49#ifndef LIBBSP_ARM_TMS570_EMIF
50#define LIBBSP_ARM_TMS570_EMIF
64 uint8_t reserved1 [24];
70 uint8_t reserved2 [24];
81#define TMS570_EMIF_AWCC_WP1 BSP_BIT32(29)
84#define TMS570_EMIF_AWCC_WP0 BSP_BIT32(28)
87#define TMS570_EMIF_AWCC_CS5_WAIT(val) BSP_FLD32(val,22, 23)
88#define TMS570_EMIF_AWCC_CS5_WAIT_GET(reg) BSP_FLD32GET(reg,22, 23)
89#define TMS570_EMIF_AWCC_CS5_WAIT_SET(reg,val) BSP_FLD32SET(reg, val,22, 23)
92#define TMS570_EMIF_AWCC_CS4_WAIT(val) BSP_FLD32(val,20, 21)
93#define TMS570_EMIF_AWCC_CS4_WAIT_GET(reg) BSP_FLD32GET(reg,20, 21)
94#define TMS570_EMIF_AWCC_CS4_WAIT_SET(reg,val) BSP_FLD32SET(reg, val,20, 21)
97#define TMS570_EMIF_AWCC_CS3_WAIT(val) BSP_FLD32(val,18, 19)
98#define TMS570_EMIF_AWCC_CS3_WAIT_GET(reg) BSP_FLD32GET(reg,18, 19)
99#define TMS570_EMIF_AWCC_CS3_WAIT_SET(reg,val) BSP_FLD32SET(reg, val,18, 19)
102#define TMS570_EMIF_AWCC_CS2_WAIT(val) BSP_FLD32(val,16, 17)
103#define TMS570_EMIF_AWCC_CS2_WAIT_GET(reg) BSP_FLD32GET(reg,16, 17)
104#define TMS570_EMIF_AWCC_CS2_WAIT_SET(reg,val) BSP_FLD32SET(reg, val,16, 17)
107#define TMS570_EMIF_AWCC_MAX_EXT_WAIT(val) BSP_FLD32(val,0, 7)
108#define TMS570_EMIF_AWCC_MAX_EXT_WAIT_GET(reg) BSP_FLD32GET(reg,0, 7)
109#define TMS570_EMIF_AWCC_MAX_EXT_WAIT_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
114#define TMS570_EMIF_SDCR_SR BSP_BIT32(31)
117#define TMS570_EMIF_SDCR_PD BSP_BIT32(30)
120#define TMS570_EMIF_SDCR_PDWR BSP_BIT32(29)
123#define TMS570_EMIF_SDCR_NM BSP_BIT32(14)
126#define TMS570_EMIF_SDCR_CL(val) BSP_FLD32(val,9, 11)
127#define TMS570_EMIF_SDCR_CL_GET(reg) BSP_FLD32GET(reg,9, 11)
128#define TMS570_EMIF_SDCR_CL_SET(reg,val) BSP_FLD32SET(reg, val,9, 11)
131#define TMS570_EMIF_SDCR_BIT11_9LOCK BSP_BIT32(8)
134#define TMS570_EMIF_SDCR_IBANK(val) BSP_FLD32(val,4, 6)
135#define TMS570_EMIF_SDCR_IBANK_GET(reg) BSP_FLD32GET(reg,4, 6)
136#define TMS570_EMIF_SDCR_IBANK_SET(reg,val) BSP_FLD32SET(reg, val,4, 6)
139#define TMS570_EMIF_SDCR_PAGESIZE(val) BSP_FLD32(val,0, 2)
140#define TMS570_EMIF_SDCR_PAGESIZE_GET(reg) BSP_FLD32GET(reg,0, 2)
141#define TMS570_EMIF_SDCR_PAGESIZE_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
146#define TMS570_EMIF_SDRCR_RR(val) BSP_FLD32(val,0, 12)
