RTEMS 6.1-rc4
isrlevel.h
2
14/*
15 * COPYRIGHT (c) 1989-2011.
16 * On-Line Applications Research Corporation (OAR).
17 *
18 * Redistribution and use in source and binary forms, with or without
19 * modification, are permitted provided that the following conditions
20 * are met:
21 * 1. Redistributions of source code must retain the above copyright
22 * notice, this list of conditions and the following disclaimer.
23 * 2. Redistributions in binary form must reproduce the above copyright
24 * notice, this list of conditions and the following disclaimer in the
25 * documentation and/or other materials provided with the distribution.
26 *
27 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
28 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
29 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
30 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
31 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
32 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
33 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
34 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
35 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
36 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
37 * POSSIBILITY OF SUCH DAMAGE.
38 */
39
40#ifndef _RTEMS_SCORE_ISR_LEVEL_h
41#define _RTEMS_SCORE_ISR_LEVEL_h
42
43#include <rtems/score/cpu.h>
44#include <rtems/score/assert.h>
45
46#ifdef __cplusplus
47extern "C" {
48#endif
49
60typedef uint32_t ISR_Level;
61
76#define _ISR_Local_disable( _level ) \
77 do { \
78 _CPU_ISR_Disable( _level ); \
79 RTEMS_COMPILER_MEMORY_BARRIER(); \
80 } while (0)
81
93#define _ISR_Local_enable( _level ) \
94 do { \
95 RTEMS_COMPILER_MEMORY_BARRIER(); \
96 _CPU_ISR_Enable( _level ); \
97 } while (0)
98
118#define _ISR_Local_flash( _level ) \
119 do { \
120 RTEMS_COMPILER_MEMORY_BARRIER(); \
121 _CPU_ISR_Flash( _level ); \
122 RTEMS_COMPILER_MEMORY_BARRIER(); \
123 } while (0)
124
134#define _ISR_Is_enabled( _level ) \
135 _CPU_ISR_Is_enabled( _level )
136
147#define _ISR_Get_level() \
148 _CPU_ISR_Get_level()
149
159#define _ISR_Set_level( _new_level ) \
160 do { \
161 RTEMS_COMPILER_MEMORY_BARRIER(); \
162 _CPU_ISR_Set_level( _new_level ); \
163 RTEMS_COMPILER_MEMORY_BARRIER(); \
164 } while (0)
165
175bool _ISR_Is_in_progress( void );
176
179#ifdef __cplusplus
180}
181#endif
182#endif
This header file provides the interfaces of the Assert Handler.
bool _ISR_Is_in_progress(void)
Checks if an ISR in progress.
Definition: nios2-isr-is-in-progress.c:36
uint32_t ISR_Level
Definition: isrlevel.h:60
