RTEMS 6.1-rc4
msdos.h
1
9/*
10 * Copyright (C) 2001 OKTET Ltd., St.-Petersburg, Russia
11 * Author: Eugeny S. Mints <Eugeny.Mints@oktet.ru>
12 *
13 * Modifications to support UTF-8 in the file system are
14 * Copyright (c) 2013 embedded brains GmbH & Co. KG
15 *
16 * The license and distribution terms for this file may be
17 * found in the file LICENSE in this distribution or at
18 * http://www.rtems.org/license/LICENSE.
19 */
20
21#ifndef __DOSFS_MSDOS_H__
22#define __DOSFS_MSDOS_H__
23
24#include <rtems.h>
25#include <rtems/libio_.h>
26#include <rtems/dosfs.h>
27#include <rtems/thread.h>
28
29#include "fat.h"
30#include "fat_file.h"
31
32#ifdef __cplusplus
33extern "C" {
34#endif
35
42#define MSDOS_NAME_NOT_FOUND_ERR 0x7D01
43
44/*
45 * This structure identifies the instance of the filesystem on the MSDOS
46 * level.
47 */
48typedef struct msdos_fs_info_s
49{
50 fat_fs_info_t fat; /*
51 * volume
52 * description
53 */
54 const rtems_filesystem_file_handlers_r *directory_handlers; /*
55 * a set of routines
56 * that handles the
57 * nodes of directory
58 * type
59 */
60 const rtems_filesystem_file_handlers_r *file_handlers; /*
61 * a set of routines
62 * that handles the
63 * nodes of file
64 * type
65 */
66 rtems_recursive_mutex vol_mutex;
67 uint8_t *cl_buf; /*
68 * just placeholder
69 * for anything
70 */
71
74
75static inline void msdos_fs_lock(msdos_fs_info_t *fs_info)
76{
77 rtems_recursive_mutex_lock(&fs_info->vol_mutex);
78}
79
80static inline void msdos_fs_unlock(msdos_fs_info_t *fs_info)
81{
82 rtems_recursive_mutex_unlock(&fs_info->vol_mutex);
83}
84
85/* a set of routines that handle the nodes which are directories */
86extern const rtems_filesystem_file_handlers_r msdos_dir_handlers;
87
88/* a set of routines that handle the nodes which are files */
89extern const rtems_filesystem_file_handlers_r msdos_file_handlers;
90
91/*
92 * Macros for fetching fields from 32 bytes long FAT Directory Entry
93 * Structure
94 */
95#define MSDOS_DIRECTORY_ENTRY_STRUCT_SIZE 32 /* 32 bytes */
96
97#define MSDOS_DIR_NAME(x) (char *)((x) + 0)
98#define MSDOS_DIR_ENTRY_TYPE(x) (uint8_t *)((x) + 0)
99#define MSDOS_DIR_ATTR(x) (uint8_t *)((x) + 11)
100#define MSDOS_DIR_NT_RES(x) (uint8_t *)((x) + 12)
101#define MSDOS_DIR_LFN_CHECKSUM(x) (uint8_t *)((x) + 13)
102#define MSDOS_DIR_CRT_TIME_TENTH(x) (uint8_t *)((x) + 13)
103#define MSDOS_DIR_CRT_TIME(x) (uint16_t *)((x) + 14)
104#define MSDOS_DIR_CRT_DATE(x) (uint16_t *)((x) + 16)
105#define MSDOS_DIR_LAST_ACCESS_DATE(x) (uint16_t *)((x) + 18)