147#define TMS570_EMIF_SDRCR_RR_GET(reg) BSP_FLD32GET(reg,0, 12)
148#define TMS570_EMIF_SDRCR_RR_SET(reg,val) BSP_FLD32SET(reg, val,0, 12)
153#define TMS570_EMIF_CE2CFG_SS BSP_BIT32(31)
156#define TMS570_EMIF_CE2CFG_EW BSP_BIT32(30)
159#define TMS570_EMIF_CE2CFG_W_SETUP(val) BSP_FLD32(val,26, 29)
160#define TMS570_EMIF_CE2CFG_W_SETUP_GET(reg) BSP_FLD32GET(reg,26, 29)
161#define TMS570_EMIF_CE2CFG_W_SETUP_SET(reg,val) BSP_FLD32SET(reg, val,26, 29)
164#define TMS570_EMIF_CE2CFG_W_STROBE(val) BSP_FLD32(val,20, 25)
165#define TMS570_EMIF_CE2CFG_W_STROBE_GET(reg) BSP_FLD32GET(reg,20, 25)
166#define TMS570_EMIF_CE2CFG_W_STROBE_SET(reg,val) BSP_FLD32SET(reg, val,20, 25)
169#define TMS570_EMIF_CE2CFG_W_HOLD(val) BSP_FLD32(val,17, 19)
170#define TMS570_EMIF_CE2CFG_W_HOLD_GET(reg) BSP_FLD32GET(reg,17, 19)
171#define TMS570_EMIF_CE2CFG_W_HOLD_SET(reg,val) BSP_FLD32SET(reg, val,17, 19)
174#define TMS570_EMIF_CE2CFG_R_SETUP(val) BSP_FLD32(val,13, 16)
175#define TMS570_EMIF_CE2CFG_R_SETUP_GET(reg) BSP_FLD32GET(reg,13, 16)
176#define TMS570_EMIF_CE2CFG_R_SETUP_SET(reg,val) BSP_FLD32SET(reg, val,13, 16)
179#define TMS570_EMIF_CE2CFG_R_STROBE(val) BSP_FLD32(val,7, 12)
180#define TMS570_EMIF_CE2CFG_R_STROBE_GET(reg) BSP_FLD32GET(reg,7, 12)
181#define TMS570_EMIF_CE2CFG_R_STROBE_SET(reg,val) BSP_FLD32SET(reg, val,7, 12)
184#define TMS570_EMIF_CE2CFG_R_HOLD(val) BSP_FLD32(val,4, 6)
185#define TMS570_EMIF_CE2CFG_R_HOLD_GET(reg) BSP_FLD32GET(reg,4, 6)
186#define TMS570_EMIF_CE2CFG_R_HOLD_SET(reg,val) BSP_FLD32SET(reg, val,4, 6)
189#define TMS570_EMIF_CE2CFG_TA(val) BSP_FLD32(val,2, 3)
190#define TMS570_EMIF_CE2CFG_TA_GET(reg) BSP_FLD32GET(reg,2, 3)
191#define TMS570_EMIF_CE2CFG_TA_SET(reg,val) BSP_FLD32SET(reg, val,2, 3)
194#define TMS570_EMIF_CE2CFG_ASIZE(val) BSP_FLD32(val,0, 1)
195#define TMS570_EMIF_CE2CFG_ASIZE_GET(reg) BSP_FLD32GET(reg,0, 1)
196#define TMS570_EMIF_CE2CFG_ASIZE_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
201#define TMS570_EMIF_CE3CFG_SS BSP_BIT32(31)
204#define TMS570_EMIF_CE3CFG_EW BSP_BIT32(30)
207#define TMS570_EMIF_CE3CFG_W_SETUP(val) BSP_FLD32(val,26, 29)
208#define TMS570_EMIF_CE3CFG_W_SETUP_GET(reg) BSP_FLD32GET(reg,26, 29)
209#define TMS570_EMIF_CE3CFG_W_SETUP_SET(reg,val) BSP_FLD32SET(reg, val,26, 29)
