RTEMS 6.1-rc4
Data Structures | Typedefs | Functions
regulator.h File Reference
This header file defines the Regulator API. More...
struct  rtems_regulator_attributes
 Attributes for Regulator Instance. More...
struct  rtems_regulator_statistics
 Statistics for Regulator Instance. More...
typedef bool(* rtems_regulator_deliverer) (void *context, void *message, size_t length)
 Regulator Delivery Function Type.
typedef struct _Regulator_Controlrtems_regulator_instance
 Regulator Instance.
rtems_status_code rtems_regulator_create (rtems_regulator_attributes *attributes, rtems_regulator_instance **regulator)
 Create a regulator.
rtems_status_code rtems_regulator_delete (rtems_regulator_instance *regulator, rtems_interval ticks)
 Delete a regulator.
rtems_status_code rtems_regulator_obtain_buffer (rtems_regulator_instance *regulator, void **buffer)
 Obtain Buffer from Regulator.
rtems_status_code rtems_regulator_release_buffer (rtems_regulator_instance *regulator, void *buffer)
 Release Previously Obtained Regulator Buffer.
rtems_status_code rtems_regulator_send (rtems_regulator_instance *regulator, void *message, size_t length)
 Send to regulator instance.
rtems_status_code rtems_regulator_get_statistics (rtems_regulator_instance *regulator, rtems_regulator_statistics *statistics)
 Obtain statistics for regulator instance.
