RTEMS 6.1-rc4
stm32h7xx_hal_gfxmmu.c File Reference
This file provides firmware functions to manage the following functionalities of the Graphic MMU (GFXMMU) peripheral: More...
#include "stm32h7xx_hal.h"
Author
MCD Application Team
  • Initialization and De-initialization.
  • LUT configuration.
  • Force flush and/or invalidate of cache.
  • Modify physical buffer addresses.
  • Modify cache and pre-fetch parameters.
  • Error management.
Attention
                   ##### How to use this driver #####
  *** Initialization ***
    (#) As prerequisite, fill in the HAL_GFXMMU_MspInit() :
      (++) Enable GFXMMU clock interface with __HAL_RCC_GFXMMU_CLK_ENABLE().
      (++) If interrupts are used, enable and configure GFXMMU global
          interrupt with HAL_NVIC_SetPriority() and HAL_NVIC_EnableIRQ().
    (#) Configure the number of blocks per line, default value, physical
        buffer addresses, cache and pre-fetch parameters and interrupts
        using the HAL_GFXMMU_Init() function.
  *** LUT configuration ***
    (#) Use HAL_GFXMMU_DisableLutLines() to deactivate all LUT lines (or a
        range of lines).
    (#) Use HAL_GFXMMU_ConfigLut() to copy LUT from flash to look up RAM.
    (#) Use HAL_GFXMMU_ConfigLutLine() to configure one line of LUT.
  *** Force flush and/or invalidate of cache ***
    (#) Use HAL_GFXMMU_ConfigForceCache() to flush and/or invalidate cache.
  *** Modify physical buffer addresses ***
    (#) Use HAL_GFXMMU_ModifyBuffers() to modify physical buffer addresses.
  *** Modify cache and pre-fetch parameters ***
    (#) Use HAL_GFXMMU_ModifyCachePrefetch() to modify cache and pre-fetch
        parameters.
  *** Error management ***
    (#) If interrupts are used, HAL_GFXMMU_IRQHandler() will be called when
        an error occurs. This function will call HAL_GFXMMU_ErrorCallback().
        Use HAL_GFXMMU_GetError() to get the error code.
  *** De-initialization ***
    (#) As prerequisite, fill in the HAL_GFXMMU_MspDeInit() :
      (++) Disable GFXMMU clock interface with __HAL_RCC_GFXMMU_CLK_ENABLE().
      (++) If interrupts has been used, disable GFXMMU global interrupt with
           HAL_NVIC_DisableIRQ().
    (#) De-initialize GFXMMU using the HAL_GFXMMU_DeInit() function.
  *** Callback registration ***
  The compilation define USE_HAL_GFXMMU_REGISTER_CALLBACKS when set to 1
  allows the user to configure dynamically the driver callbacks.
  Use functions HAL_GFXMMU_RegisterCallback() to register a user callback.
  Function HAL_GFXMMU_RegisterCallback() allows to register following callbacks:
    (+) ErrorCallback      : GFXMMU error.
    (+) MspInitCallback    : GFXMMU MspInit.
    (+) MspDeInitCallback  : GFXMMU MspDeInit.
  This function takes as parameters the HAL peripheral handle, the callback ID
  and a pointer to the user callback function.
  Use function HAL_GFXMMU_UnRegisterCallback() to reset a callback to the default
  weak (surcharged) function.
  HAL_GFXMMU_UnRegisterCallback() takes as parameters the HAL peripheral handle,
  and the callback ID.
  This function allows to reset following callbacks:
  By default, after the HAL_GFXMMU_Init and if the state is HAL_GFXMMU_STATE_RESET
  all callbacks are reset to the corresponding legacy weak (surcharged) functions:
  examples HAL_GFXMMU_ErrorCallback().
  Exception done for MspInit and MspDeInit callbacks that are respectively
  reset to the legacy weak (surcharged) functions in the HAL_GFXMMU_Init
  and HAL_GFXMMU_DeInit only when these callbacks are null (not registered beforehand).
  If not, MspInit or MspDeInit are not null, the HAL_GFXMMU_Init and HAL_GFXMMU_DeInit
  keep and use the user MspInit/MspDeInit callbacks (registered beforehand).
  Callbacks can be registered/unregistered in READY state only.
  Exception done for MspInit/MspDeInit callbacks that can be registered/unregistered
  in READY or RESET state, thus registered (user) MspInit/DeInit callbacks can be used
  during the Init/DeInit.
  In that case first register the MspInit/MspDeInit user callbacks
  using HAL_GFXMMU_RegisterCallback before calling HAL_GFXMMU_DeInit
  or HAL_GFXMMU_Init function.
  When the compilation define USE_HAL_GFXMMU_REGISTER_CALLBACKS is set to 0 or
  not defined, the callback registering feature is not available
  and weak (surcharged) callbacks are used.