212#define TMS570_EMIF_CE3CFG_W_STROBE(val) BSP_FLD32(val,20, 25)
213#define TMS570_EMIF_CE3CFG_W_STROBE_GET(reg) BSP_FLD32GET(reg,20, 25)
214#define TMS570_EMIF_CE3CFG_W_STROBE_SET(reg,val) BSP_FLD32SET(reg, val,20, 25)
217#define TMS570_EMIF_CE3CFG_W_HOLD(val) BSP_FLD32(val,17, 19)
218#define TMS570_EMIF_CE3CFG_W_HOLD_GET(reg) BSP_FLD32GET(reg,17, 19)
219#define TMS570_EMIF_CE3CFG_W_HOLD_SET(reg,val) BSP_FLD32SET(reg, val,17, 19)
222#define TMS570_EMIF_CE3CFG_R_SETUP(val) BSP_FLD32(val,13, 16)
223#define TMS570_EMIF_CE3CFG_R_SETUP_GET(reg) BSP_FLD32GET(reg,13, 16)
224#define TMS570_EMIF_CE3CFG_R_SETUP_SET(reg,val) BSP_FLD32SET(reg, val,13, 16)
227#define TMS570_EMIF_CE3CFG_R_STROBE(val) BSP_FLD32(val,7, 12)
228#define TMS570_EMIF_CE3CFG_R_STROBE_GET(reg) BSP_FLD32GET(reg,7, 12)
229#define TMS570_EMIF_CE3CFG_R_STROBE_SET(reg,val) BSP_FLD32SET(reg, val,7, 12)
232#define TMS570_EMIF_CE3CFG_R_HOLD(val) BSP_FLD32(val,4, 6)
233#define TMS570_EMIF_CE3CFG_R_HOLD_GET(reg) BSP_FLD32GET(reg,4, 6)
234#define TMS570_EMIF_CE3CFG_R_HOLD_SET(reg,val) BSP_FLD32SET(reg, val,4, 6)
237#define TMS570_EMIF_CE3CFG_TA(val) BSP_FLD32(val,2, 3)
238#define TMS570_EMIF_CE3CFG_TA_GET(reg) BSP_FLD32GET(reg,2, 3)
239#define TMS570_EMIF_CE3CFG_TA_SET(reg,val) BSP_FLD32SET(reg, val,2, 3)
242#define TMS570_EMIF_CE3CFG_ASIZE(val) BSP_FLD32(val,0, 1)
243#define TMS570_EMIF_CE3CFG_ASIZE_GET(reg) BSP_FLD32GET(reg,0, 1)
244#define TMS570_EMIF_CE3CFG_ASIZE_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
249#define TMS570_EMIF_CE4CFG_SS BSP_BIT32(31)
252#define TMS570_EMIF_CE4CFG_EW BSP_BIT32(30)
255#define TMS570_EMIF_CE4CFG_W_SETUP(val) BSP_FLD32(val,26, 29)
256#define TMS570_EMIF_CE4CFG_W_SETUP_GET(reg) BSP_FLD32GET(reg,26, 29)
257#define TMS570_EMIF_CE4CFG_W_SETUP_SET(reg,val) BSP_FLD32SET(reg, val,26, 29)
260#define TMS570_EMIF_CE4CFG_W_STROBE(val) BSP_FLD32(val,20, 25)
261#define TMS570_EMIF_CE4CFG_W_STROBE_GET(reg) BSP_FLD32GET(reg,20, 25)
262#define TMS570_EMIF_CE4CFG_W_STROBE_SET(reg,val) BSP_FLD32SET(reg, val,20, 25)
265#define TMS570_EMIF_CE4CFG_W_HOLD(val) BSP_FLD32(val,17, 19)
266#define TMS570_EMIF_CE4CFG_W_HOLD_GET(reg) BSP_FLD32GET(reg,17, 19)
