RTEMS
6.1-rc4
bsps
arm
include
dev
spi
imx-spi-gpio.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
12
13
* Copyright (C) 2024 embedded brains GmbH & Co. KG
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
#ifndef _RTEMS_DEV_SPI_IMX_SPI_GPIO_H
38
#define _RTEMS_DEV_SPI_IMX_SPI_GPIO_H
39
40
rtems.h
41
42
#ifdef __cplusplus
43
extern
"C"
44
#endif
/* __cplusplus */
45
80
rtems_status_code
imx_spi_gpio_init
void
81
84
#ifdef __cplusplus
85
86
#endif
/* __cplusplus */
87
88
#endif
/* _RTEMS_DEV_SPI_IMX_SPI_GPIO_H */
rtems_status_code
rtems_status_code
Definition:
status.h:85
imx_spi_gpio_init
rtems_status_code imx_spi_gpio_init(void)
Register all compatible nodes from the device tree.
Definition:
imx-spi-gpio.c:67
rtems.h
