RTEMS
6.1-rc4
bsps
microblaze
include
bsp
microblaze-fdt-support.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
* Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef LIBBSP_MICROBLAZE_MICROBLAZE_FDT_SUPPORT_H
37
#define LIBBSP_MICROBLAZE_MICROBLAZE_FDT_SUPPORT_H
38
39
#ifdef __cplusplus
40
extern
"C"
41
#endif
42
43
#include <stdint.h>
44
55
uint32_t
try_get_prop_from_device_tree
56
const
char
*compatible,
57
const
char
*prop_name,
58
uint32_t default_value
59
60
61
#ifdef __cplusplus
62
63
#endif
64
65
#endif
/* LIBBSP_MICROBLAZE_MICROBLAZE_FDT_SUPPORT_H */
uint32_t try_get_prop_from_device_tree(const char *compatible, const char *prop_name, uint32_t default_value)
Get the value of a property from a compatible node in the device tree.
Definition:
microblaze-fdt-support.c:82
