RTEMS 6.1-rc4
stm32h7xx_hal_comp.c File Reference
COMP HAL module driver. This file provides firmware functions to manage the following functionalities of the COMP peripheral: More...
#include "stm32h7xx_hal.h"
Author
MCD Application Team
  • Initialization and de-initialization functions
  • Peripheral control functions
  • Peripheral state functions
Attention
                 ##### COMP Peripheral features #####
    The STM32H7xx device family integrates two analog comparators instances
    COMP1 and COMP2:
    (#) The COMP input minus (inverting input) and input plus (non inverting input)
        can be set to internal references or to GPIO pins
        (refer to GPIO list in reference manual).
    (#) The COMP output level is available using HAL_COMP_GetOutputLevel()
        and can be redirected to other peripherals: GPIO pins (in mode
        alternate functions for comparator), timers.
    (#) Pairs of comparators instances can be combined in window mode
        (2 consecutive instances odd and even COMP<x> and COMP<x+1>).
    (#) The comparators have interrupt capability through the EXTI controller
        with wake-up from sleep and stop modes:
        (++) COMP1 is internally connected to EXTI Line 20
        (++) COMP2 is internally connected to EXTI Line 21
        From the corresponding IRQ handler, the right interrupt source can be retrieved
        using macro __HAL_COMP_COMP1_EXTI_GET_FLAG() and __HAL_COMP_COMP2_EXTI_GET_FLAG().
          ##### How to use this driver #####
    This driver provides functions to configure and program the comparator instances of
    STM32H7xx devices.
    To use the comparator, perform the following steps:
    (#)  Initialize the COMP low level resources by implementing the HAL_COMP_MspInit():
    (++) Configure the GPIO connected to comparator inputs plus and minus in analog mode
         using HAL_GPIO_Init().
    (++) If needed, configure the GPIO connected to comparator output in alternate function mode
    (++) If required enable the COMP interrupt by configuring and enabling EXTI line in Interrupt mode and
         selecting the desired sensitivity level using HAL_GPIO_Init() function. After that enable the comparator
         interrupt vector using HAL_NVIC_EnableIRQ() function.
    (#) Configure the comparator using HAL_COMP_Init() function:
    (++) Select the input minus (inverting input)
    (++) Select the input plus (non-inverting input)
    (++) Select the hysteresis
    (++) Select the blanking source
    (++) Select the output polarity
    (++) Select the power mode
    (++) Select the window mode
    -@@- HAL_COMP_Init() calls internally __HAL_RCC_SYSCFG_CLK_ENABLE()
        to enable internal control clock of the comparators.
        However, this is a legacy strategy.
        Therefore, for compatibility anticipation, it is recommended to
        implement __HAL_RCC_SYSCFG_CLK_ENABLE() in "HAL_COMP_MspInit()".
        In STM32H7,COMP clock enable  __HAL_RCC_COMP12_CLK_ENABLE() must
        be implemented by user in "HAL_COMP_MspInit()".
    (#) Reconfiguration on-the-fly of comparator can be done by calling again
        function HAL_COMP_Init() with new input structure parameters values.
    (#) Enable the comparator using HAL_COMP_Start() or HAL_COMP_Start_IT()to be enabled
        with the interrupt through NVIC of the CPU.
    Note: HAL_COMP_Start_IT() must be called after each interrupt otherwise the interrupt
    mode will stay disabled.
    (#) Use HAL_COMP_GetOutputLevel() or HAL_COMP_TriggerCallback()
        functions to manage comparator outputs(output level or events)
    (#) Disable the comparator using HAL_COMP_Stop() or HAL_COMP_Stop_IT()
        to disable the interrupt too.
    (#) De-initialize the comparator using HAL_COMP_DeInit() function.
    (#) For safety purpose, comparator configuration can be locked using HAL_COMP_Lock() function.
        The only way to unlock the comparator is a device hardware reset.
  *** Callback registration ***
   The compilation flag USE_HAL_COMP_REGISTER_CALLBACKS, when set to 1,
   allows the user to configure dynamically the driver callbacks.
   Use Functions HAL_COMP_RegisterCallback()
   to register an interrupt callback.
   Function HAL_COMP_RegisterCallback() allows to register following callbacks:
     (+) TriggerCallback       : callback for COMP trigger.
     (+) MspInitCallback       : callback for Msp Init.
     (+) MspDeInitCallback     : callback for Msp DeInit.
   This function takes as parameters the HAL peripheral handle, the Callback ID
   and a pointer to the user callback function.
   Use function HAL_COMP_UnRegisterCallback to reset a callback to the default
   weak function.
   HAL_COMP_UnRegisterCallback takes as parameters the HAL peripheral handle,
   and the Callback ID.
   This function allows to reset following callbacks:
   By default, after the HAL_COMP_Init() and when the state is HAL_COMP_STATE_RESET
   all callbacks are set to the corresponding weak functions:
   example HAL_COMP_TriggerCallback().
   Exception done for MspInit and MspDeInit functions that are
   reset to the legacy weak functions in the HAL_COMP_Init()/ HAL_COMP_DeInit() only when
   these callbacks are null (not registered beforehand).
   If MspInit or MspDeInit are not null, the HAL_COMP_Init()/ HAL_COMP_DeInit()
   keep and use the user MspInit/MspDeInit callbacks (registered beforehand) whatever the state.
   Callbacks can be registered/unregistered in HAL_COMP_STATE_READY state only.
   Exception done MspInit/MspDeInit functions that can be registered/unregistered
   in HAL_COMP_STATE_READY or HAL_COMP_STATE_RESET state,
   thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit.
   Then, the user first registers the MspInit/MspDeInit user callbacks
   using HAL_COMP_RegisterCallback() before calling HAL_COMP_DeInit()
   or HAL_COMP_Init() function.
   When the compilation flag USE_HAL_COMP_REGISTER_CALLBACKS is set to 0 or
   not defined, the callback registration feature is not available and all callbacks
   are set to the corresponding weak functions.
Table 1. COMP inputs and output for STM32H7xx devices +------------------------------------------------------—+
COMP1 COMP2
IO1 PB0 PE9
Input plus IO2 PB2 PE11
|-------------—|-------------—|--------------------—| | | 1/4 VrefInt | Available | Available | | | 1/2 VrefInt | Available | Available | | | 3/4 VrefInt | Available | Available | | Input minus | VrefInt | Available | Available | | | DAC1 channel 1 | Available | Available | | | DAC1 channel 2 | Available | Available | | | IO1 | PB1 | PE10 |
IO2 PC4 PE7
+------------------------------------------------------—+ | Output | | PC5 (1) | PE8 (1) | | | | PE12 (1) | PE13 (1) | | | | TIM (2) | TIM (2) | +------------------------------------------------------—+ (1) GPIO must be set to alternate function for comparator (2) Comparators output to timers is set in timers instances.