267#define TMS570_EMIF_CE4CFG_W_HOLD_SET(reg,val) BSP_FLD32SET(reg, val,17, 19)
270#define TMS570_EMIF_CE4CFG_R_SETUP(val) BSP_FLD32(val,13, 16)
271#define TMS570_EMIF_CE4CFG_R_SETUP_GET(reg) BSP_FLD32GET(reg,13, 16)
272#define TMS570_EMIF_CE4CFG_R_SETUP_SET(reg,val) BSP_FLD32SET(reg, val,13, 16)
275#define TMS570_EMIF_CE4CFG_R_STROBE(val) BSP_FLD32(val,7, 12)
276#define TMS570_EMIF_CE4CFG_R_STROBE_GET(reg) BSP_FLD32GET(reg,7, 12)
277#define TMS570_EMIF_CE4CFG_R_STROBE_SET(reg,val) BSP_FLD32SET(reg, val,7, 12)
280#define TMS570_EMIF_CE4CFG_R_HOLD(val) BSP_FLD32(val,4, 6)
281#define TMS570_EMIF_CE4CFG_R_HOLD_GET(reg) BSP_FLD32GET(reg,4, 6)
282#define TMS570_EMIF_CE4CFG_R_HOLD_SET(reg,val) BSP_FLD32SET(reg, val,4, 6)
285#define TMS570_EMIF_CE4CFG_TA(val) BSP_FLD32(val,2, 3)
286#define TMS570_EMIF_CE4CFG_TA_GET(reg) BSP_FLD32GET(reg,2, 3)
287#define TMS570_EMIF_CE4CFG_TA_SET(reg,val) BSP_FLD32SET(reg, val,2, 3)
290#define TMS570_EMIF_CE4CFG_ASIZE(val) BSP_FLD32(val,0, 1)
291#define TMS570_EMIF_CE4CFG_ASIZE_GET(reg) BSP_FLD32GET(reg,0, 1)
292#define TMS570_EMIF_CE4CFG_ASIZE_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
297#define TMS570_EMIF_CE5CFG_SS BSP_BIT32(31)
300#define TMS570_EMIF_CE5CFG_EW BSP_BIT32(30)
303#define TMS570_EMIF_CE5CFG_W_SETUP(val) BSP_FLD32(val,26, 29)
304#define TMS570_EMIF_CE5CFG_W_SETUP_GET(reg) BSP_FLD32GET(reg,26, 29)
305#define TMS570_EMIF_CE5CFG_W_SETUP_SET(reg,val) BSP_FLD32SET(reg, val,26, 29)
308#define TMS570_EMIF_CE5CFG_W_STROBE(val) BSP_FLD32(val,20, 25)
309#define TMS570_EMIF_CE5CFG_W_STROBE_GET(reg) BSP_FLD32GET(reg,20, 25)
310#define TMS570_EMIF_CE5CFG_W_STROBE_SET(reg,val) BSP_FLD32SET(reg, val,20, 25)
313#define TMS570_EMIF_CE5CFG_W_HOLD(val) BSP_FLD32(val,17, 19)
314#define TMS570_EMIF_CE5CFG_W_HOLD_GET(reg) BSP_FLD32GET(reg,17, 19)
315#define TMS570_EMIF_CE5CFG_W_HOLD_SET(reg,val) BSP_FLD32SET(reg, val,17, 19)
318#define TMS570_EMIF_CE5CFG_R_SETUP(val) BSP_FLD32(val,13, 16)
319#define TMS570_EMIF_CE5CFG_R_SETUP_GET(reg) BSP_FLD32GET(reg,13, 16)
320#define TMS570_EMIF_CE5CFG_R_SETUP_SET(reg,val) BSP_FLD32SET(reg, val,13, 16)
323#define TMS570_EMIF_CE5CFG_R_STROBE(val) BSP_FLD32(val,7, 12)
324#define TMS570_EMIF_CE5CFG_R_STROBE_GET(reg) BSP_FLD32GET(reg,7, 12)
