RTEMS
6.1-rc4
bsps
arm
tms570
include
bsp
ti_herc
reg_rtp.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
/* The header file is generated by make_header.py from RTP.json */
12
/* Current script's version can be found at: */
13
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
14
15
16
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
17
18
* Czech Technical University in Prague
19
* Zikova 1903/4
20
* 166 36 Praha 6
21
* Czech Republic
22
23
* All rights reserved.
24
25
26
* modification, are permitted provided that the following conditions are met:
27
28
* 1. Redistributions of source code must retain the above copyright notice, this
29
* list of conditions and the following disclaimer.
30
* 2. Redistributions in binary form must reproduce the above copyright notice,
31
* this list of conditions and the following disclaimer in the documentation
32
* and/or other materials provided with the distribution.
33
34
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
35
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
36
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
37
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
38
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
39
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
40
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
41
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
42
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
43
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
44
45
* The views and conclusions contained in the software and documentation are those
46
* of the authors and should not be interpreted as representing official policies,
47
* either expressed or implied, of the FreeBSD Project.
48
49
#ifndef LIBBSP_ARM_TMS570_RTP
50
#define LIBBSP_ARM_TMS570_RTP
51
52
bsp/utility.h
53
54
typedef
struct
55
uint32_t GLBCTRL;
/*RTP Global Control Register*/
56
uint32_t TRENA;
/*RTP Trace Enable Register*/
57
uint32_t GSR;
/*RTP Global Status Register*/
58
uint32_t RAM1REG1;
/*RTP RAM 1 Trace Region 1 Register*/
59
uint32_t RAM1REG2;
/*RTP RAM 1 Trace Region 2 Register*/
60
uint32_t RAM2REG1;
/*RTP RAM 2 Trace Region 1 Register*/
61
uint32_t RAM2REG2;
/*RTP RAM 2 Trace Region 2 Register*/
62
uint8_t reserved1 [8];
63
uint32_t PERREG1;
/*RTP Peripheral Trace Region 1 Register*/
64
uint32_t PERREG2;
/*RTP Peripheral Trace Region 2 Register*/
65
uint32_t DDMW;
/*RTP Direct Data Mode Write Register*/
66
uint8_t reserved2 [4];
67
uint32_t PC0;
/*RTP Pin Control 0 Register*/
68
uint32_t PC1;
/*RTP Pin Control 1 Register*/
69
uint32_t PC2;
/*RTP Pin Control 2 Register*/
70
uint32_t PC3;
/*RTP Pin Control 3 Register*/
71
uint32_t PC4;
/*RTP Pin Control 4 Register*/
72
uint32_t PC5;
/*RTP Pin Control 5 Register*/
73
uint32_t PC6;
/*RTP Pin Control 6 Register*/
74
uint32_t PC7;
/*RTP Pin Control 7 Register*/
75
uint32_t PC8;
/*RTP Pin Control 8 Register*/
76
tms570_rtp_t
77
78
79
/*---------------------TMS570_RTP_GLBCTRL---------------------*/
80
/* field: TEST - By setting the bit, the FIFO RAM will be mapped into the SYSTEM Peripheral frame starting at */
81
#define TMS570_RTP_GLBCTRL_TEST BSP_BIT32(24)
82
83
/* field: PRESCALER - The prescaler divides HCLK down to the desired RTPCLK frequency. */
84
#define TMS570_RTP_GLBCTRL_PRESCALER(val) BSP_FLD32(val,16, 18)
85
#define TMS570_RTP_GLBCTRL_PRESCALER_GET(reg) BSP_FLD32GET(reg,16, 18)
86
