RTEMS 6.1-rc4
stm32h7xx_hal_cryp.c File Reference
CRYP HAL module driver. This file provides firmware functions to manage the following functionalities of the Cryptography (CRYP) peripheral: More...
#include "stm32h7xx_hal.h"
Author
MCD Application Team
  • Initialization and de-initialization functions
  • AES processing functions
  • DES processing functions
  • TDES processing functions
  • DMA callback functions
  • CRYP IRQ handler management
  • Peripheral State functions
Attention
                    ##### How to use this driver #####
     The CRYP HAL driver can be used in CRYP IP as follows:
     (#)Initialize the CRYP low level resources by implementing the HAL_CRYP_MspInit():
        (##) Enable the CRYP interface clock using __HAL_RCC_CRYP_CLK_ENABLE()
        (##) In case of using interrupts (e.g. HAL_CRYP_Encrypt_IT())
            (+++) Configure the CRYP interrupt priority using HAL_NVIC_SetPriority()
            (+++) Enable the CRYP IRQ handler using HAL_NVIC_EnableIRQ()
            (+++) In CRYP IRQ handler, call HAL_CRYP_IRQHandler()
        (##) In case of using DMA to control data transfer (e.g. HAL_CRYP_Encrypt_DMA())
            (+++) Enable the DMAx interface clock using __RCC_DMAx_CLK_ENABLE()
            (+++) Configure and enable two DMA streams one for managing data transfer from
                memory to peripheral (input stream) and another stream for managing data
                transfer from peripheral to memory (output stream)
            (+++) Associate the initialized DMA handle to the CRYP DMA handle
                using  __HAL_LINKDMA()
            (+++) Configure the priority and enable the NVIC for the transfer complete
                interrupt on the two DMA Streams. The output stream should have higher
                priority than the input stream HAL_NVIC_SetPriority() and HAL_NVIC_EnableIRQ()
     (#)Initialize the CRYP according to the specified parameters :
        (##) The data type: bit swap(1-bit data), byte swap(8-bit data), half word swap(16-bit data)
           or no swap(32-bit data).
        (##) The key size: 128, 192 or 256.
        (##) The AlgoMode DES/ TDES Algorithm ECB/CBC or AES Algorithm ECB/CBC/CTR/GCM or CCM.
        (##) The initialization vector (counter). It is not used in ECB mode.
        (##) The key buffer used for encryption/decryption.
        (##) The Header used only in AES GCM and CCM Algorithm for authentication.
        (##) The HeaderSize The size of header buffer in word.
        (##) The B0 block is the first authentication block used only  in AES CCM mode.
     (#)Three processing (encryption/decryption) functions are available:
        (##) Polling mode: encryption and decryption APIs are blocking functions
             i.e. they process the data and wait till the processing is finished,
             e.g. HAL_CRYP_Encrypt & HAL_CRYP_Decrypt
        (##) Interrupt mode: encryption and decryption APIs are not blocking functions
             i.e. they process the data under interrupt,
             e.g. HAL_CRYP_Encrypt_IT & HAL_CRYP_Decrypt_IT
        (##) DMA mode: encryption and decryption APIs are not blocking functions
             i.e. the data transfer is ensured by DMA,
             e.g. HAL_CRYP_Encrypt_DMA & HAL_CRYP_Decrypt_DMA
     (#)When the processing function is called at first time after HAL_CRYP_Init()
        the CRYP peripheral is configured and processes the buffer in input.
        At second call, no need to Initialize the CRYP, user have to get current configuration via
        HAL_CRYP_GetConfig() API, then only  HAL_CRYP_SetConfig() is requested to set
        new parametres, finally user can  start encryption/decryption.
      (#)Call HAL_CRYP_DeInit() to deinitialize the CRYP peripheral.
      (#)To process a single message with consecutive calls to HAL_CRYP_Encrypt() or HAL_CRYP_Decrypt()
         without having to configure again the Key or the Initialization Vector between each API call,
         the field KeyIVConfigSkip of the initialization structure must be set to CRYP_KEYIVCONFIG_ONCE.
