49#ifndef LIBBSP_ARM_TMS570_FLASH
50#define LIBBSP_ARM_TMS570_FLASH
56 uint8_t reserved1 [4];
80 uint8_t reserved2 [4];
87 uint8_t reserved3 [64];
89 uint8_t reserved4 [452];
91 uint8_t reserved5 [24];
93 uint8_t reserved6 [16];
94 uint32_t EEPROMCONFIG;
95 uint8_t reserved7 [76];
100 uint32_t EECORERRPOS;
102 uint32_t EEUNCERRADD;
103 uint8_t reserved8 [220];
110#define TMS570_FLASH_FRDCNTL_RWAIT(val) BSP_FLD32(val,8, 11)
111#define TMS570_FLASH_FRDCNTL_RWAIT_GET(reg) BSP_FLD32GET(reg,8, 11)
112#define TMS570_FLASH_FRDCNTL_RWAIT_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
115#define TMS570_FLASH_FRDCNTL_ASWSTEN BSP_BIT32(4)
118#define TMS570_FLASH_FRDCNTL_ENPIPE BSP_BIT32(0)
123#define TMS570_FLASH_FEDACTRL1_SUSP_IGNR BSP_BIT32(24)
126#define TMS570_FLASH_FEDACTRL1_EDACMODE(val) BSP_FLD32(val,16, 19)
127#define TMS570_FLASH_FEDACTRL1_EDACMODE_GET(reg) BSP_FLD32GET(reg,16, 19)
128#define TMS570_FLASH_FEDACTRL1_EDACMODE_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
131#define TMS570_FLASH_FEDACTRL1_EOFEN BSP_BIT32(10)
134#define TMS570_FLASH_FEDACTRL1_EZFEN BSP_BIT32(9)
137#define TMS570_FLASH_FEDACTRL1_EPEN BSP_BIT32(8)
140#define TMS570_FLASH_FEDACTRL1_EDACEN(val) BSP_FLD32(val,0, 3)
141#define TMS570_FLASH_FEDACTRL1_EDACEN_GET(reg) BSP_FLD32GET(reg,0, 3)
142#define TMS570_FLASH_FEDACTRL1_EDACEN_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
147#define TMS570_FLASH_FEDACTRL2_SEC_THRESHOLD(val) BSP_FLD32(val,0, 15)
148#define TMS570_FLASH_FEDACTRL2_SEC_THRESHOLD_GET(reg) BSP_FLD32GET(reg,0, 15)
149#define TMS570_FLASH_FEDACTRL2_SEC_THRESHOLD_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
154#define TMS570_FLASH_FCORERRCNT_FERRCNT(val) BSP_FLD32(val,0, 15)
155#define TMS570_FLASH_FCORERRCNT_FERRCNT_GET(reg) BSP_FLD32GET(reg,0, 15)
156#define TMS570_FLASH_FCORERRCNT_FERRCNT_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
161#define TMS570_FLASH_FCORERRADD_COR_ERR_ADD(val) BSP_FLD32(val,3, 31)
162#define TMS570_FLASH_FCORERRADD_COR_ERR_ADD_GET(reg) BSP_FLD32GET(reg,3, 31)
163#define TMS570_FLASH_FCORERRADD_COR_ERR_ADD_SET(reg,val) BSP_FLD32SET(reg, val,3, 31)
166#define TMS570_FLASH_FCORERRADD_B_OFF(val) BSP_FLD32(val,0, 2)
167#define TMS570_FLASH_FCORERRADD_B_OFF_GET(reg) BSP_FLD32GET(reg,0, 2)
168#define TMS570_FLASH_FCORERRADD_B_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
173#define TMS570_FLASH_FCORERRPOS_BUS2 BSP_BIT32(9)
176#define TMS570_FLASH_FCORERRPOS_TYPE BSP_BIT32(8)
179#define TMS570_FLASH_FCORERRPOS_ERR_POS(val) BSP_FLD32(val,0, 7)
180#define TMS570_FLASH_FCORERRPOS_ERR_POS_GET(reg) BSP_FLD32GET(reg,0, 7)
181#define TMS570_FLASH_FCORERRPOS_ERR_POS_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