#define TMS570_RTP_GLBCTRL_PRESCALER_SET(reg,val) BSP_FLD32SET(reg, val,16, 18)
87
88
/* field: DDM_WIDTH - Direct data mode word size width. */
89
#define TMS570_RTP_GLBCTRL_DDM_WIDTH(val) BSP_FLD32(val,12, 13)
90
#define TMS570_RTP_GLBCTRL_DDM_WIDTH_GET(reg) BSP_FLD32GET(reg,12, 13)
91
#define TMS570_RTP_GLBCTRL_DDM_WIDTH_SET(reg,val) BSP_FLD32SET(reg, val,12, 13)
92
93
/* field: DDM_RW - */
94
#define TMS570_RTP_GLBCTRL_DDM_RW BSP_BIT32(11)
95
96
/* field: TM_DDM - Trace Mode or Direct Data Mode */
97
#define TMS570_RTP_GLBCTRL_TM_DDM BSP_BIT32(10)
98
99
/* field: PW - Port width. This bit field configures the RTP to the desired port width. */
100
#define TMS570_RTP_GLBCTRL_PW(val) BSP_FLD32(val,8, 9)
101
#define TMS570_RTP_GLBCTRL_PW_GET(reg) BSP_FLD32GET(reg,8, 9)
102
#define TMS570_RTP_GLBCTRL_PW_SET(reg,val) BSP_FLD32SET(reg, val,8, 9)
103
104
/* field: RESET - This bit resets the state machine and the registers to their reset value. */
105
#define TMS570_RTP_GLBCTRL_RESET BSP_BIT32(7)
106
107
/* field: CONTCLK - Continuous RTPCLK enable. */
108
#define TMS570_RTP_GLBCTRL_CONTCLK BSP_BIT32(6)
109
110
/* field: HOVF - Halt on overflow. */
111
#define TMS570_RTP_GLBCTRL_HOVF BSP_BIT32(5)
112
113
/* field: INV_RGN - Trace inside or outside of defined trace regions. */
114
#define TMS570_RTP_GLBCTRL_INV_RGN BSP_BIT32(4)
115
116
/* field: ON_OFF - ON/Off switch. */
117
#define TMS570_RTP_GLBCTRL_ON_OFF(val) BSP_FLD32(val,0, 3)
118
#define TMS570_RTP_GLBCTRL_ON_OFF_GET(reg) BSP_FLD32GET(reg,0, 3)
119
#define TMS570_RTP_GLBCTRL_ON_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
120
121
122
/*----------------------TMS570_RTP_TRENA----------------------*/
123
/* field: ENA4 - Enable tracing for peripherals. */
124
#define TMS570_RTP_TRENA_ENA4 BSP_BIT32(24)
125
126
/* field: ENA2 - Enable tracing for RAM block 2. */
127
#define TMS570_RTP_TRENA_ENA2 BSP_BIT32(8)
128
129
/* field: ENA1 - */
130
#define TMS570_RTP_TRENA_ENA1 BSP_BIT32(0)
131
132
133
/*-----------------------TMS570_RTP_GSR-----------------------*/
134
/* field: EMPTYSER - Serializer empty. This bit determines if there is data left in the serializer. */
135
#define TMS570_RTP_GSR_EMPTYSER BSP_BIT32(12)
136
137
/* field: EMPTYPER - Peripheral FIFO empty. This bit determines if there are entries left in the FIFO. */
138
#define TMS570_RTP_GSR_EMPTYPER BSP_BIT32(11)
139
140
/* field: EMPTY2 - RAM block 2 FIFO empty. This bit determines if there are entries left in the FIFO. */
141
#define TMS570_RTP_GSR_EMPTY2 BSP_BIT32(9)
142
143
/* field: EMPTY1 - RAM block 1 FIFO empty. This bit determines if there are entries left in the FIFO. */
144
#define TMS570_RTP_GSR_EMPTY1 BSP_BIT32(8)
145
146
/* field: OVFPER - Overflow peripheral FIFO. */
147
#define TMS570_RTP_GSR_OVFPER BSP_BIT32(3)
148
149
/* field: OVF2 - Overflow RAM block 2 FIFO. */
150
#define TMS570_RTP_GSR_OVF2 BSP_BIT32(1)
151
152
/* field: OVF1 - Overflow RAM block 1 FIFO. */
153
#define TMS570_RTP_GSR_OVF1 BSP_BIT32(0)
154
155
156
/*--------------------TMS570_RTP_RAM1REGx--------------------*/
157
/* field: CPU_DMA - CPU and/or other master access. */
158
#define TMS570_RTP_RAM1REGx_CPU_DMA(val) BSP_FLD32(val,29, 30)
159
#define TMS570_RTP_RAM1REGx_CPU_DMA_GET(reg) BSP_FLD32GET(reg,29, 30)
160
#define TMS570_RTP_RAM1REGx_CPU_DMA_SET(reg,val) BSP_FLD32SET(reg, val,29, 30)
161
162
/* field: RW - Read/Write. */
163
#define TMS570_RTP_RAM1REGx_RW BSP_BIT32(28)