         Same is true for consecutive calls of HAL_CRYP_Encrypt_IT(), HAL_CRYP_Decrypt_IT(), HAL_CRYP_Encrypt_DMA()
         or HAL_CRYP_Decrypt_DMA().
     The cryptographic processor supports following standards:
     (#) The data encryption standard (DES) and Triple-DES (TDES) supported only by CRYP1 IP:
        (##)64-bit data block processing
        (##) chaining modes supported :
            (+++)  Electronic Code Book(ECB)
            (+++)  Cipher Block Chaining (CBC)
        (##) keys length supported :64-bit, 128-bit and 192-bit.
     (#) The advanced encryption standard (AES) supported  by CRYP1:
        (##)128-bit data block processing
            (+++)  Counter mode (CTR)
            (+++)  Galois/counter mode (GCM/GMAC)
            (+++)  Counter with Cipher Block Chaining-Message(CCM)
        (##) keys length Supported :
            (+++) for CRYP1 IP: 128-bit, 192-bit and 256-bit.
   [..]  This section describes the AES Galois/counter mode (GCM) supported by both CRYP1 IP:
     (#)  Algorithm supported :
        (##) Galois/counter mode (GCM)
        (##) Galois message authentication code (GMAC) :is exactly the same as
             GCM algorithm composed only by an header.
     (#)  Four phases are performed in GCM :
        (##) Init phase: IP prepares the GCM hash subkey (H) and do the IV processing
        (##) Header phase: IP processes the Additional Authenticated Data (AAD), with hash
         computation only.
        (##) Payload phase: IP processes the plaintext (P) with hash computation + keystream
         encryption + data XORing. It works in a similar way for ciphertext (C).
        (##) Final phase: IP generates the authenticated tag (T) using the last block of data.
         HAL_CRYPEx_AESGCM_GenerateAuthTAG API used in this phase to generate 4 words which correspond
         to the Tag. user should consider only part of this 4 words, if Tag length is less than 128 bits.
     (#)  structure of message construction in GCM is defined as below  :
        (##) 16 bytes Initial Counter Block (ICB)composed of IV and counter
        (##) The authenticated header A (also knows as Additional Authentication Data AAD)
         this part of the message is only authenticated, not encrypted.
        (##) The plaintext message P is both authenticated and encrypted as ciphertext.
         GCM standard specifies that ciphertext has same bit length as the plaintext.
        (##) The last block is composed of the length of A (on 64 bits) and the length of ciphertext
         (on 64 bits)
   [..]  This section describe The AES Counter with Cipher Block Chaining-Message
         Authentication Code (CCM) supported by both CRYP1 IP:
     (#)  Specific parameters for CCM  :
        (##) B0 block  : According to NIST Special Publication 800-38C,
           The first block B0 is formatted as follows, where l(m) is encoded in
           most-significant-byte first order(see below table 3)
             (+++)  Q: a bit string representation of the octet length of P (plaintext)
             (+++)  q The octet length of the binary representation of the octet length of the payload
             (+++)  A nonce (N), n The octet length of the where n+q=15.
             (+++)  Flags: most significant octet containing four flags for control information,
             (+++)  t The octet length of the MAC.
        (##) B1 block (header) : associated data length(a) concatenated with Associated Data (A)
             the associated data length expressed in bytes (a) defined as below:
           (+++)  If 0 < a < 216-28, then it is encoded as [a]16, i.e. two octets
           (+++)  If 216-28 < a < 232, then it is encoded as 0xff || 0xfe || [a]32, i.e. six octets
           (+++)  If 232 < a < 264, then it is encoded as 0xff || 0xff || [a]64, i.e. ten octets
        (##) CTRx block  : control blocks
           (+++) Generation of CTR1 from first block B0 information :
             equal to B0 with first 5 bits zeroed and most significant bits storing octet
             length of P also zeroed, then incremented by one ( see below Table 4)
           (+++) Generation of CTR0: same as CTR1 with bit[0] set to zero.
     (#)  Four phases are performed in CCM for CRYP1 IP:
         computation only.
        HAL_CRYPEx_AESCCM_GenerateAuthTAG API used in this phase to generate 4 words which correspond to the Tag.