106#define MSDOS_DIR_FIRST_CLUSTER_HI(x) (uint16_t *)((x) + 20)
107#define MSDOS_DIR_WRITE_TIME(x) (uint16_t *)((x) + 22)
108#define MSDOS_DIR_WRITE_DATE(x) (uint16_t *)((x) + 24)
109#define MSDOS_DIR_FIRST_CLUSTER_LOW(x) (uint16_t *)((x) + 26)
110#define MSDOS_DIR_FILE_SIZE(x) (uint32_t *)((x) + 28)
111
112#define MSDOS_EXTRACT_CLUSTER_NUM(p) \
113 (uint32_t)( (CF_LE_W(*MSDOS_DIR_FIRST_CLUSTER_LOW(p))) | \
114 ((uint32_t)(CF_LE_W((*MSDOS_DIR_FIRST_CLUSTER_HI(p))))<<16) )
115
116/*
117 * Fields offset in 32 bytes long FAT Directory Entry
118 * Structure
119 */
120#define MSDOS_FILE_SIZE_OFFSET 28
121#define MSDOS_FILE_NAME_OFFSET 0
122#define MSDOS_FIRST_CLUSTER_HI_OFFSET 20
123#define MSDOS_FIRST_CLUSTER_LOW_OFFSET 26
124#define MSDOS_FILE_WDATE_OFFSET 24
125#define MSDOS_FILE_WTIME_OFFSET 22
126#define MSDOS_FILE_ADATE_OFFSET 18
127#define MSDOS_FILE_CDATE_OFFSET 16
128#define MSDOS_FILE_CTIME_OFFSET 14
129
130/*
131 * Possible values of DIR_Attr field of 32 bytes long FAT Directory Entry
132 * Structure
133 */
134#define MSDOS_ATTR_READ_ONLY 0x01
135#define MSDOS_ATTR_HIDDEN 0x02
136#define MSDOS_ATTR_SYSTEM 0x04
137#define MSDOS_ATTR_VOLUME_ID 0x08
138#define MSDOS_ATTR_DIRECTORY 0x10
139#define MSDOS_ATTR_ARCHIVE 0x20
140#define MSDOS_ATTR_LFN (MSDOS_ATTR_READ_ONLY | \
141 MSDOS_ATTR_HIDDEN | \
142 MSDOS_ATTR_SYSTEM | \
143 MSDOS_ATTR_VOLUME_ID)
144#define MSDOS_ATTR_LFN_MASK (MSDOS_ATTR_READ_ONLY | \
145 MSDOS_ATTR_HIDDEN | \
146 MSDOS_ATTR_SYSTEM | \
147 MSDOS_ATTR_VOLUME_ID | \
148 MSDOS_ATTR_DIRECTORY | \
149 MSDOS_ATTR_ARCHIVE)
150
151#define MSDOS_LAST_LONG_ENTRY 0x40
152#define MSDOS_LAST_LONG_ENTRY_MASK 0x3F
153
154#define MSDOS_DT_2SECONDS_MASK 0x1F /* seconds divided by 2 */
155#define MSDOS_DT_2SECONDS_SHIFT 0
156#define MSDOS_DT_MINUTES_MASK 0x7E0 /* minutes */
157#define MSDOS_DT_MINUTES_SHIFT 5
158#define MSDOS_DT_HOURS_MASK 0xF800 /* hours */
159#define MSDOS_DT_HOURS_SHIFT 11
160
161#define MSDOS_DD_DAY_MASK 0x1F /* day of month */
162#define MSDOS_DD_DAY_SHIFT 0
163#define MSDOS_DD_MONTH_MASK 0x1E0 /* month */
164#define MSDOS_DD_MONTH_SHIFT 5
165#define MSDOS_DD_YEAR_MASK 0xFE00 /* year - 1980 */
166#define MSDOS_DD_YEAR_SHIFT 9
167
168
169/*
170 * Possible values of DIR_Name[0] field of 32 bytes long FAT Directory Entry
171 * Structure
172 */
173#define MSDOS_THIS_DIR_ENTRY_EMPTY 0xE5
174#define MSDOS_THIS_DIR_ENTRY_AND_REST_EMPTY 0x00
175
176/*
177 * Number of characters per directory entry for a long filename.
