RTEMS 6.1-rc4
or1k.h
2
7/*
8 * This file contains information pertaining to the OR1K processor.
9 *
10 * COPYRIGHT (c) 2014 Hesham ALMatary <heshamelmatary@gmail.com>
11 *
12 * Based on code with the following copyright...
13 * COPYRIGHT (c) 1989-1999, 2010.
14 * On-Line Applications Research Corporation (OAR).
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 * 1. Redistributions of source code must retain the above copyright
20 * notice, this list of conditions and the following disclaimer.
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in the
23 * documentation and/or other materials provided with the distribution.
24 *
25 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35 * POSSIBILITY OF SUCH DAMAGE.
36 */
37
38#ifndef _RTEMS_SCORE_OR1K_H
39#define _RTEMS_SCORE_OR1K_H
40
41#ifdef __cplusplus
42extern "C" {
43#endif
44
45/*
46 * This file contains the information required to build
47 * RTEMS for a particular member of the OR1K family.
48 * It does this by setting variables to indicate which
49 * implementation dependent features are present in a particular
50 * member of the family.
51 *
52 * This is a good place to list all the known CPU models
53 * that this port supports and which RTEMS CPU model they correspond
54 * to.
55 */
56
57 /*
58 * Define the name of the CPU family and specific model.
59 */
60
61#define CPU_NAME "OR1K"
62#define CPU_MODEL_NAME "OR1200"
63
64#ifdef __cplusplus
65}
66#endif
67
68#endif /* _RTEMS_SCORE_OR1K_H */