325#define TMS570_EMIF_CE5CFG_R_STROBE_SET(reg,val) BSP_FLD32SET(reg, val,7, 12)
328#define TMS570_EMIF_CE5CFG_R_HOLD(val) BSP_FLD32(val,4, 6)
329#define TMS570_EMIF_CE5CFG_R_HOLD_GET(reg) BSP_FLD32GET(reg,4, 6)
330#define TMS570_EMIF_CE5CFG_R_HOLD_SET(reg,val) BSP_FLD32SET(reg, val,4, 6)
333#define TMS570_EMIF_CE5CFG_TA(val) BSP_FLD32(val,2, 3)
334#define TMS570_EMIF_CE5CFG_TA_GET(reg) BSP_FLD32GET(reg,2, 3)
335#define TMS570_EMIF_CE5CFG_TA_SET(reg,val) BSP_FLD32SET(reg, val,2, 3)
338#define TMS570_EMIF_CE5CFG_ASIZE(val) BSP_FLD32(val,0, 1)
339#define TMS570_EMIF_CE5CFG_ASIZE_GET(reg) BSP_FLD32GET(reg,0, 1)
340#define TMS570_EMIF_CE5CFG_ASIZE_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
345#define TMS570_EMIF_SDTIMR_T_RFC(val) BSP_FLD32(val,27, 31)
346#define TMS570_EMIF_SDTIMR_T_RFC_GET(reg) BSP_FLD32GET(reg,27, 31)
347#define TMS570_EMIF_SDTIMR_T_RFC_SET(reg,val) BSP_FLD32SET(reg, val,27, 31)
350#define TMS570_EMIF_SDTIMR_T_RP(val) BSP_FLD32(val,24, 26)
351#define TMS570_EMIF_SDTIMR_T_RP_GET(reg) BSP_FLD32GET(reg,24, 26)
352#define TMS570_EMIF_SDTIMR_T_RP_SET(reg,val) BSP_FLD32SET(reg, val,24, 26)
355#define TMS570_EMIF_SDTIMR_T_RCD(val) BSP_FLD32(val,20, 22)
356#define TMS570_EMIF_SDTIMR_T_RCD_GET(reg) BSP_FLD32GET(reg,20, 22)
357#define TMS570_EMIF_SDTIMR_T_RCD_SET(reg,val) BSP_FLD32SET(reg, val,20, 22)
360#define TMS570_EMIF_SDTIMR_T_WR(val) BSP_FLD32(val,16, 18)
361#define TMS570_EMIF_SDTIMR_T_WR_GET(reg) BSP_FLD32GET(reg,16, 18)
362#define TMS570_EMIF_SDTIMR_T_WR_SET(reg,val) BSP_FLD32SET(reg, val,16, 18)
365#define TMS570_EMIF_SDTIMR_T_RAS(val) BSP_FLD32(val,12, 15)
366#define TMS570_EMIF_SDTIMR_T_RAS_GET(reg) BSP_FLD32GET(reg,12, 15)
367#define TMS570_EMIF_SDTIMR_T_RAS_SET(reg,val) BSP_FLD32SET(reg, val,12, 15)
370#define TMS570_EMIF_SDTIMR_T_RC(val) BSP_FLD32(val,8, 11)
371#define TMS570_EMIF_SDTIMR_T_RC_GET(reg) BSP_FLD32GET(reg,8, 11)
372#define TMS570_EMIF_SDTIMR_T_RC_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
375#define TMS570_EMIF_SDTIMR_T_RRD(val) BSP_FLD32(val,4, 6)
376#define TMS570_EMIF_SDTIMR_T_RRD_GET(reg) BSP_FLD32GET(reg,4, 6)
377#define TMS570_EMIF_SDTIMR_T_RRD_SET(reg,val) BSP_FLD32SET(reg, val,4, 6)