178 */
179#define MSDOS_LFN_LEN_PER_ENTRY (13)
180
181/*
182 * Macros for names parsing and formatting
183 */
184#define MSDOS_NAME_MAX_UTF8_BYTES_PER_CHAR 4
185#define MSDOS_NAME_MIN_UTF8_BYTES_PER_CHAR 1
186
187#define MSDOS_SHORT_BASE_LEN 8 /* 8 characters */
188#define MSDOS_SHORT_EXT_LEN 3 /* 3 characters */
189#define MSDOS_SHORT_NAME_LEN (MSDOS_SHORT_BASE_LEN+\
190 MSDOS_SHORT_EXT_LEN) /* 11 chars */
191#define MSDOS_NAME_MAX_LNF_LEN (255)
192#define MSDOS_NAME_MAX MSDOS_SHORT_NAME_LEN
193#define MSDOS_NAME_MAX_UTF8_SFN_BYTES (MSDOS_NAME_MAX *\
194 MSDOS_NAME_MAX_UTF8_BYTES_PER_CHAR)
195#define MSDOS_NAME_MAX_WITH_DOT (MSDOS_NAME_MAX + 1)
196#define MSDOS_SFN_MAX_WITH_DOT_UTF8_BYTES (MSDOS_NAME_MAX_WITH_DOT *\
197 MSDOS_NAME_MAX_UTF8_BYTES_PER_CHAR)
198#define MSDOS_NAME_MAX_LFN_WITH_DOT (260)
199
200#define MSDOS_NAME_LFN_BYTES_PER_CHAR (2)
201#define MSDOS_NAME_MAX_LFN_BYTES (MSDOS_NAME_MAX_LFN_WITH_DOT *\
202 MSDOS_NAME_LFN_BYTES_PER_CHAR)
203#define MSDOS_NAME_MAX_UTF8_LFN_BYTES (MSDOS_NAME_MAX_LFN_WITH_DOT *\
204 MSDOS_NAME_MAX_UTF8_BYTES_PER_CHAR)
205#define MSDOS_ENTRY_LFN_UTF8_BYTES (MSDOS_LFN_LEN_PER_ENTRY *\
206 MSDOS_NAME_MAX_UTF8_BYTES_PER_CHAR)
207
208extern const char *const MSDOS_DOT_NAME; /* ".", padded to MSDOS_NAME chars */
209extern const char *const MSDOS_DOTDOT_NAME; /* ".", padded to MSDOS_NAME chars */
210
211typedef enum msdos_name_types_e
212{
213 MSDOS_NAME_INVALID = 0, /* Unknown name type. Has invalid characters. */
214 MSDOS_NAME_SHORT, /* Name can be short. */
215 MSDOS_NAME_LONG /* Name is long; cannot be short. */
216} msdos_name_type_t;
217
218typedef enum msdos_token_types_e
219{
220 MSDOS_NO_MORE_PATH,
221 MSDOS_CURRENT_DIR,
222 MSDOS_UP_DIR,
223 MSDOS_NAME,
224 MSDOS_INVALID_TOKEN
225} msdos_token_types_t;
226
227/* Others macros */
228#define MSDOS_RES_NT_VALUE 0x00
229#define MSDOS_INIT_DIR_SIZE 0x00
230
231/* "dot" entry offset in a directory */
232#define MSDOS_DOT_DIR_ENTRY_OFFSET 0x00 /* first entry in directory */
233
234/* "dotdot" entry offset in a directory */
235#define MSDOS_DOTDOT_DIR_ENTRY_OFFSET 0x20 /* second entry in directory */
236
237/* 'p' should be char* */
238#define DOT_NODE_P(p) ((char *)(p))
239#define DOTDOT_NODE_P(p) ((char *)((p) + MSDOS_DIRECTORY_ENTRY_STRUCT_SIZE))
240
241/* Size limits for files and directories */
242#define MSDOS_MAX_DIR_LENGTH 0x200000 /* 2,097,152 bytes */
243#define MSDOS_MAX_FILE_SIZE 0xFFFFFFFF /* 4 Gb */
244
245/*
246 * The number of 32 bytes long FAT Directory Entry
247 * Structures per 512 bytes sector
248 */
249#define MSDOS_DPS512_NUM 16
250
257
258void msdos_eval_path(rtems_filesystem_eval_path_context_t *ctx);
259
266
272int msdos_mknod(
274 const char *name,
275 size_t namelen,
276 mode_t mode,
277 dev_t dev
278);
279
285int msdos_rmnod(
286 const rtems_filesystem_location_info_t *parentloc,
288);
289
295int msdos_rename(
296 const rtems_filesystem_location_info_t *old_parent_loc,
298 const rtems_filesystem_location_info_t *new_parent_loc,
299 const char *new_name,
300 size_t new_namelen
301);
302
