RTEMS
6.1-rc4
bsps
arm
tms570
include
bsp
ti_herc
reg_vim.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
/* The header file is generated by make_header.py from VIM.json */
12
/* Current script's version can be found at: */
13
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
14
15
16
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
17
18
* Czech Technical University in Prague
19
* Zikova 1903/4
20
* 166 36 Praha 6
21
* Czech Republic
22
23
* All rights reserved.
24
25
26
* modification, are permitted provided that the following conditions are met:
27
28
* 1. Redistributions of source code must retain the above copyright notice, this
29
* list of conditions and the following disclaimer.
30
* 2. Redistributions in binary form must reproduce the above copyright notice,
31
* this list of conditions and the following disclaimer in the documentation
32
* and/or other materials provided with the distribution.
33
34
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
35
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
36
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
37
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
38
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
39
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
40
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
41
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
42
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
43
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
44
45
* The views and conclusions contained in the software and documentation are those
46
* of the authors and should not be interpreted as representing official policies,
47
* either expressed or implied, of the FreeBSD Project.
48
49
#ifndef LIBBSP_ARM_TMS570_VIM
50
#define LIBBSP_ARM_TMS570_VIM
51
52
bsp/utility.h
53
54
typedef
struct
55
uint32_t PARFLG;
/*Interrupt Vector Table Parity Flag Register*/
56
uint32_t PARCTL;
/*Interrupt Vector Table Parity Control Register*/
57
uint32_t ADDERR;
/*Address Parity Error Register*/
58
uint32_t FBPARERR;
/*Fall-Back Address Parity Error Register*/
59
uint8_t reserved1 [4];
60
uint32_t IRQINDEX;
/*IRQ Index Offset Vector Register*/
61
uint32_t FIQINDEX;
/*FIQ Index Offset Vector Register*/
62
uint8_t reserved2 [8];
63
uint32_t FIRQPR[3];
/*FIQ/IRQ Program Control Register*/
64
uint8_t reserved3 [4];
65
uint32_t INTREQ[3];
/*Pending Interrupt Read Location Register*/
66
uint8_t reserved4 [4];
67
uint32_t REQENASET[3];
/*Interrupt Enable Set Register */
68
uint8_t reserved5 [4];
69
uint32_t REQENACLR[3];
/*Interrupt Enable Clear Register */
70
uint8_t reserved6 [4];
71
uint32_t WAKEENASET[3];
/*Wake-Up Enable Set Register*/
72
uint8_t reserved7 [4];
73
uint32_t WAKEENACLR[3];
/*Wake-Up Enable Clear Registers*/
74
uint8_t reserved8 [4];
75
uint32_t IRQVECREG;
/*IRQ Interrupt Vector Register*/
76
uint32_t FIQVECREG;
/*FIQ Interrupt Vector Register*/
77
uint32_t CAPEVT;
/*Capture Event Register*/
78
uint8_t reserved9 [4];
79
uint32_t CHANCTRL[24];
/*VIM Interrupt Control Register*/
80
tms570_vim_t
81
82
83