186#define TMS570_FLASH_FEDACSTATUS_Reserved(val) BSP_FLD32(val,26, 31)
187#define TMS570_FLASH_FEDACSTATUS_Reserved_GET(reg) BSP_FLD32GET(reg,26, 31)
188#define TMS570_FLASH_FEDACSTATUS_Reserved_SET(reg,val) BSP_FLD32SET(reg, val,26, 31)
191#define TMS570_FLASH_FEDACSTATUS_FSM_DONE BSP_BIT32(24)
194#define TMS570_FLASH_FEDACSTATUS_COMB2_MAL_G BSP_BIT32(19)
197#define TMS570_FLASH_FEDACSTATUS_ECC_B2_MAL_ BSP_BIT32(18)
200#define TMS570_FLASH_FEDACSTATUS_B2_UNC_ERR BSP_BIT32(17)
203#define TMS570_FLASH_FEDACSTATUS_B2_COR_ERR BSP_BIT32(16)
206#define TMS570_FLASH_FEDACSTATUS_D_UNC_ERR BSP_BIT32(12)
209#define TMS570_FLASH_FEDACSTATUS_ADD_TAG_ERR BSP_BIT32(11)
212#define TMS570_FLASH_FEDACSTATUS_ADD_PAR_ERR BSP_BIT32(10)
215#define TMS570_FLASH_FEDACSTATUS_B1_UNC_ERR BSP_BIT32(8)
218#define TMS570_FLASH_FEDACSTATUS_D_CORR_ERR BSP_BIT32(3)
221#define TMS570_FLASH_FEDACSTATUS_ERR_ONE_FLG BSP_BIT32(2)
224#define TMS570_FLASH_FEDACSTATUS_ERR_ZERO__FLG BSP_BIT32(1)
227#define TMS570_FLASH_FEDACSTATUS_ERR_PRF_FLG BSP_BIT32(0)
232#define TMS570_FLASH_FUNCERRADD_UNC_ERR_ADD(val) BSP_FLD32(val,3, 31)
233#define TMS570_FLASH_FUNCERRADD_UNC_ERR_ADD_GET(reg) BSP_FLD32GET(reg,3, 31)
234#define TMS570_FLASH_FUNCERRADD_UNC_ERR_ADD_SET(reg,val) BSP_FLD32SET(reg, val,3, 31)
237#define TMS570_FLASH_FUNCERRADD_B_OFF(val) BSP_FLD32(val,0, 2)
238#define TMS570_FLASH_FUNCERRADD_B_OFF_GET(reg) BSP_FLD32GET(reg,0, 2)
239#define TMS570_FLASH_FUNCERRADD_B_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
244#define TMS570_FLASH_FEDACSDIS_BankID1_Inverse(val) BSP_FLD32(val,29, 31)
245#define TMS570_FLASH_FEDACSDIS_BankID1_Inverse_GET(reg) BSP_FLD32GET(reg,29, 31)
246#define TMS570_FLASH_FEDACSDIS_BankID1_Inverse_SET(reg,val) BSP_FLD32SET(reg, val,29, 31)
249#define TMS570_FLASH_FEDACSDIS_SectorID1_inverse(val) BSP_FLD32(val,24, 27)
250#define TMS570_FLASH_FEDACSDIS_SectorID1_inverse_GET(reg) BSP_FLD32GET(reg,24, 27)
251#define TMS570_FLASH_FEDACSDIS_SectorID1_inverse_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
254#define TMS570_FLASH_FEDACSDIS_BankID1(val) BSP_FLD32(val,21, 23)
255#define TMS570_FLASH_FEDACSDIS_BankID1_GET(reg) BSP_FLD32GET(reg,21, 23)
256#define TMS570_FLASH_FEDACSDIS_BankID1_SET(reg,val) BSP_FLD32SET(reg, val,21, 23)
259#define TMS570_FLASH_FEDACSDIS_SectorID1(val) BSP_FLD32(val,16, 19)
260#define TMS570_FLASH_FEDACSDIS_SectorID1_GET(reg) BSP_FLD32GET(reg,16, 19)
261#define TMS570_FLASH_FEDACSDIS_SectorID1_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
264#define TMS570_FLASH_FEDACSDIS_BankID0_Inverse(val) BSP_FLD32(val,13, 15)
265#define TMS570_FLASH_FEDACSDIS_BankID0_Inverse_GET(reg) BSP_FLD32GET(reg,13, 15)
266#define TMS570_FLASH_FEDACSDIS_BankID0_Inverse_SET(reg,val) BSP_FLD32SET(reg, val,13, 15)
