RTEMS 6.1-rc4
status-checks.h
2
12/*
13 * Copyright (c) 2008 embedded brains GmbH & Co. KG
16 * are met:
22 *
34 */
35
36#ifndef RTEMS_STATUS_CHECKS_H
37#define RTEMS_STATUS_CHECKS_H
38
39#include <rtems/bspIo.h>
40
41#ifdef __cplusplus
42extern "C" {
43#endif /* __cplusplus */
44
60#ifdef DEBUG
61 #ifndef RTEMS_DEBUG_PRINT
62 #ifdef RTEMS_STATUS_CHECKS_USE_PRINTK
63 #define RTEMS_DEBUG_PRINT( fmt, ...) \
64 printk( "%s: " fmt, __func__, ##__VA_ARGS__)
65 #else /* RTEMS_STATUS_CHECKS_USE_PRINTK */
66 #include <stdio.h>
67 #define RTEMS_DEBUG_PRINT( fmt, ...) \
68 printf( "%s: " fmt, __func__, ##__VA_ARGS__)
69 #endif /* RTEMS_STATUS_CHECKS_USE_PRINTK */
70 #endif /* RTEMS_DEBUG_PRINT */
71#else /* DEBUG */
72 #ifdef RTEMS_DEBUG_PRINT
73 #warning RTEMS_DEBUG_PRINT was defined, but DEBUG was undefined
74 #undef RTEMS_DEBUG_PRINT
75 #endif /* RTEMS_DEBUG_PRINT */
76 #define RTEMS_DEBUG_PRINT( fmt, ...)
77#endif /* DEBUG */
78
82#define RTEMS_DEBUG_OK( msg) \
83 RTEMS_DEBUG_PRINT( "Ok: %s\n", msg)
84
88#ifndef RTEMS_SYSLOG_PRINT
89 #ifdef RTEMS_STATUS_CHECKS_USE_PRINTK
90 #define RTEMS_SYSLOG_PRINT( fmt, ...) \
91 printk( fmt, ##__VA_ARGS__)
92 #else /* RTEMS_STATUS_CHECKS_USE_PRINTK */
93 #include <stdio.h>
94 #define RTEMS_SYSLOG_PRINT( fmt, ...) \
95 printf( fmt, ##__VA_ARGS__)
96 #endif /* RTEMS_STATUS_CHECKS_USE_PRINTK */
97#endif /* RTEMS_SYSLOG_PRINT */
98
102#define RTEMS_SYSLOG( fmt, ...) \
103 RTEMS_SYSLOG_PRINT( "%s: " fmt, __func__, ##__VA_ARGS__)
104
108#define RTEMS_SYSLOG_WARNING( fmt, ...) \
109 RTEMS_SYSLOG( "Warning: " fmt, ##__VA_ARGS__)
110
115#define RTEMS_SYSLOG_WARNING_SC( sc, msg) \
116 if ((rtems_status_code) (sc) != RTEMS_SUCCESSFUL) { \
117 RTEMS_SYSLOG_WARNING( "SC = %i: %s\n", (int) sc, msg); \
118 }
119
123#define RTEMS_SYSLOG_ERROR( fmt, ...) \
124 RTEMS_SYSLOG( "Error: " fmt, ##__VA_ARGS__)
125
129#define RTEMS_SYSLOG_ERROR_WITH_SC( sc, msg) \
130 RTEMS_SYSLOG_ERROR( "SC = %i: %s\n", (int) sc, msg);
131
135#define RTEMS_SYSLOG_ERROR_WITH_RV( rv, msg) \
136 RTEMS_SYSLOG_ERROR( "RV = %i: %s\n", (int) rv, msg);
137
142#define RTEMS_SYSLOG_ERROR_SC( sc, msg) \
143 if ((rtems_status_code) (sc) != RTEMS_SUCCESSFUL) { \
144 RTEMS_SYSLOG_ERROR_WITH_SC( sc, msg); \
145 }
146
151#define RTEMS_SYSLOG_ERROR_RV( rv, msg) \
152 if ((int) (rv) < 0) { \
153 RTEMS_SYSLOG_ERROR_WITH_RV( rv, msg); \
154 }
155
167#define RTEMS_CHECK_SC( sc, msg) \
168 if ((rtems_status_code) (sc) != RTEMS_SUCCESSFUL) { \
169 RTEMS_SYSLOG_ERROR_WITH_SC( sc, msg); \
170 return (rtems_status_code) sc; \
171 } else { \
172 RTEMS_DEBUG_OK( msg); \
173 }
174
179#define RTEMS_CHECK_SC_RV( sc, msg) \
180 if ((rtems_status_code) (sc) != RTEMS_SUCCESSFUL) { \
181 RTEMS_SYSLOG_ERROR_WITH_SC( sc, msg); \
182 return -((int) (sc)); \
183 } else { \
