RTEMS 6.1-rc4
Extended FLASH HAL module driver. This file provides firmware functions to manage the following functionalities of the FLASH extension peripheral: More...
#include "stm32h7xx_hal.h"
============================================================================== ##### Flash Extension features ##### ============================================================================== [..] Comparing to other previous devices, the FLASH interface for STM32H7xx devices contains the following additional features (+) Capacity up to 2 Mbyte with dual bank architecture supporting read-while-write capability (RWW) (+) Dual bank memory organization (+) PCROP protection for all banks (+) Global readout protection (RDP) (+) Write protection (+) Secure access only protection (+) Bank / register swapping (when Dual-Bank) (+) Cyclic Redundancy Check (CRC) ##### How to use this driver ##### ============================================================================== [..] This driver provides functions to configure and program the FLASH memory of all STM32H7xx devices. It includes (#) FLASH Memory Erase functions: (++) Lock and Unlock the FLASH interface using HAL_FLASH_Unlock() and HAL_FLASH_Lock() functions (++) Erase function: Sector erase, bank erase and dual-bank mass erase (++) There are two modes of erase : (+++) Polling Mode using HAL_FLASHEx_Erase() (+++) Interrupt Mode using HAL_FLASHEx_Erase_IT() (#) Option Bytes Programming functions: Use HAL_FLASHEx_OBProgram() to: (++) Set/Reset the write protection per bank (++) Set the Read protection Level (++) Set the BOR level (++) Program the user Option Bytes (++) PCROP protection configuration and control per bank (++) Secure area configuration and control per bank (++) Core Boot address configuration (++) TCM / AXI shared RAM configuration (++) CPU Frequency Boost configuration (#) FLASH Memory Lock and unlock per Bank: HAL_FLASHEx_Lock_Bank1(), HAL_FLASHEx_Unlock_Bank1(), HAL_FLASHEx_Lock_Bank2() and HAL_FLASHEx_Unlock_Bank2() functions (#) FLASH CRC computation function: Use HAL_FLASHEx_ComputeCRC() to: (++) Enable CRC feature (++) Program the desired burst size (++) Define the user Flash Area on which the CRC has be computed (++) Perform the CRC computation (++) Disable CRC feature (#) Error correction code error functions: (++) Use the HAL_FLASHEx_EnableEccCorrectionInterrupt() and HAL_FLASHEx_DisableEccCorrectionInterrupt() functions to enable and disable the FLASH ECC correction interruption. (++) Use the HAL_FLASHEx_EnableEccDetectionInterrupt() and HAL_FLASHEx_DisableEccDetectionInterrupt() functions to enable and disable the FLASH ECC Detection interruption. (++) Handle ECCD interrupt by calling HAL_FLASHEx_BusFault_IRQHandler() (++) Use HAL_FLASHEx_BusFault_IRQHandler() function called under BusFault_IRQHandler() interrupt subroutine to handle the ECCD interrupt. (++) Use HAL_FLASHEx_GetEccInfo() function to get the flash ECC fail information.