/*---------------------TMS570_VIM_PARFLG---------------------*/
84
/* field: PARFLG - The PARFLG indicates that a parity error has been found and that theInterrupt Vector Table is */
85
#define TMS570_VIM_PARFLG_PARFLG BSP_BIT32(0)
86
87
88
/*---------------------TMS570_VIM_PARCTL---------------------*/
89
/* field: TEST - This bit maps the parity bits into the Interrupt Vector Table frame to make them accessible by the */
90
#define TMS570_VIM_PARCTL_TEST BSP_BIT32(8)
91
92
/* field: PARENA - VIM parity enable. */
93
#define TMS570_VIM_PARCTL_PARENA(val) BSP_FLD32(val,0, 3)
94
#define TMS570_VIM_PARCTL_PARENA_GET(reg) BSP_FLD32GET(reg,0, 3)
95
#define TMS570_VIM_PARCTL_PARENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
96
97
98
/*---------------------TMS570_VIM_ADDERR---------------------*/
99
/* field: Interrupt_Vector_Table - Interrupt Vector Table offset. */
100
#define TMS570_VIM_ADDERR_Interrupt_Vector_Table(val) BSP_FLD32(val,9, 31)
101
#define TMS570_VIM_ADDERR_Interrupt_Vector_Table_GET(reg) BSP_FLD32GET(reg,9, 31)
102
#define TMS570_VIM_ADDERR_Interrupt_Vector_Table_SET(reg,val) BSP_FLD32SET(reg, val,9, 31)
103
104
/* field: ADDERR - Address parity error register. */
105
#define TMS570_VIM_ADDERR_ADDERR(val) BSP_FLD32(val,2, 8)
106
#define TMS570_VIM_ADDERR_ADDERR_GET(reg) BSP_FLD32GET(reg,2, 8)
107
#define TMS570_VIM_ADDERR_ADDERR_SET(reg,val) BSP_FLD32SET(reg, val,2, 8)
108
109
/* field: Word_offset - Word offset. Reads are always 0; writes have no effect. */
110
#define TMS570_VIM_ADDERR_Word_offset(val) BSP_FLD32(val,0, 1)
111
#define TMS570_VIM_ADDERR_Word_offset_GET(reg) BSP_FLD32GET(reg,0, 1)
112
#define TMS570_VIM_ADDERR_Word_offset_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
113
114
115
/*--------------------TMS570_VIM_FBPARERR--------------------*/
116
/* field: FBPARERR - Fall back address parity error. */
117
/* Whole 32 bits */
118
119
/*--------------------TMS570_VIM_IRQINDEX--------------------*/
120
/* field: IRQINDEX - IRQ index vector. */
121
#define TMS570_VIM_IRQINDEX_IRQINDEX(val) BSP_FLD32(val,0, 7)
122
#define TMS570_VIM_IRQINDEX_IRQINDEX_GET(reg) BSP_FLD32GET(reg,0, 7)
123
#define TMS570_VIM_IRQINDEX_IRQINDEX_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
124
125
126
/*--------------------TMS570_VIM_FIQINDEX--------------------*/
127
/* field: FIQINDEX - FIQ index offset vector. */
128
#define TMS570_VIM_FIQINDEX_FIQINDEX(val) BSP_FLD32(val,0, 7)
129
#define TMS570_VIM_FIQINDEX_FIQINDEX_GET(reg) BSP_FLD32GET(reg,0, 7)
130
#define TMS570_VIM_FIQINDEX_FIQINDEX_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
131
132
133
/*---------------------TMS570_VIM_FIRQPR---------------------*/
134
/* field: FIRQPRx - FIQ/IRQ program control bits. 96 bit register. 0-1 bits reserved. */
135
/* Whole 32 bits */
136
137
/*---------------------TMS570_VIM_INTREQ---------------------*/
138
/* field: INTREQx - Pending interrupt bits. 96 bit register. */
139
/* Whole 32 bits */
140
141
/*--------------------TMS570_VIM_REQENASET--------------------*/
142
/* field: REQENASETx - Request enable set bits. 96 bit register. 0-1 bits reserved. */
