RTEMS 6.1-rc4
virtex
BSP NAME: Virtex
BOARD: Xilinx ML-403 and (hopefully) any vitex/PPC based board
BUS: N/A
CPU FAMILY: ppc
CPU: PowerPC 405GP
COPROCESSORS: N/A
MODE: 32 bit mode
DEBUG MONITOR:
PERIPHERALS
TIMERS: 405GP internal
SERIAL PORTS: Xilinx consolelite
REAL-TIME CLOCK: none
DMA: Xilinx vitex internal
VIDEO: none
SCSI: none
NETWORKING: Xilinx TEMAC
DRIVER INFORMATION
CLOCK DRIVER: PPC Decrementer
IOSUPP DRIVER: N/A
SHMSUPP: N/A
TIMER DRIVER: N/A
TTY DRIVER: consoleelite
STDIO
PORT: Console port 0
ELECTRICAL: RS-232
BAUD: as defined in FPGA design
BITS PER CHARACTER: 8
PARITY: None
STOP BITS: 1
Board description
clock rate: 234 MHz
ROM: 16MByte FLASH
RAM: 64MByte DRAM
Virtex only supports single processor operations.
Configuration
This board support package is written for a typical virtex/PPC FPGA system. The rough features of such a board are described above.
When a new virtex FPGA system is created (using the Xilinx design software), a parameter file "xparameters.h" is also created, which describes the basic features of the hardware (like peripherals included, interrupt routing etc.).
This BSP normally takes its basic HW description for the file "xparameters_dflt.h", which describes my FPGA system. When this BSP should run on a different hardware, a path to the proper "xparameters.h" can be provided on the "configure" command line.
For adapting this BSP to other boards, you can specify several configuration options at the configure command line (use "./configure --help" in this directory). Here is an example for the top-level configure invocation:
/path/to/rtems/sources/configure \
--target=powerpc-rtems4.11 \
--enable-rtemsbsp=virtex \
--enable-maintainer-mode \
--enable-posix \
--enable-tests \
--disable-networking \
'RTEMS_XPARAMETERS_H="/path/to/xparameters.h"' \
VIRTEX_RAM_ORIGIN=0xfffc0000 \
VIRTEX_RAM_LENGTH=0x3ffec \
VIRTEX_RESET_ORIGIN=0xffffffec