184 RTEMS_DEBUG_OK( msg); \
185 }
186
191#define RTEMS_CHECK_SC_VOID( sc, msg) \
192 if ((rtems_status_code) (sc) != RTEMS_SUCCESSFUL) { \
193 RTEMS_SYSLOG_ERROR_WITH_SC( sc, msg); \
194 return; \
195 } else { \
196 RTEMS_DEBUG_OK( msg); \
197 }
198
203#define RTEMS_CHECK_SC_TASK( sc, msg) \
204 if ((rtems_status_code) (sc) != RTEMS_SUCCESSFUL) { \
205 RTEMS_SYSLOG_ERROR_WITH_SC( sc, msg); \
206 rtems_task_exit(); \
207 return; \
208 } else { \
209 RTEMS_DEBUG_OK( msg); \
210 }
211
216#define RTEMS_CHECK_RV( rv, msg) \
217 if ((int) (rv) < 0) { \
218 RTEMS_SYSLOG_ERROR_WITH_RV( rv, msg); \
219 return (int) rv; \
220 } else { \
221 RTEMS_DEBUG_OK( msg); \
222 }
223
228#define RTEMS_CHECK_RV_SC( rv, msg) \
229 if ((int) (rv) < 0) { \
230 RTEMS_SYSLOG_ERROR_WITH_RV( rv, msg); \
231 return RTEMS_IO_ERROR; \
232 } else { \
233 RTEMS_DEBUG_OK( msg); \
234 }
235
240#define RTEMS_CHECK_RV_VOID( rv, msg) \
241 if ((int) (rv) < 0) { \
242 RTEMS_SYSLOG_ERROR_WITH_RV( rv, msg); \
243 return; \
244 } else { \
245 RTEMS_DEBUG_OK( msg); \
246 }
247
252#define RTEMS_CHECK_RV_TASK( rv, msg) \
253 if ((int) (rv) < 0) { \
254 RTEMS_SYSLOG_ERROR_WITH_RV( rv, msg); \
255 rtems_task_exit(); \
256 return; \
257 } else { \
258 RTEMS_DEBUG_OK( msg); \
259 }
260
272#define RTEMS_CLEANUP_SC( sc, label, msg) \
273 if ((rtems_status_code) (sc) != RTEMS_SUCCESSFUL) { \
274 RTEMS_SYSLOG_ERROR_WITH_SC( sc, msg); \
275 goto label; \
276 } else { \
277 RTEMS_DEBUG_OK( msg); \
278 }
279
285#define RTEMS_CLEANUP_SC_RV( sc, rv, label, msg) \
286 if ((rtems_status_code) (sc) != RTEMS_SUCCESSFUL) { \
287 RTEMS_SYSLOG_ERROR_WITH_SC( sc, msg); \
288 rv = -((int) (sc)); \
289 goto label; \
290 } else { \
291 RTEMS_DEBUG_OK( msg); \
292 }
293
298#define RTEMS_CLEANUP_RV( rv, label, msg) \
299 if ((int) (rv) < 0) { \
300 RTEMS_SYSLOG_ERROR_WITH_RV( rv, msg); \
301 goto label; \
302 } else { \
303 RTEMS_DEBUG_OK( msg); \
304 }
305
311#define RTEMS_CLEANUP_RV_SC( rv, sc, label, msg) \
312 if ((int) (rv) < 0) { \
313 RTEMS_SYSLOG_ERROR_WITH_RV( rv, msg); \
314 sc = RTEMS_IO_ERROR; \
315 goto label; \
316 } else { \
317 RTEMS_DEBUG_OK( msg); \
318 }
319
323#define RTEMS_DO_CLEANUP( label, msg) \
324 do { \
325 RTEMS_SYSLOG_ERROR( msg); \
326 goto label; \
327 } while (0)
328
333#define RTEMS_DO_CLEANUP_SC( val, sc, label, msg) \
334 do { \
335 sc = (rtems_status_code) val; \
336 RTEMS_SYSLOG_ERROR_WITH_SC( sc, msg); \
337 goto label; \
338 } while (0)
339
344#define RTEMS_DO_CLEANUP_RV( val, rv, label, msg) \
345 do { \
346 rv = (int) val; \
347 RTEMS_SYSLOG_ERROR_WITH_RV( rv, msg); \
348 goto label; \
349 } while (0)
350
355#ifdef __cplusplus
356}
357#endif /* __cplusplus */
358
359#endif /* RTEMS_STATUS_CHECKS_H */
This header file provides the kernel character input/output support API.
