RTEMS
6.1-rc4
bsps
arm
tms570
include
bsp
ti_herc
reg_stc.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
/* The header file is generated by make_header.py from STC.json */
12
/* Current script's version can be found at: */
13
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
14
15
16
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
17
18
* Czech Technical University in Prague
19
* Zikova 1903/4
20
* 166 36 Praha 6
21
* Czech Republic
22
23
* All rights reserved.
24
25
26
* modification, are permitted provided that the following conditions are met:
27
28
* 1. Redistributions of source code must retain the above copyright notice, this
29
* list of conditions and the following disclaimer.
30
* 2. Redistributions in binary form must reproduce the above copyright notice,
31
* this list of conditions and the following disclaimer in the documentation
32
* and/or other materials provided with the distribution.
33
34
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
35
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
36
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
37
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
38
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
39
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
40
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
41
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
42
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
43
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
44
45
* The views and conclusions contained in the software and documentation are those
46
* of the authors and should not be interpreted as representing official policies,
47
* either expressed or implied, of the FreeBSD Project.
48
49
#ifndef LIBBSP_ARM_TMS570_STC
50
#define LIBBSP_ARM_TMS570_STC
51
52
bsp/utility.h
53
54
typedef
struct
55
uint32_t STCGCR0;
/*STC Global Control Register 0*/
56
uint32_t STCGCR1;
/*STCGlobal Control Register 1*/
57
uint32_t STCTPR;
/*Self-Test Run Timeout Counter Preload Register*/
58
uint32_t STC_CADDR;
/*STC Current ROM Address Register*/
59
uint32_t STCCICR;
/*STC Current Interval Count Register*/
60
uint32_t STCGSTAT;
/*Self-Test Global Status Register*/
61
uint32_t STCFSTAT;
/*Self-Test Fail Status Register*/
62
uint32_t CPU1_CURMISR3;
/*CPU1 Current MISR Register 3*/
63
uint32_t CPU1_CURMISR2;
/*CPU1 Current MISR Register 2*/
64
uint32_t CPU1_CURMISR1;
/*CPU1 Current MISR Register 1*/
65
uint32_t CPU1_CURMISR0;
/*CPU1 Current MISR Register 0*/
66
uint32_t CPU2_CURMISR3;
/*CPU2 Current MISR Register 3*/
67
uint32_t CPU2_CURMISR2;
/*CPU2 Current MISR Register 2*/
68
uint32_t CPU2_CURMISR1;
/*CPU2 Current MISR Register 1*/
69
uint32_t CPU2_CURMISR0;
/*CPU2 Current MISR Register 0*/
70
uint32_t STCSCSCR;
/*Signature Compare Self-Check Register*/
71
tms570_stc_t
72
73
74
/*---------------------TMS570_STC_STCGCR0---------------------*/
75
/* field: INTCOUNT - Number of intervals of self-test run */
76
#define TMS570_STC_STCGCR0_INTCOUNT(val) BSP_FLD32(val,16, 31)
77
#define TMS570_STC_STCGCR0_INTCOUNT_GET(reg) BSP_FLD32GET(reg,16, 31)
78
#define TMS570_STC_STCGCR0_INTCOUNT_SET(reg,val) BSP_FLD32SET(reg, val,16, 31)
79
80
/* field: RS_CNT - Restart or Continue */
81
#define TMS570_STC_STCGCR0_RS_CNT BSP_BIT32(0)
82
83
84
/*---------------------TMS570_STC_STCGCR1---------------------*/
85
/* field: STC_ENA - Self-test run enable key */
86
#define TMS570_STC_STCGCR1_STC_ENA(val) BSP_FLD32(val,0, 3)
87
#define TMS570_STC_STCGCR1_STC_ENA_GET(reg) BSP_FLD32GET(reg,0, 3)
88
#define TMS570_STC_STCGCR1_STC_ENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
89
90
91
/*---------------------TMS570_STC_STCTPR---------------------*/
92
/* field: RTOD - Self-test timeout count preload */
93
/* Whole 32 bits */
94
95
/*--------------------TMS570_STC_STC_CADDR--------------------*/
96
/* field: ADDR - Current ROM Address */
97
/* Whole 32 bits */
98
99
/*---------------------TMS570_STC_STCCICR---------------------*/
100
/* field: N - Interval Number */
101
#define TMS570_STC_STCCICR_N(val) BSP_FLD32(val,0, 15)
102
#define TMS570_STC_STCCICR_N_GET(reg) BSP_FLD32GET(reg,0, 15)
103
#define TMS570_STC_STCCICR_N_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
104
105
106
/*--------------------TMS570_STC_STCGSTAT--------------------*/
107
/* field: TEST_FAIL - Test Fail */
108
#define TMS570_STC_STCGSTAT_TEST_FAIL BSP_BIT32(1)
109
110
/* field: TEST_DONE - Test Done */
111
#define TMS570_STC_STCGSTAT_TEST_DONE BSP_BIT32(0)
112
113
114
/*--------------------TMS570_STC_STCFSTAT--------------------*/
115
/* field: TO_ERR - Timeout Error */
116
#define TMS570_STC_STCFSTAT_TO_ERR BSP_BIT32(2)
117
118
/* field: CPU2_FAIL - CPU2 failure info */
119
#define TMS570_STC_STCFSTAT_CPU2_FAIL BSP_BIT32(1)
120
121
/* field: CPU1_FAIL - CPU1 failure info */
122
#define TMS570_STC_STCFSTAT_CPU1_FAIL BSP_BIT32(0)
123
124
125
/*------------------TMS570_STC_CPU1_CURMISR3------------------*/
126
/* field: MISR - MISR data from CPU1 */
127
/* Whole 32 bits */
128
129
/*------------------TMS570_STC_CPU1_CURMISR2------------------*/
130
131
/* Whole 32 bits */
132
133
/*------------------TMS570_STC_CPU1_CURMISR1------------------*/
134
135
/* Whole 32 bits */
136
137
/*------------------TMS570_STC_CPU1_CURMISR0------------------*/
138
139
/* Whole 32 bits */
140
141
/*------------------TMS570_STC_CPU2_CURMISR3------------------*/
142
/* field: MISR - MISR data from CPU2 */
143
/* Whole 32 bits */
144
145
/*------------------TMS570_STC_CPU2_CURMISR2------------------*/
146
147
/* Whole 32 bits */
148
149
/*------------------TMS570_STC_CPU2_CURMISR1------------------*/
150
151
/* Whole 32 bits */
152
153
/*------------------TMS570_STC_CPU2_CURMISR0------------------*/
154
155
/* Whole 32 bits */
156
157
/*--------------------TMS570_STC_STCSCSCR--------------------*/
158
/* field: FAULT_INS - Enable / Disable fault insertion. */
159
#define TMS570_STC_STCSCSCR_FAULT_INS BSP_BIT32(4)
160
161
/* field: SELF_CHECK_KEY - Signature compare logic self-check enable key */
162
#define TMS570_STC_STCSCSCR_SELF_CHECK_KEY(val) BSP_FLD32(val,0, 3)
163
#define TMS570_STC_STCSCSCR_SELF_CHECK_KEY_GET(reg) BSP_FLD32GET(reg,0, 3)
164
#define TMS570_STC_STCSCSCR_SELF_CHECK_KEY_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
165
166
167
168
#endif
/* LIBBSP_ARM_TMS570_STC */
utility.h
This header file provides utility macros for BSPs.
tms570_stc_t
Definition:
reg_stc.h:54