269#define TMS570_FLASH_FEDACSDIS_SectorID0_inverse(val) BSP_FLD32(val,8, 11)
270#define TMS570_FLASH_FEDACSDIS_SectorID0_inverse_GET(reg) BSP_FLD32GET(reg,8, 11)
271#define TMS570_FLASH_FEDACSDIS_SectorID0_inverse_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
274#define TMS570_FLASH_FEDACSDIS_BankID0(val) BSP_FLD32(val,5, 7)
275#define TMS570_FLASH_FEDACSDIS_BankID0_GET(reg) BSP_FLD32GET(reg,5, 7)
276#define TMS570_FLASH_FEDACSDIS_BankID0_SET(reg,val) BSP_FLD32SET(reg, val,5, 7)
279#define TMS570_FLASH_FEDACSDIS_SectorID0(val) BSP_FLD32(val,0, 3)
280#define TMS570_FLASH_FEDACSDIS_SectorID0_GET(reg) BSP_FLD32GET(reg,0, 3)
281#define TMS570_FLASH_FEDACSDIS_SectorID0_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
286#define TMS570_FLASH_FPRIMADDTAG_PRIM_ADD_TAG(val) BSP_FLD32(val,4, 31)
287#define TMS570_FLASH_FPRIMADDTAG_PRIM_ADD_TAG_GET(reg) BSP_FLD32GET(reg,4, 31)
288#define TMS570_FLASH_FPRIMADDTAG_PRIM_ADD_TAG_SET(reg,val) BSP_FLD32SET(reg, val,4, 31)
291#define TMS570_FLASH_FPRIMADDTAG_0(val) BSP_FLD32(val,0, 3)
292#define TMS570_FLASH_FPRIMADDTAG_0_GET(reg) BSP_FLD32GET(reg,0, 3)
293#define TMS570_FLASH_FPRIMADDTAG_0_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
298#define TMS570_FLASH_FDUPADDTAG_DUP_ADD_TAG(val) BSP_FLD32(val,4, 31)
299#define TMS570_FLASH_FDUPADDTAG_DUP_ADD_TAG_GET(reg) BSP_FLD32GET(reg,4, 31)
300#define TMS570_FLASH_FDUPADDTAG_DUP_ADD_TAG_SET(reg,val) BSP_FLD32SET(reg, val,4, 31)
305#define TMS570_FLASH_FBPROT_PROTL1DIS BSP_BIT32(0)
310#define TMS570_FLASH_FBSE_BSE(val) BSP_FLD32(val,0, 15)
311#define TMS570_FLASH_FBSE_BSE_GET(reg) BSP_FLD32GET(reg,0, 15)
312#define TMS570_FLASH_FBSE_BSE_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
317#define TMS570_FLASH_FBBUSY_BUSY(val) BSP_FLD32(val,0, 7)
318#define TMS570_FLASH_FBBUSY_BUSY_GET(reg) BSP_FLD32GET(reg,0, 7)
319#define TMS570_FLASH_FBBUSY_BUSY_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
324#define TMS570_FLASH_FBAC_OTPPROTDIS(val) BSP_FLD32(val,16, 23)
325#define TMS570_FLASH_FBAC_OTPPROTDIS_GET(reg) BSP_FLD32GET(reg,16, 23)
326#define TMS570_FLASH_FBAC_OTPPROTDIS_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
329#define TMS570_FLASH_FBAC_15_8(val) BSP_FLD32(val,8, 15)
330#define TMS570_FLASH_FBAC_15_8_GET(reg) BSP_FLD32GET(reg,8, 15)
331#define TMS570_FLASH_FBAC_15_8_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
334#define TMS570_FLASH_FBAC_VREADST(val) BSP_FLD32(val,0, 7)
335#define TMS570_FLASH_FBAC_VREADST_GET(reg) BSP_FLD32GET(reg,0, 7)
336#define TMS570_FLASH_FBAC_VREADST_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
341#define TMS570_FLASH_FBFALLBACK_BANKPWR7(val) BSP_FLD32(val,14, 15)
