RTEMS
6.1-rc4
bsps
microblaze
microblaze_fpga
include
bsp
intc.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
* Copyright (C) 2021 On-Line Applications Research Corporation (OAR)
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef LIBBSP_MICROBLAZE_FPGA_INTC_H
37
#define LIBBSP_MICROBLAZE_FPGA_INTC_H
38
39
#include <bspopts.h>
40
41
bsp/utility.h
42
43
#ifdef __cplusplus
44
extern
"C"
45
#endif
/* __cplusplus */
46
47
typedef
struct
48
/* Interrupt Status Register */
49
uint32_t isr;
50
uint32_t ipr;
51
/* Interrupt Enable Register */
52
uint32_t ier;
53
/* Interrupt Acknowledge Register */
54
uint32_t iar;
55
uint32_t sie;
56
uint32_t cie;
57
uint32_t ivr;
58
#define MICROBLAZE_INTC_MER_HIE BSP_BIT32(1)
59
#define MICROBLAZE_INTC_MER_ME BSP_BIT32(0)
60
/* Master Enable Register */
61
uint32_t mer;
62
/* Interrupt Mode Register, this is present only for Fast Interrupt */
63
uint32_t imr;
64
/* Interrupt Level Register */
65
uint32_t ilr;
66
Microblaze_INTC
67
68
#ifdef __cplusplus
69
70
#endif
/* __cplusplus */
71
72
#endif
/* LIBBSP_MICROBLAZE_FPGA_INTC_H */
utility.h
This header file provides utility macros for BSPs.
Microblaze_INTC
Definition:
intc.h:47