143
/* Whole 32 bits */
144
145
/*--------------------TMS570_VIM_REQENACLR--------------------*/
146
/* field: REQENACLRx - Request enable clear bits. 96 bit register. 0-1 bits reserved. */
147
/* Whole 32 bits */
148
149
/*-------------------TMS570_VIM_WAKEENASET-------------------*/
150
/* field: WAKEENASETx - Wake-up enable set bits. This vector determines whether the wake-up interrupt line is enabled. */
151
/* Whole 32 bits */
152
153
/*-------------------TMS570_VIM_WAKEENACLR-------------------*/
154
/* field: WAKEENACLRx - Wake-up enable clear bits. This vector determines whether the wake-up interrupt line is enabled. */
155
/* Whole 32 bits */
156
157
/*--------------------TMS570_VIM_IRQVECREG--------------------*/
158
/* field: IRQVECREG - IRQ interrupt vector register. */
159
/* Whole 32 bits */
160
161
/*--------------------TMS570_VIM_FIQVECREG--------------------*/
162
/* field: FIQVECREG - FIQ interrupt vector register. */
163
/* Whole 32 bits */
164
165
/*---------------------TMS570_VIM_CAPEVT---------------------*/
166
/* field: CAPEVTSRC1 - Capture event source 1 mapping control. */
167
#define TMS570_VIM_CAPEVT_CAPEVTSRC1(val) BSP_FLD32(val,16, 22)
168
#define TMS570_VIM_CAPEVT_CAPEVTSRC1_GET(reg) BSP_FLD32GET(reg,16, 22)
169
#define TMS570_VIM_CAPEVT_CAPEVTSRC1_SET(reg,val) BSP_FLD32SET(reg, val,16, 22)
170
171
/* field: CAPEVTSRC0 - the capture event source 0 of the RTI: */
172
#define TMS570_VIM_CAPEVT_CAPEVTSRC0(val) BSP_FLD32(val,0, 6)
173
#define TMS570_VIM_CAPEVT_CAPEVTSRC0_GET(reg) BSP_FLD32GET(reg,0, 6)
174
#define TMS570_VIM_CAPEVT_CAPEVTSRC0_SET(reg,val) BSP_FLD32SET(reg, val,0, 6)
175
176
177
/*--------------------TMS570_VIM_CHANCTRL--------------------*/
178
/* field: CHANMAPx0 - CHANMAPx 0(6-0). Interrupt CHANx 0 mapping control. */
179
#define TMS570_VIM_CHANCTRL_CHANMAPx0(val) BSP_FLD32(val,24, 30)
180
#define TMS570_VIM_CHANCTRL_CHANMAPx0_GET(reg) BSP_FLD32GET(reg,24, 30)
181
#define TMS570_VIM_CHANCTRL_CHANMAPx0_SET(reg,val) BSP_FLD32SET(reg, val,24, 30)
182
183
/* field: CHANMAPx1 - CHANMAPx 1(6-0). Interrupt CHANx 1 mapping control. */
184
#define TMS570_VIM_CHANCTRL_CHANMAPx1(val) BSP_FLD32(val,16, 22)
185
#define TMS570_VIM_CHANCTRL_CHANMAPx1_GET(reg) BSP_FLD32GET(reg,16, 22)
186
#define TMS570_VIM_CHANCTRL_CHANMAPx1_SET(reg,val) BSP_FLD32SET(reg, val,16, 22)
187
188
/* field: CHANMAPx2 - CHANMAPx 2(6-0). Interrupt CHANx 2 mapping control. */
189
#define TMS570_VIM_CHANCTRL_CHANMAPx2(val) BSP_FLD32(val,8, 14)
190
#define TMS570_VIM_CHANCTRL_CHANMAPx2_GET(reg) BSP_FLD32GET(reg,8, 14)
191
#define TMS570_VIM_CHANCTRL_CHANMAPx2_SET(reg,val) BSP_FLD32SET(reg, val,8, 14)
192
193
/* field: CHANMAPx3 - CHANMAPx 3(6-0). Interrupt CHANx 3 mapping control. */
194
#define TMS570_VIM_CHANCTRL_CHANMAPx3(val) BSP_FLD32(val,0, 6)
195
#define TMS570_VIM_CHANCTRL_CHANMAPx3_GET(reg) BSP_FLD32GET(reg,0, 6)
196
#define TMS570_VIM_CHANCTRL_CHANMAPx3_SET(reg,val) BSP_FLD32SET(reg, val,0, 6)
197
198
199
200
#endif
/* LIBBSP_ARM_TMS570_VIM */
utility.h
This header file provides utility macros for BSPs.
tms570_vim_t
Definition:
reg_vim.h:54