303int msdos_statvfs(
304 const rtems_filesystem_location_info_t *root_loc,
305 struct statvfs *sb);
306
307void msdos_lock(const rtems_filesystem_mount_table_entry_t *mt_entry);
308
309void msdos_unlock(const rtems_filesystem_mount_table_entry_t *mt_entry);
310
318 const rtems_filesystem_operations_table *op_table,
319 const rtems_filesystem_file_handlers_r *file_handlers,
320 const rtems_filesystem_file_handlers_r *directory_handlers,
322);
323
324ssize_t msdos_file_read(
325 rtems_libio_t *iop, /* IN */
326 void *buffer, /* IN */
327 size_t count /* IN */
328);
329
330ssize_t msdos_file_write(
331 rtems_libio_t *iop, /* IN */
332 const void *buffer, /* IN */
333 size_t count /* IN */
334);
335
336int msdos_file_stat(
338 struct stat *buf
339);
340
341int
342msdos_file_ftruncate(
343 rtems_libio_t *iop, /* IN */
344 off_t length /* IN */
345);
346
347int msdos_file_sync(rtems_libio_t *iop);
348
349ssize_t msdos_dir_read(
350 rtems_libio_t *iop, /* IN */
351 void *buffer, /* IN */
352 size_t count /* IN */
353);
354
355int msdos_dir_sync(rtems_libio_t *iop);
356
357int msdos_dir_stat(
359 struct stat *buf
360);
361
369 fat_file_type_t type,
370 const char *name,
371 int name_len,
372 mode_t mode,
373 fat_file_fd_t *link_fd);
374
375/* Misc prototypes */
376
377int msdos_find_name(
379 const char *name,
380 int name_len
381);
382
383int msdos_get_name_node(
384 const rtems_filesystem_location_info_t *parent_loc,
385 bool create_node,
386 const char *name,
387 int name_len,
388 msdos_name_type_t name_type,
389 fat_dir_pos_t *dir_pos,
390 char *name_dir_entry
391);
392
393int msdos_dir_info_remove(rtems_filesystem_location_info_t *pathloc);
394
395ssize_t
396msdos_format_dirent_with_dot(char *dst,const char *src);
397
398msdos_name_type_t msdos_long_to_short(rtems_dosfs_convert_control *converter,
399 const char *lfn, int lfn_len,
400 char* sfn, int sfn_len);
401
402ssize_t
403msdos_filename_utf8_to_short_name_for_compare (
405 const uint8_t *utf8_name,
406 const size_t utf8_name_size,
407 void *short_name,
408 const size_t short_name_size);
409
410ssize_t
411msdos_filename_utf8_to_short_name_for_save (
413 const uint8_t *utf8_name,
414 const size_t utf8_name_size,
415 void *short_name,
416 const size_t short_name_size);
417
418ssize_t
419msdos_filename_utf8_to_long_name_for_compare (
421 const uint8_t *utf8_name,
422 const size_t utf8_name_size,
423 uint8_t *long_name,
424 const size_t long_name_size);
425
426ssize_t
427msdos_filename_utf8_to_long_name_for_save (
429 const uint8_t *utf8_name,
430 const size_t utf8_name_size,
431 uint16_t *long_name,
432 const size_t long_name_size);
433
434ssize_t
435msdos_get_utf16_string_from_long_entry (
436 const char *entry,
437 uint16_t *entry_string_buf,
438 const size_t buf_size,
439 bool is_first_entry
440);
441
442void msdos_date_unix2dos(
443 unsigned int tsp, uint16_t *ddp,
444 uint16_t *dtp);
445
446unsigned int msdos_date_dos2unix(unsigned int dd, unsigned int dt);
447
448int msdos_set_first_char4file_name(
450 fat_dir_pos_t *dir_pos,
451 unsigned char first_char
452);
453