342#define TMS570_FLASH_FBFALLBACK_BANKPWR7_GET(reg) BSP_FLD32GET(reg,14, 15)
343#define TMS570_FLASH_FBFALLBACK_BANKPWR7_SET(reg,val) BSP_FLD32SET(reg, val,14, 15)
346#define TMS570_FLASH_FBFALLBACK_BANKPWR1(val) BSP_FLD32(val,2, 3)
347#define TMS570_FLASH_FBFALLBACK_BANKPWR1_GET(reg) BSP_FLD32GET(reg,2, 3)
348#define TMS570_FLASH_FBFALLBACK_BANKPWR1_SET(reg,val) BSP_FLD32SET(reg, val,2, 3)
351#define TMS570_FLASH_FBFALLBACK_BANKPWR0(val) BSP_FLD32(val,0, 1)
352#define TMS570_FLASH_FBFALLBACK_BANKPWR0_GET(reg) BSP_FLD32GET(reg,0, 1)
353#define TMS570_FLASH_FBFALLBACK_BANKPWR0_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
358#define TMS570_FLASH_FBPRDY_BANKBUSY(val) BSP_FLD32(val,16, 23)
359#define TMS570_FLASH_FBPRDY_BANKBUSY_GET(reg) BSP_FLD32GET(reg,16, 23)
360#define TMS570_FLASH_FBPRDY_BANKBUSY_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
363#define TMS570_FLASH_FBPRDY_PUMPRDY BSP_BIT32(15)
366#define TMS570_FLASH_FBPRDY_BANKRDY(val) BSP_FLD32(val,0, 7)
367#define TMS570_FLASH_FBPRDY_BANKRDY_GET(reg) BSP_FLD32GET(reg,0, 7)
368#define TMS570_FLASH_FBPRDY_BANKRDY_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
373#define TMS570_FLASH_FPAC1_PSLEEP(val) BSP_FLD32(val,16, 26)
374#define TMS570_FLASH_FPAC1_PSLEEP_GET(reg) BSP_FLD32GET(reg,16, 26)
375#define TMS570_FLASH_FPAC1_PSLEEP_SET(reg,val) BSP_FLD32SET(reg, val,16, 26)
378#define TMS570_FLASH_FPAC1_PUMPPWR BSP_BIT32(0)
383#define TMS570_FLASH_FPAC2_PAGP(val) BSP_FLD32(val,0, 15)
384#define TMS570_FLASH_FPAC2_PAGP_GET(reg) BSP_FLD32GET(reg,0, 15)
385#define TMS570_FLASH_FPAC2_PAGP_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
390#define TMS570_FLASH_FMAC_BANK(val) BSP_FLD32(val,0, 2)
391#define TMS570_FLASH_FMAC_BANK_GET(reg) BSP_FLD32GET(reg,0, 2)
392#define TMS570_FLASH_FMAC_BANK_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
397#define TMS570_FLASH_FMSTAT_ILA BSP_BIT32(14)
400#define TMS570_FLASH_FMSTAT_PGV BSP_BIT32(12)
403#define TMS570_FLASH_FMSTAT_EV BSP_BIT32(10)
406#define TMS570_FLASH_FMSTAT_BUSY BSP_BIT32(8)
409#define TMS570_FLASH_FMSTAT_ERS BSP_BIT32(7)
412#define TMS570_FLASH_FMSTAT_PGM BSP_BIT32(6)
415#define TMS570_FLASH_FMSTAT_INVDAT BSP_BIT32(5)
418#define TMS570_FLASH_FMSTAT_CSTAT BSP_BIT32(4)
421#define TMS570_FLASH_FMSTAT_VOLTSTAT BSP_BIT32(3)
424#define TMS570_FLASH_FMSTAT_ESUSP BSP_BIT32(2)
427#define TMS570_FLASH_FMSTAT_PSUSP BSP_BIT32(1)
430#define TMS570_FLASH_FMSTAT_SLOCK BSP_BIT32(0)
443#define TMS570_FLASH_FEMUECC_EMU_ECC(val) BSP_FLD32(val,0, 7)
444#define TMS570_FLASH_FEMUECC_EMU_ECC_GET(reg) BSP_FLD32GET(reg,0, 7)
445#define TMS570_FLASH_FEMUECC_EMU_ECC_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
