RTEMS 6.1-rc4
isr_entries.h
2
8/*
9 * COPYRIGHT (c) 1989-2012.
10 * On-Line Applications Research Corporation (OAR).
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 * 1. Redistributions of source code must retain the above copyright
16 * notice, this list of conditions and the following disclaimer.
17 * 2. Redistributions in binary form must reproduce the above copyright
18 * notice, this list of conditions and the following disclaimer in the
19 * documentation and/or other materials provided with the distribution.
20 *
21 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31 * POSSIBILITY OF SUCH DAMAGE.
32 */
33
34#ifndef _ISR_ENTRIES_H
35#define _ISR_ENTRIES_H 1
36
37#include <rtems/score/cpuimpl.h>
38
39extern void mips_install_isr_entries( void );
40extern void mips_vector_isr_handlers( CPU_Interrupt_frame *frame );
41
42#if __mips == 1
43extern void exc_utlb_code(void);
44extern void exc_dbg_code(void);
45extern void exc_norm_code(void);
46#elif __mips == 32
47extern void exc_tlb_code(void);
48extern void exc_xtlb_code(void);
49extern void exc_cache_code(void);
50extern void exc_norm_code(void);
51#elif __mips == 3
52extern void exc_tlb_code(void);
53extern void exc_xtlb_code(void);
54extern void exc_cache_code(void);
55extern void exc_norm_code(void);
56#endif
57
58#endif
Interrupt stack frame (ISF).
Definition: cpuimpl.h:64