454int msdos_dir_is_empty(
456 fat_file_fd_t *fat_fd,
457 bool *ret_val
458);
459
460int msdos_find_name_in_fat_file(
462 fat_file_fd_t *fat_fd,
463 bool create_node,
464 const uint8_t *name_utf8,
465 int name_len,
466 msdos_name_type_t name_type,
467 fat_dir_pos_t *dir_pos,
468 char *name_dir_entry
469);
470
471int msdos_find_node_by_cluster_num_in_fat_file(
473 fat_file_fd_t *fat_fd,
474 uint32_t cl4find,
475 fat_dir_pos_t *dir_pos,
476 char *dir_entry
477);
478
479int msdos_get_dotdot_dir_info_cluster_num_and_offset(
481 uint32_t cln,
482 fat_dir_pos_t *dir_pos,
483 char *dir_entry
484);
485
486int msdos_sync(rtems_libio_t *iop);
487
488uint8_t msdos_lfn_checksum(const void *entry);
489
492#ifdef __cplusplus
493}
494#endif
495#endif /* __DOSFS_MSDOS_H__ */
Application Interface to FAT Filesystem.
Constants/Data Structures/Prototypes on a Volume with FAT Filesystem.
Constants/Data Structures/Prototypes for Operations on "fat-file".
int msdos_rename(const rtems_filesystem_location_info_t *old_parent_loc, const rtems_filesystem_location_info_t *old_loc, const rtems_filesystem_location_info_t *new_parent_loc, const char *new_name, size_t new_namelen)
Rename a MSDOS filesystem node.
Definition: msdos_rename.c:39
int msdos_initialize_support(rtems_filesystem_mount_table_entry_t *temp_mt_entry, const rtems_filesystem_operations_table *op_table, const rtems_filesystem_file_handlers_r *file_handlers, const rtems_filesystem_file_handlers_r *directory_handlers, rtems_dosfs_convert_control *converter)
MSDOS filesystem initialization routine.
Definition: msdos_initsupp.c:52
void msdos_free_node_info(const rtems_filesystem_location_info_t *pathloc)
Call the Fat-File close routine.
Definition: msdos_free.c:37
int msdos_mknod(const rtems_filesystem_location_info_t *loc, const char *name, size_t namelen, mode_t mode, dev_t dev)
Routine for node creation in a MSDOS filesystem.
Definition: msdos_mknod.c:38
void msdos_shut_down(rtems_filesystem_mount_table_entry_t *temp_mt_entry)
Shut down the MSDOS filesystem.
Definition: msdos_fsunmount.c:47
int msdos_rmnod(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *loc)
Remove node from MSDOS directory.
Definition: msdos_rmnod.c:25
int msdos_creat_node(const rtems_filesystem_location_info_t *parent_loc, fat_file_type_t type, const char *name, int name_len, mode_t mode, fat_file_fd_t *link_fd)
Implements wake up version of the "signal" operation.
Definition: msdos_create.c:62
LibIO Internal Interface.
File system node operations table.
Definition: libio.h:1021
File system operations table.
Definition: libio.h:489
Definition: mmu-config.c:53
Definition: fat.h:381
Descriptor of a fat-file.
Definition: fat_file.h:74
Definition: fat.h:352
Definition: msdos.h:49
FAT filesystem convert control.
Definition: dosfs.h:201
Path evaluation context.
Definition: libio.h:103
File system location.
Definition: fs.h:72
Mount table entry.
Definition: libio.h:1622
An open file data structure.
Definition: libio.h:1338
Definition: statvfs.h:56
This header file provides the API of Self-Contained Objects.