 *** Callback registration ***
 The compilation define  USE_HAL_CRYP_REGISTER_CALLBACKS when set to 1
 allows the user to configure dynamically the driver callbacks.
 Use Functions @ref HAL_CRYP_RegisterCallback() or HAL_CRYP_RegisterXXXCallback()
 to register an interrupt callback.
 Function @ref HAL_CRYP_RegisterCallback() allows to register following callbacks:
   (+) InCpltCallback     :  Input FIFO transfer completed callback.
   (+) OutCpltCallback    : Output FIFO transfer completed callback.
   (+) ErrorCallback      : callback for error detection.
   (+) MspInitCallback    : CRYP MspInit.
   (+) MspDeInitCallback  : CRYP MspDeInit.
 This function takes as parameters the HAL peripheral handle, the Callback ID
 and a pointer to the user callback function.
 Use function @ref HAL_CRYP_UnRegisterCallback() to reset a callback to the default
 weak function.
 @ref HAL_CRYP_UnRegisterCallback() takes as parameters the HAL peripheral handle,
 and the Callback ID.
 This function allows to reset following callbacks:
 By default, after the @ref HAL_CRYP_Init() and when the state is HAL_CRYP_STATE_RESET
 all callbacks are set to the corresponding weak functions :
 examples @ref HAL_CRYP_InCpltCallback() , @ref HAL_CRYP_OutCpltCallback().
 Exception done for MspInit and MspDeInit functions that are
 reset to the legacy weak function in the @ref HAL_CRYP_Init()/ @ref HAL_CRYP_DeInit() only when
 these callbacks are null (not registered beforehand).
 if not, MspInit or MspDeInit are not null, the @ref HAL_CRYP_Init() / @ref HAL_CRYP_DeInit()
 keep and use the user MspInit/MspDeInit functions (registered beforehand)
 Callbacks can be registered/unregistered in HAL_CRYP_STATE_READY state only.
 Exception done MspInit/MspDeInit callbacks that can be registered/unregistered
 in HAL_CRYP_STATE_READY or HAL_CRYP_STATE_RESET state,
 thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit.
 In that case first register the MspInit/MspDeInit user callbacks
 using @ref HAL_CRYP_RegisterCallback() before calling @ref HAL_CRYP_DeInit()
 or @ref HAL_CRYP_Init() function.
 When The compilation define USE_HAL_CRYP_REGISTER_CALLBACKS is set to 0 or
 not defined, the callback registration feature is not available and all callbacks
 are set to the corresponding weak functions.
Table 1. Initial Counter Block (ICB) +----------------------------------------------------—+ | Initialization vector (IV) | Counter | |-------------—|-------------—|--------—|------—| 127 95 63 31 0
         Bit Number    Register           Contents
         127 ...96    CRYP_IV1R[31:0]     ICB[127:96]
         95  ...64    CRYP_IV1L[31:0]     B0[95:64]
         63 ... 32    CRYP_IV0R[31:0]     ICB[63:32]
         31 ... 0     CRYP_IV0L[31:0]     ICB[31:0], where 32-bit counter= 0x2
Table 2. GCM last block definition
    |  Bit[0]   |  Bit[32]           |  Bit[64]  | Bit[96]              |
    |   0x0     | Header length[31:0]|     0x0   | Payload length[31:0] |
Table 3. B0 block Octet Number Contents
0 Flags 1 ... 15-q Nonce N 16-q ... 15 Q
the Flags field is formatted as follows:
Bit Number   Contents
7            Reserved (always zero)
6            Adata
5 ... 3      (t-2)/2
2 ... 0      [q-1]3
Table 4. CTRx block Bit Number Register Contents
127 ...96 CRYP_IV1R[31:0] B0[127:96], where Q length bits are set to 0, except for bit 0 that is set to 1 95 ...64 CRYP_IV1L[31:0] B0[95:64] 63 ... 32 CRYP_IV0R[31:0] B0[63:32] 31 ... 0 CRYP_IV0L[31:0] B0[31:0], where flag bits set to 0
