() macro. From that point, each buffer can be fed to the Peripheral through HAL_HASHEx_xxx_Start_DMA() API. Before entering the last buffer, reset the MDMAT bit with __HAL_HASH_RESET_MDMAT() macro then wrap-up the HASH processing in feeding the last input buffer through the same API HAL_HASHEx_xxx_Start_DMA(). The digest can then be retrieved with a call to API HAL_HASHEx_xxx_Finish(). (+++) HMAC processing (MD-5, SHA-1, SHA-224 and SHA-256 must all resort to extended functions): after initialization, the key and the first input buffer are entered in the Peripheral with the API HAL_HMACEx_xxx_Step1_2_DMA(). This carries out HMAC step 1 and starts step 2. The following buffers are next entered with the API HAL_HMACEx_xxx_Step2_DMA(). At this point, the HMAC processing is still carrying out step 2. Then, step 2 for the last input buffer and step 3 are carried out by a single call to HAL_HMACEx_xxx_Step2_3_DMA(). The digest can finally be retrieved with a call to API HAL_HASH_xxx_Finish() for MD-5 and SHA-1, to HAL_HASHEx_xxx_Finish() for SHA-224 and SHA-256.