450#define TMS570_FLASH_FEMUADDR_EMU_ADDR(val) BSP_FLD32(val,3, 21)
451#define TMS570_FLASH_FEMUADDR_EMU_ADDR_GET(reg) BSP_FLD32GET(reg,3, 21)
452#define TMS570_FLASH_FEMUADDR_EMU_ADDR_SET(reg,val) BSP_FLD32SET(reg, val,3, 21)
457#define TMS570_FLASH_FDIAGCTRL_DIAG_TRIG BSP_BIT32(24)
460#define TMS570_FLASH_FDIAGCTRL_DIAG_EN_KEY(val) BSP_FLD32(val,16, 19)
461#define TMS570_FLASH_FDIAGCTRL_DIAG_EN_KEY_GET(reg) BSP_FLD32GET(reg,16, 19)
462#define TMS570_FLASH_FDIAGCTRL_DIAG_EN_KEY_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
465#define TMS570_FLASH_FDIAGCTRL_DIAG_ECC_SEL(val) BSP_FLD32(val,12, 14)
466#define TMS570_FLASH_FDIAGCTRL_DIAG_ECC_SEL_GET(reg) BSP_FLD32GET(reg,12, 14)
467#define TMS570_FLASH_FDIAGCTRL_DIAG_ECC_SEL_SET(reg,val) BSP_FLD32SET(reg, val,12, 14)
480#define TMS570_FLASH_FRAWECC_PIPE_BUF BSP_BIT32(8)
483#define TMS570_FLASH_FRAWECC_RAW_ECC(val) BSP_FLD32(val,0, 7)
484#define TMS570_FLASH_FRAWECC_RAW_ECC_GET(reg) BSP_FLD32GET(reg,0, 7)
485#define TMS570_FLASH_FRAWECC_RAW_ECC_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
490#define TMS570_FLASH_FPAROVR_BNK_INV_PAR BSP_BIT32(16)
493#define TMS570_FLASH_FPAROVR_BUS_PAR_DIS(val) BSP_FLD32(val,12, 15)
494#define TMS570_FLASH_FPAROVR_BUS_PAR_DIS_GET(reg) BSP_FLD32GET(reg,12, 15)
495#define TMS570_FLASH_FPAROVR_BUS_PAR_DIS_SET(reg,val) BSP_FLD32SET(reg, val,12, 15)
498#define TMS570_FLASH_FPAROVR_PAR_OVR_KEY(val) BSP_FLD32(val,9, 11)
499#define TMS570_FLASH_FPAROVR_PAR_OVR_KEY_GET(reg) BSP_FLD32GET(reg,9, 11)
500#define TMS570_FLASH_FPAROVR_PAR_OVR_KEY_SET(reg,val) BSP_FLD32SET(reg, val,9, 11)
503#define TMS570_FLASH_FPAROVR_ADD_INV_PAR BSP_BIT32(8)
506#define TMS570_FLASH_FPAROVR_DAT_INV_PAR(val) BSP_FLD32(val,0, 7)
507#define TMS570_FLASH_FPAROVR_DAT_INV_PAR_GET(reg) BSP_FLD32GET(reg,0, 7)
508#define TMS570_FLASH_FPAROVR_DAT_INV_PAR_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
513#define TMS570_FLASH_FEDACSDIS2_BankID3_Inverse(val) BSP_FLD32(val,29, 31)
514#define TMS570_FLASH_FEDACSDIS2_BankID3_Inverse_GET(reg) BSP_FLD32GET(reg,29, 31)
515#define TMS570_FLASH_FEDACSDIS2_BankID3_Inverse_SET(reg,val) BSP_FLD32SET(reg, val,29, 31)
518#define TMS570_FLASH_FEDACSDIS2_SectorID3_inverse(val) BSP_FLD32(val,24, 27)
519#define TMS570_FLASH_FEDACSDIS2_SectorID3_inverse_GET(reg) BSP_FLD32GET(reg,24, 27)
520#define TMS570_FLASH_FEDACSDIS2_SectorID3_inverse_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
523#define TMS570_FLASH_FEDACSDIS2_BankID3(val) BSP_FLD32(val,21, 23)
524#define TMS570_FLASH_FEDACSDIS2_BankID3_GET(reg) BSP_FLD32GET(reg,21, 23)
525#define TMS570_FLASH_FEDACSDIS2_BankID3_SET(reg,val) BSP_FLD32SET(reg, val,21, 23)
528#define TMS570_FLASH_FEDACSDIS2_SectorID3(val) BSP_FLD32(val,16, 19)
