RTEMS 6.1-rc4
Macros | Typedefs | Functions
rbtree.h File Reference
This header file provides the Red-Black Trees API. More...
#include <rtems/score/rbtree.h>
#define RTEMS_RBTREE_INITIALIZER_EMPTY(name)    RBTREE_INITIALIZER_EMPTY(name)
 RBTree initializer for an empty rbtree with designator name.
#define RTEMS_RBTREE_DEFINE_EMPTY(name)    RBTREE_DEFINE_EMPTY(name)
 RBTree definition for an empty rbtree with designator name.
typedef RBTree_Node rtems_rbtree_node
typedef RBTree_Control rtems_rbtree_control
typedef long rtems_rbtree_compare_result
 Integer type for compare results.
typedef rtems_rbtree_compare_result(* rtems_rbtree_compare) (const RBTree_Node *first, const RBTree_Node *second)
 Compares two red-black tree nodes.
void rtems_rbtree_initialize (rtems_rbtree_control *the_rbtree, rtems_rbtree_compare compare, void *starting_address, size_t number_nodes, size_t node_size, bool is_unique)
 Initialize a RBTree header.
rtems_rbtree_nodertems_rbtree_find (const rtems_rbtree_control *the_rbtree, const rtems_rbtree_node *the_node, rtems_rbtree_compare compare, bool is_unique)
 Tries to find a node for the specified key in the tree.
rtems_rbtree_nodertems_rbtree_insert (RBTree_Control *the_rbtree, RBTree_Node *the_node, rtems_rbtree_compare compare, bool is_unique)
 Inserts the node into the red-black tree.