382#define TMS570_EMIF_SDSRETR_T_XS(val) BSP_FLD32(val,0, 4)
383#define TMS570_EMIF_SDSRETR_T_XS_GET(reg) BSP_FLD32GET(reg,0, 4)
384#define TMS570_EMIF_SDSRETR_T_XS_SET(reg,val) BSP_FLD32SET(reg, val,0, 4)
389#define TMS570_EMIF_INTRAW_WR BSP_BIT32(2)
392#define TMS570_EMIF_INTRAW_LT BSP_BIT32(1)
395#define TMS570_EMIF_INTRAW_AT BSP_BIT32(0)
400#define TMS570_EMIF_INTMSK_WR_MASKED BSP_BIT32(2)
403#define TMS570_EMIF_INTMSK_LT_MASKED BSP_BIT32(1)
406#define TMS570_EMIF_INTMSK_AT_MASKED BSP_BIT32(0)
411#define TMS570_EMIF_INTMSKSET_WR_MASK_SET BSP_BIT32(2)
414#define TMS570_EMIF_INTMSKSET_LT_MASK_SET BSP_BIT32(1)
417#define TMS570_EMIF_INTMSKSET_AT_MASK_SET BSP_BIT32(0)
422#define TMS570_EMIF_INTMSKCLR_WR_MASK_CLR BSP_BIT32(2)
425#define TMS570_EMIF_INTMSKCLR_LT_MASK_CLR BSP_BIT32(1)
428#define TMS570_EMIF_INTMSKCLR_AT_MASK_CLR BSP_BIT32(0)
433#define TMS570_EMIF_PMCR_CS5_PG_DEL(val) BSP_FLD32(val,26, 31)
434#define TMS570_EMIF_PMCR_CS5_PG_DEL_GET(reg) BSP_FLD32GET(reg,26, 31)
435#define TMS570_EMIF_PMCR_CS5_PG_DEL_SET(reg,val) BSP_FLD32SET(reg, val,26, 31)
438#define TMS570_EMIF_PMCR_CS5_PG_SIZE BSP_BIT32(25)
441#define TMS570_EMIF_PMCR_CS5_PG_MD_EN BSP_BIT32(24)
444#define TMS570_EMIF_PMCR_CS4_PG_DEL(val) BSP_FLD32(val,18, 23)
445#define TMS570_EMIF_PMCR_CS4_PG_DEL_GET(reg) BSP_FLD32GET(reg,18, 23)
446#define TMS570_EMIF_PMCR_CS4_PG_DEL_SET(reg,val) BSP_FLD32SET(reg, val,18, 23)
449#define TMS570_EMIF_PMCR_CS4_PG_SIZE BSP_BIT32(17)
452#define TMS570_EMIF_PMCR_CS4_PG_MD_EN BSP_BIT32(16)
455#define TMS570_EMIF_PMCR_CS3_PG_DEL(val) BSP_FLD32(val,10, 15)
456#define TMS570_EMIF_PMCR_CS3_PG_DEL_GET(reg) BSP_FLD32GET(reg,10, 15)
457#define TMS570_EMIF_PMCR_CS3_PG_DEL_SET(reg,val) BSP_FLD32SET(reg, val,10, 15)
460#define TMS570_EMIF_PMCR_CS3_PG_SIZE BSP_BIT32(9)
463#define TMS570_EMIF_PMCR_CS3_PG_MD_EN BSP_BIT32(8)
466#define TMS570_EMIF_PMCR_CS2_PG_DEL(val) BSP_FLD32(val,2, 7)
467#define TMS570_EMIF_PMCR_CS2_PG_DEL_GET(reg) BSP_FLD32GET(reg,2, 7)
468#define TMS570_EMIF_PMCR_CS2_PG_DEL_SET(reg,val) BSP_FLD32SET(reg, val,2, 7)
471#define TMS570_EMIF_PMCR_CS2_PG_SIZE BSP_BIT32(1)
474#define TMS570_EMIF_PMCR_CS2_PG_MD_EN BSP_BIT32(0)
This header file provides utility macros for BSPs.
Definition: reg_emif.h:54