529#define TMS570_FLASH_FEDACSDIS2_SectorID3_GET(reg) BSP_FLD32GET(reg,16, 19)
530#define TMS570_FLASH_FEDACSDIS2_SectorID3_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
533#define TMS570_FLASH_FEDACSDIS2_BankID2_Inverse(val) BSP_FLD32(val,13, 15)
534#define TMS570_FLASH_FEDACSDIS2_BankID2_Inverse_GET(reg) BSP_FLD32GET(reg,13, 15)
535#define TMS570_FLASH_FEDACSDIS2_BankID2_Inverse_SET(reg,val) BSP_FLD32SET(reg, val,13, 15)
538#define TMS570_FLASH_FEDACSDIS2_SectorID2_inverse(val) BSP_FLD32(val,8, 11)
539#define TMS570_FLASH_FEDACSDIS2_SectorID2_inverse_GET(reg) BSP_FLD32GET(reg,8, 11)
540#define TMS570_FLASH_FEDACSDIS2_SectorID2_inverse_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
543#define TMS570_FLASH_FEDACSDIS2_BankID2(val) BSP_FLD32(val,5, 7)
544#define TMS570_FLASH_FEDACSDIS2_BankID2_GET(reg) BSP_FLD32GET(reg,5, 7)
545#define TMS570_FLASH_FEDACSDIS2_BankID2_SET(reg,val) BSP_FLD32SET(reg, val,5, 7)
548#define TMS570_FLASH_FEDACSDIS2_SectorID2(val) BSP_FLD32(val,0, 3)
549#define TMS570_FLASH_FEDACSDIS2_SectorID2_GET(reg) BSP_FLD32GET(reg,0, 3)
550#define TMS570_FLASH_FEDACSDIS2_SectorID2_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
555#define TMS570_FLASH_FSMWRENA_WR_ENA(val) BSP_FLD32(val,0, 2)
556#define TMS570_FLASH_FSMWRENA_WR_ENA_GET(reg) BSP_FLD32GET(reg,0, 2)
557#define TMS570_FLASH_FSMWRENA_WR_ENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
562#define TMS570_FLASH_FSMSECTOR_SECT_ERASED(val) BSP_FLD32(val,16, 31)
563#define TMS570_FLASH_FSMSECTOR_SECT_ERASED_GET(reg) BSP_FLD32GET(reg,16, 31)
564#define TMS570_FLASH_FSMSECTOR_SECT_ERASED_SET(reg,val) BSP_FLD32SET(reg, val,16, 31)
569#define TMS570_FLASH_EEPROMCONFIG_EWAIT(val) BSP_FLD32(val,16, 19)
570#define TMS570_FLASH_EEPROMCONFIG_EWAIT_GET(reg) BSP_FLD32GET(reg,16, 19)
571#define TMS570_FLASH_EEPROMCONFIG_EWAIT_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
574#define TMS570_FLASH_EEPROMCONFIG_AUTOSUSP_EN BSP_BIT32(8)
577#define TMS570_FLASH_EEPROMCONFIG_AUTOSTART_GRACE(val) BSP_FLD32(val,0, 7)
578#define TMS570_FLASH_EEPROMCONFIG_AUTOSTART_GRACE_GET(reg) BSP_FLD32GET(reg,0, 7)
579#define TMS570_FLASH_EEPROMCONFIG_AUTOSTART_GRACE_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
584#define TMS570_FLASH_EECTRL1_EDACMODE(val) BSP_FLD32(val,16, 19)
585#define TMS570_FLASH_EECTRL1_EDACMODE_GET(reg) BSP_FLD32GET(reg,16, 19)
586#define TMS570_FLASH_EECTRL1_EDACMODE_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
589#define TMS570_FLASH_EECTRL1_EE_EOFEN BSP_BIT32(10)
592#define TMS570_FLASH_EECTRL1_EE_EZFEN BSP_BIT32(9)
595#define TMS570_FLASH_EECTRL1_EE_EPEN BSP_BIT32(8)
600#define TMS570_FLASH_EECTRL2_EE_SEC_THRESHOLD(val) BSP_FLD32(val,0, 15)