164
165
/* field: BLOCKSIZE - These bits define the length of the trace region. */
166
#define TMS570_RTP_RAM1REGx_BLOCKSIZE(val) BSP_FLD32(val,24, 27)
167
#define TMS570_RTP_RAM1REGx_BLOCKSIZE_GET(reg) BSP_FLD32GET(reg,24, 27)
168
#define TMS570_RTP_RAM1REGx_BLOCKSIZE_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
169
170
/* field: STARTADDR - These bits define the starting address of the address region that should be traced. */
171
#define TMS570_RTP_RAM1REGx_STARTADDR(val) BSP_FLD32(val,0, 17)
172
#define TMS570_RTP_RAM1REGx_STARTADDR_GET(reg) BSP_FLD32GET(reg,0, 17)
173
#define TMS570_RTP_RAM1REGx_STARTADDR_SET(reg,val) BSP_FLD32SET(reg, val,0, 17)
174
175
176
/*--------------------TMS570_RTP_RAM2REGx--------------------*/
177
178
#define TMS570_RTP_RAM2REGx_CPU_DMA(val) BSP_FLD32(val,29, 30)
179
#define TMS570_RTP_RAM2REGx_CPU_DMA_GET(reg) BSP_FLD32GET(reg,29, 30)
180
#define TMS570_RTP_RAM2REGx_CPU_DMA_SET(reg,val) BSP_FLD32SET(reg, val,29, 30)
181
182
183
#define TMS570_RTP_RAM2REGx_RW BSP_BIT32(28)
184
185
186
#define TMS570_RTP_RAM2REGx_BLOCKSIZE(val) BSP_FLD32(val,24, 27)
187
#define TMS570_RTP_RAM2REGx_BLOCKSIZE_GET(reg) BSP_FLD32GET(reg,24, 27)
188
#define TMS570_RTP_RAM2REGx_BLOCKSIZE_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
189
190
191
#define TMS570_RTP_RAM2REGx_STARTADDR(val) BSP_FLD32(val,0, 23)
192
#define TMS570_RTP_RAM2REGx_STARTADDR_GET(reg) BSP_FLD32GET(reg,0, 23)
193
#define TMS570_RTP_RAM2REGx_STARTADDR_SET(reg,val) BSP_FLD32SET(reg, val,0, 23)
194
195
196
/*---------------------TMS570_RTP_PERREGx---------------------*/
197
198
#define TMS570_RTP_PERREGx_CPU_DMA(val) BSP_FLD32(val,29, 30)
199
#define TMS570_RTP_PERREGx_CPU_DMA_GET(reg) BSP_FLD32GET(reg,29, 30)
200
#define TMS570_RTP_PERREGx_CPU_DMA_SET(reg,val) BSP_FLD32SET(reg, val,29, 30)
201
202
203
#define TMS570_RTP_PERREGx_RW BSP_BIT32(28)
204
205
206
#define TMS570_RTP_PERREGx_BLOCKSIZE(val) BSP_FLD32(val,24, 27)
207
#define TMS570_RTP_PERREGx_BLOCKSIZE_GET(reg) BSP_FLD32GET(reg,24, 27)
208
#define TMS570_RTP_PERREGx_BLOCKSIZE_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
209
210
211
#define TMS570_RTP_PERREGx_STARTADDR(val) BSP_FLD32(val,0, 23)
212
#define TMS570_RTP_PERREGx_STARTADDR_GET(reg) BSP_FLD32GET(reg,0, 23)
213
#define TMS570_RTP_PERREGx_STARTADDR_SET(reg,val) BSP_FLD32SET(reg, val,0, 23)
214
215
216
/*----------------------TMS570_RTP_DDMW----------------------*/
217
/* field: DATA - This register must be written to in a Direct Data Mode write operation to store the data into */
218
/* Whole 32 bits */
219
220
/*-----------------------TMS570_RTP_PCx-----------------------*/
221
/* field: ENAFUNC - Functional mode of RTPENA pin. */
222
#define TMS570_RTP_PCx_ENAFUNC BSP_BIT32(18)
223
224
/* field: CLKFUNC - Functional mode of RTPCLK pin. */
225
#define TMS570_RTP_PCx_CLKFUNC BSP_BIT32(17)
226
227
/* field: SYNCFUNC - Functional mode of RTPSYNC pin. */
228
#define TMS570_RTP_PCx_SYNCFUNC BSP_BIT32(16)
229
230
/* field: DATAFUNC - Functional mode of RTPDATA[15:0] pins. */
231
#define TMS570_RTP_PCx_DATAFUNC(val) BSP_FLD32(val,0, 15)
232
#define TMS570_RTP_PCx_DATAFUNC_GET(reg) BSP_FLD32GET(reg,0, 15)
233
#define TMS570_RTP_PCx_DATAFUNC_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
234
235
236
237
#endif
/* LIBBSP_ARM_TMS570_RTP */
utility.h
This header file provides utility macros for BSPs.
tms570_rtp_t
Definition:
reg_rtp.h:54
