RTEMS 6.1-rc4
rtl-string.h
2
11/*
12 * COPYRIGHT (c) 2012 Chris Johns <chrisj@rtems.org>
13 *
16 * are met:
22 *
34 */
35
36#if !defined (_RTEMS_RTL_STRING_H_)
37#define _RTEMS_RTL_STRING_H_
38
39#ifdef __cplusplus
40extern "C" {
41#endif /* __cplusplus */
42
49char* rtems_rtl_strdup (const char *s1);
50
51#ifdef __cplusplus
52}
53#endif /* __cplusplus */
54
55#endif
char * rtems_rtl_strdup(const char *s1)
Definition: rtl-string.c:42