601#define TMS570_FLASH_EECTRL2_EE_SEC_THRESHOLD_GET(reg) BSP_FLD32GET(reg,0, 15)
602#define TMS570_FLASH_EECTRL2_EE_SEC_THRESHOLD_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
607#define TMS570_FLASH_EECORERRCNT_EE_ERRCNT(val) BSP_FLD32(val,0, 15)
608#define TMS570_FLASH_EECORERRCNT_EE_ERRCNT_GET(reg) BSP_FLD32GET(reg,0, 15)
609#define TMS570_FLASH_EECORERRCNT_EE_ERRCNT_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
614#define TMS570_FLASH_EECORERRADD_COR_ERR_ADD(val) BSP_FLD32(val,3, 31)
615#define TMS570_FLASH_EECORERRADD_COR_ERR_ADD_GET(reg) BSP_FLD32GET(reg,3, 31)
616#define TMS570_FLASH_EECORERRADD_COR_ERR_ADD_SET(reg,val) BSP_FLD32SET(reg, val,3, 31)
619#define TMS570_FLASH_EECORERRADD_B_OFF(val) BSP_FLD32(val,0, 2)
620#define TMS570_FLASH_EECORERRADD_B_OFF_GET(reg) BSP_FLD32GET(reg,0, 2)
621#define TMS570_FLASH_EECORERRADD_B_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
626#define TMS570_FLASH_EECORERRPOS_TYPE BSP_BIT32(8)
629#define TMS570_FLASH_EECORERRPOS_EE_ERR_POS(val) BSP_FLD32(val,0, 7)
630#define TMS570_FLASH_EECORERRPOS_EE_ERR_POS_GET(reg) BSP_FLD32GET(reg,0, 7)
631#define TMS570_FLASH_EECORERRPOS_EE_ERR_POS_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
636#define TMS570_FLASH_EESTATUS_EE_D_UNC_ERR BSP_BIT32(12)
639#define TMS570_FLASH_EESTATUS_EE_UNC_ERR BSP_BIT32(8)
642#define TMS570_FLASH_EESTATUS_EE_CMG BSP_BIT32(6)
645#define TMS570_FLASH_EESTATUS_EE_CME BSP_BIT32(4)
648#define TMS570_FLASH_EESTATUS_EE_D_COR_ERR BSP_BIT32(3)
651#define TMS570_FLASH_EESTATUS_EE_ERR_ONE_FLG BSP_BIT32(2)
654#define TMS570_FLASH_EESTATUS_EE_ERR_ZERO_FLG BSP_BIT32(1)
657#define TMS570_FLASH_EESTATUS_EE_ERR_PRF_FLG BSP_BIT32(0)
662#define TMS570_FLASH_EEUNCERRADD_UNC_ERR_ADD(val) BSP_FLD32(val,3, 31)
663#define TMS570_FLASH_EEUNCERRADD_UNC_ERR_ADD_GET(reg) BSP_FLD32GET(reg,3, 31)
664#define TMS570_FLASH_EEUNCERRADD_UNC_ERR_ADD_SET(reg,val) BSP_FLD32SET(reg, val,3, 31)
667#define TMS570_FLASH_EEUNCERRADD_B_OFF(val) BSP_FLD32(val,0, 2)
668#define TMS570_FLASH_EEUNCERRADD_B_OFF_GET(reg) BSP_FLD32GET(reg,0, 2)
669#define TMS570_FLASH_EEUNCERRADD_B_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
674#define TMS570_FLASH_FCFGBANK_EE_BANK_WIDTH(val) BSP_FLD32(val,20, 31)
675#define TMS570_FLASH_FCFGBANK_EE_BANK_WIDTH_GET(reg) BSP_FLD32GET(reg,20, 31)
676#define TMS570_FLASH_FCFGBANK_EE_BANK_WIDTH_SET(reg,val) BSP_FLD32SET(reg, val,20, 31)
679#define TMS570_FLASH_FCFGBANK_MAIN_BANK_WIDTH(val) BSP_FLD32(val,4, 15)
680#define TMS570_FLASH_FCFGBANK_MAIN_BANK_WIDTH_GET(reg) BSP_FLD32GET(reg,4, 15)
681#define TMS570_FLASH_FCFGBANK_MAIN_BANK_WIDTH_SET(reg,val) BSP_FLD32SET(reg, val,4, 15)
This header file provides utility macros for BSPs.
Definition: reg_flash.h:54
