RTEMS 6.1-rc4
rtl-error.h
2
11/*
12 * COPYRIGHT (c) 2012 Chris Johns <chrisj@rtems.org>
13 *
16 * are met:
22 *
34 */
35
36#if !defined (_RTEMS_RTL_ERROR_H_)
37#define _RTEMS_RTL_ERROR_H_
38
39#ifdef __cplusplus
40extern "C" {
41#endif /* __cplusplus */
42
43#if __GNUC__
44#define RTEMS_RTL_PRINTF_ATTR __attribute__((__format__(__printf__,2,3)))
45#else
46#define RTEMS_RTL_PRINTF_ATTR
47#endif
48
58void rtems_rtl_set_error (int error, const char* format, ...) RTEMS_RTL_PRINTF_ATTR;
59
60#ifdef __cplusplus
61}
62#endif /* __cplusplus */
63
64#endif
void rtems_rtl_set_error(int error, const char *format,...) RTEMS_RTL_PRINTF_ATTR
Definition: rtl-error.c:49
Definition: mknod-pack_dev.c:254
