49#ifndef LIBBSP_ARM_TMS570_IOMM
50#define LIBBSP_ARM_TMS570_IOMM
56 uint32_t REVISION_REG;
57 uint8_t reserved1 [28];
59 uint8_t reserved2 [20];
62 uint8_t reserved3 [160];
63 uint32_t ERR_RAW_STATUS_REG;
64 uint32_t ERR_ENABLED_STATUS_REG;
65 uint32_t ERR_ENABLE_REG;
66 uint32_t ERR_ENABLE_CLR_REG;
67 uint8_t reserved4 [4];
68 uint32_t FAULT_ADDRESS_REG;
69 uint32_t FAULT_STATUS_REG;
70 uint32_t FAULT_CLEAR_REG;
71 uint8_t reserved5 [16];
72#if TMS570_VARIANT == 4357
85#define TMS570_IOMM_PINMMRx_PINMMRx24To31(val) BSP_FLD32(val,24, 31)
86#define TMS570_IOMM_PINMMRx_PINMMRx24To31_GET(reg) BSP_FLD32GET(reg,24, 31)
87#define TMS570_IOMM_PINMMRx_PINMMRx24To31_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
90#define TMS570_IOMM_PINMMRx_PINMMRx16To23(val) BSP_FLD32(val,16, 23)
91#define TMS570_IOMM_PINMMRx_PINMMRx16To23_GET(reg) BSP_FLD32GET(reg,16, 23)
92#define TMS570_IOMM_PINMMRx_PINMMRx16To23_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
95#define TMS570_IOMM_PINMMRx_PINMMRx8To16(val) BSP_FLD32(val,8, 15)
96#define TMS570_IOMM_PINMMRx_PINMMRx8To16_GET(reg) BSP_FLD32GET(reg,8, 15)
97#define TMS570_IOMM_PINMMRx_PINMMRx8To16_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
100#define TMS570_IOMM_PINMMRx_PINMMRx0To7(val) BSP_FLD32(val,0, 7)
101#define TMS570_IOMM_PINMMRx_PINMMRx0To7_GET(reg) BSP_FLD32GET(reg,0, 7)
102#define TMS570_IOMM_PINMMRx_PINMMRx0To7_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
107#define TMS570_IOMM_REVISION_REG_REV_SCHEME(val) BSP_FLD32(val,30, 31)
108#define TMS570_IOMM_REVISION_REG_REV_SCHEME_GET(reg) BSP_FLD32GET(reg,30, 31)
109#define TMS570_IOMM_REVISION_REG_REV_SCHEME_SET(reg,val) BSP_FLD32SET(reg, val,30, 31)
112#define TMS570_IOMM_REVISION_REG_REV_MODULE(val) BSP_FLD32(val,16, 27)
113#define TMS570_IOMM_REVISION_REG_REV_MODULE_GET(reg) BSP_FLD32GET(reg,16, 27)
114#define TMS570_IOMM_REVISION_REG_REV_MODULE_SET(reg,val) BSP_FLD32SET(reg, val,16, 27)
117#define TMS570_IOMM_REVISION_REG_REV_RTL(val) BSP_FLD32(val,11, 15)
118#define TMS570_IOMM_REVISION_REG_REV_RTL_GET(reg) BSP_FLD32GET(reg,11, 15)
119#define TMS570_IOMM_REVISION_REG_REV_RTL_SET(reg,val) BSP_FLD32SET(reg, val,11, 15)
122#define TMS570_IOMM_REVISION_REG_REV_MAJOR(val) BSP_FLD32(val,8, 10)
123#define TMS570_IOMM_REVISION_REG_REV_MAJOR_GET(reg) BSP_FLD32GET(reg,8, 10)
124#define TMS570_IOMM_REVISION_REG_REV_MAJOR_SET(reg,val) BSP_FLD32SET(reg, val,8, 10)
127#define TMS570_IOMM_REVISION_REG_REV_CUSTOM(val) BSP_FLD32(val,6, 7)
128#define TMS570_IOMM_REVISION_REG_REV_CUSTOM_GET(reg) BSP_FLD32GET(reg,6, 7)
129#define TMS570_IOMM_REVISION_REG_REV_CUSTOM_SET(reg,val) BSP_FLD32SET(reg, val,6, 7)
132#define TMS570_IOMM_REVISION_REG_REV_MINOR(val) BSP_FLD32(val,0, 5)
133#define TMS570_IOMM_REVISION_REG_REV_MINOR_GET(reg) BSP_FLD32GET(reg,0, 5)
134#define TMS570_IOMM_REVISION_REG_REV_MINOR_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
139#define TMS570_IOMM_ENDIAN_REG_ENDIAN BSP_BIT32(0)
152#define TMS570_IOMM_ERR_RAW_STATUS_REG_ADDR_ERR BSP_BIT32(1)
155#define TMS570_IOMM_ERR_RAW_STATUS_REG_PROT_ERR BSP_BIT32(0)
160#define TMS570_IOMM_ERR_ENABLED_STATUS_REG_ENABLED_ADDR_ERR BSP_BIT32(1)
163#define TMS570_IOMM_ERR_ENABLED_STATUS_REG_ENABLED_PROT_ERR BSP_BIT32(0)
168#define TMS570_IOMM_ERR_ENABLE_REG_ADDR_ERR_EN BSP_BIT32(1)
171#define TMS570_IOMM_ERR_ENABLE_REG_PROT_ERR_EN BSP_BIT32(0)
176#define TMS570_IOMM_ERR_ENABLE_CLR_REG_ADDR_ERR_EN_CLR BSP_BIT32(1)
179#define TMS570_IOMM_ERR_ENABLE_CLR_REG_PROT_ERR_EN_CLR BSP_BIT32(0)
188#define TMS570_IOMM_FAULT_STATUS_REG_FAULT_ID(val) BSP_FLD32(val,24, 27)
189#define TMS570_IOMM_FAULT_STATUS_REG_FAULT_ID_GET(reg) BSP_FLD32GET(reg,24, 27)
190#define TMS570_IOMM_FAULT_STATUS_REG_FAULT_ID_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
193#define TMS570_IOMM_FAULT_STATUS_REG_FAULT_MSTID(val) BSP_FLD32(val,16, 23)
194#define TMS570_IOMM_FAULT_STATUS_REG_FAULT_MSTID_GET(reg) BSP_FLD32GET(reg,16, 23)
195#define TMS570_IOMM_FAULT_STATUS_REG_FAULT_MSTID_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
198#define TMS570_IOMM_FAULT_STATUS_REG_FAULT_PRIVID(val) BSP_FLD32(val,9, 12)
199#define TMS570_IOMM_FAULT_STATUS_REG_FAULT_PRIVID_GET(reg) BSP_FLD32GET(reg,9, 12)
200#define TMS570_IOMM_FAULT_STATUS_REG_FAULT_PRIVID_SET(reg,val) BSP_FLD32SET(reg, val,9, 12)
203#define TMS570_IOMM_FAULT_STATUS_REG_FAULT_TYPE(val) BSP_FLD32(val,0, 5)
204#define TMS570_IOMM_FAULT_STATUS_REG_FAULT_TYPE_GET(reg) BSP_FLD32GET(reg,0, 5)
205#define TMS570_IOMM_FAULT_STATUS_REG_FAULT_TYPE_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
210#define TMS570_IOMM_FAULT_CLEAR_REG_FAULT_CLEAR BSP_BIT32(0)
215#define TMS570_IOMM_PINMUX_FAULT_CLEAR BSP_BIT32(0)
This header file provides utility macros for BSPs.
Definition: reg_iomm.h:55
