RTEMS 6.1-rc4
This file includes a standard driver for the MT25TL01G QSPI memory mounted on STM32H747I-EVAL board. More...
#include "stm32h747i_eval_qspi.h"
int32_t | BSP_QSPI_Init (uint32_t Instance, BSP_QSPI_Init_t *Init) |
Initializes the QSPI interface. | |
int32_t | BSP_QSPI_DeInit (uint32_t Instance) |
De-Initializes the QSPI interface. | |
__weak HAL_StatusTypeDef | MX_QSPI_Init (QSPI_HandleTypeDef *hQspi, MX_QSPI_Init_t *Config) |
int32_t | BSP_QSPI_Read (uint32_t Instance, uint8_t *pData, uint32_t ReadAddr, uint32_t Size) |
Reads an amount of data from the QSPI memory. | |
int32_t | BSP_QSPI_Write (uint32_t Instance, uint8_t *pData, uint32_t WriteAddr, uint32_t Size) |
Writes an amount of data to the QSPI memory. | |
int32_t | BSP_QSPI_EraseBlock (uint32_t Instance, uint32_t BlockAddress, BSP_QSPI_Erase_t BlockSize) |
Erases the specified block of the QSPI memory. MT25TL01G support 4K, 32K, 64K size block erase commands for each Die. i.e 8K, 64K, 128K at BSP level (see BSP_QSPI_Erase_t type definition) | |
int32_t | BSP_QSPI_EraseChip (uint32_t Instance) |
Erases the entire QSPI memory. | |
int32_t | BSP_QSPI_GetStatus (uint32_t Instance) |
Reads current status of the QSPI memory. If WIP != 0 then return busy. | |
int32_t | BSP_QSPI_GetInfo (uint32_t Instance, BSP_QSPI_Info_t *pInfo) |
Return the configuration of the QSPI memory. | |
int32_t | BSP_QSPI_EnableMemoryMappedMode (uint32_t Instance) |
Configure the QSPI in memory-mapped mode Only 1 Instance can running MMP mode. And it will lock system at this mode. | |
int32_t | BSP_QSPI_DisableMemoryMappedMode (uint32_t Instance) |
Exit form memory-mapped mode Only 1 Instance can running MMP mode. And it will lock system at this mode. | |
int32_t | BSP_QSPI_ReadID (uint32_t Instance, uint8_t *Id) |
Get flash ID, 3 Byte Manufacturer ID, Memory type, Memory density. | |
int32_t | BSP_QSPI_ConfigFlash (uint32_t Instance, BSP_QSPI_Interface_t Mode, BSP_QSPI_Transfer_t Rate) |
Set Flash to desired Interface mode. And this instance becomes current instance. If current instance running at MMP mode then this function isn't work. Indirect -> Indirect. | |
QSPI_HandleTypeDef | hqspi |
BSP_QSPI_Ctx_t | QSPI_Ctx [QSPI_INSTANCES_NUMBER] |
How To use this driver: ----------------------- - This driver is used to drive the MT25TL01G QSPI external memory mounted on STM32H747I-EVAL evaluation board. - This driver need a specific component driver (MT25TL01G) to be included with. Driver description: ------------------- - Initialization steps: + Initialize the QPSI external memory using the BSP_QSPI_Init() function. This function includes the MSP layer hardware resources initialization and the QSPI interface with the external memory. STR and DTR transfer rates are supported. SPI, SPI 2-IO, SPI-4IO and QPI modes are supported - QSPI memory operations + QSPI memory can be accessed with read/write operations once it is initialized. Read/write operation can be performed with AHB access using the functions BSP_QSPI_Read()/BSP_QSPI_Write(). + The function BSP_QSPI_GetInfo() returns the configuration of the QSPI memory. (see the QSPI memory data sheet) + Perform erase block operation using the function BSP_QSPI_EraseBlock() and by specifying the block address. You can perform an erase operation of the whole chip by calling the function BSP_QSPI_EraseChip(). + The function BSP_QSPI_GetStatus() returns the current status of the QSPI memory. (see the QSPI memory data sheet) + The function BSP_QSPI_EnableMemoryMappedMode enables the QSPI memory mapped mode + The function BSP_QSPI_DisableMemoryMappedMode disables the QSPI memory mapped mode + The function BSP_QSPI_ConfigFlash() allow to configure the QSPI mode and transfer rate Note: -------- Regarding the "Instance" parameter, needed for all functions, it is used to select an QSPI instance. On the STM32H747I_EVAL board, there's one instance. Then, this parameter should be 0.
Copyright (c) 2019 STMicroelectronics. All rights reserved.
