RTEMS
6.1-rc4
bsps
include
grlib
grtc.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
/* GRTC Telecommand (TC) decoder driver interface
4
5
* COPYRIGHT (c) 2007.
6
* Cobham Gaisler AB.
7
8
9
* modification, are permitted provided that the following conditions
10
* are met:
11
* 1. Redistributions of source code must retain the above copyright
12
* notice, this list of conditions and the following disclaimer.
13
* 2. Redistributions in binary form must reproduce the above copyright
14
* notice, this list of conditions and the following disclaimer in the
15
* documentation and/or other materials provided with the distribution.
16
17
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
18
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
21
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
22
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
23
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
24
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
25
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
26
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
27
* POSSIBILITY OF SUCH DAMAGE.
28
29
30
#ifndef __GRTC_H__
31
#define __GRTC_H__
32
33
#ifdef __cplusplus
34
extern
"C"
35
#endif
36
37
#define GRTC_IOC_UNUSED 0
38
39
/* Driver operation controlling commands */
40
#define GRTC_IOC_START 1
41
#define GRTC_IOC_STOP 2
42
#define GRTC_IOC_ISSTARTED 3
43
#define GRTC_IOC_SET_BLOCKING_MODE 4
/* Raw mode only */
44
#define GRTC_IOC_SET_TIMEOUT 5
/* Raw mode only */
45
46
#define GRTC_IOC_ADD_BUFF 16
/* Frame mode only */
47
#define GRTC_IOC_RECV 17
48
49
/* Available only in STOPPED mode */
50
#define GRTC_IOC_SET_MODE 32
/* Set frame mode (ioctl) or raw mode (read) */
51
#define GRTC_IOC_SET_BUF_PARAM 33
52
#define GRTC_IOC_SET_CONFIG 34
53
#define GRTC_IOC_POOLS_SETUP 35
54
55
/* Available in both running and stopped mode */
56
#define GRTC_IOC_GET_CONFIG 64
57
#define GRTC_IOC_GET_BUF_PARAM 65
58
#define GRTC_IOC_GET_HW_STATUS 66
59
#define GRTC_IOC_ASSIGN_FRM_POOL 67
60
#define GRTC_IOC_GET_CLCW_ADR 68
/* Get address of CLCWRx1 */
61
#define GRTC_IOC_GET_STATS 69
/* Get statistics, note that most of the stats are only avilable in FRAME mode */
62
#define GRTC_IOC_CLR_STATS 70
/* Clear statistics */
63
64
/* Available only in RUNNING mode */
65
66
/* Args to GRTC_IOC_GET_BUF_PARAMS */
67
#define GRTC_BUF_MAXLEN (0x100*1024)
68
#define GRTC_BUF_MASK 0xfffffc00
69
struct
grtc_ioc_buf_params
70
unsigned
int
length;
/* Length of new buffer in multiples of 1kbyte blocks */
71
void
*custom_buffer;
/* If set zero driver will allocate with malloc, set LSB to 1 to indicate remote address */
72
73
74
/* Args to GRTC_IOC_SET_BLOCKING_MODE */
75
enum
76
GRTC_BLKMODE_POLL = 0,
/* Never block (polling mode) */
77
GRTC_BLKMODE_BLK = 1,
/* Block until at least 1 byte can be read */
78
GRTC_BLKMODE_COMPLETE = 2
/* Block until all data requested has be read */
79
80
81
/* Argument of GRTC_IOC_SET_CONFIG and GRTC_IOC_GET_CONFIG
82
* Pointer to:
83
84
struct
grtc_ioc_config
85
int
psr_enable;
86
int
nrzm_enable;
87
int
pss_enable;
88
int
crc_calc;
/* Enable Software CRC calculation (only Frame mode) */
89
90
91
/* Argument of GRTC_IOC_GET_HW_STATUS:
92
* Pointer to a grtc_ioc_hw_status structure that will be filled
93
* in by driver.
94
95
struct
grtc_ioc_hw_status
96
unsigned
int
sir;
97
unsigned
int
far;
98
unsigned
int
clcw1;
99
unsigned
int
clcw2;
100
unsigned
int
phir;
101
unsigned
int
str;
102
103
104
struct
grtc_hdr
105
unsigned
short
flags_scid;
106
unsigned
short
vc_len;
107
unsigned
char
seqnum;
108
__attribute__
((packed));
109
110
/* Frame pool, all frames in pool have the same buffer length (frame mode only) */
111
struct
grtc_frame
112
struct
grtc_frame
*next;
/* Next frame in list */
113
unsigned
short
len;
/* Length of frame extracted */
114
unsigned
short
reserved;
/* Reserved */
115
struct
grtc_frame_pool
*pool;
/* The frame pool this frame belongs to */
116
117
/* The Frame content */
118
struct
grtc_hdr
hdr;
/* Primary Header */
119
unsigned
char
data[3];
/* Frame payload */
120
__attribute__
((packed));
121
122
/* GRTC_IOC_RECV argument, single linked list of received frames */
123
struct
grtc_list
124
struct
grtc_frame
*head;
/* First frame in list */
125
struct
grtc_frame
*tail;
/* Last frame in list */
126
int
cnt;
/* Number of frames in list */
127
128
129
struct
grtc_ioc_pools_setup
130
unsigned
int
pool_cnt;
/* Number of pools */
131
unsigned
int
pool_frame_len[1];
/* Array of 'pool_cnt' length: Frame length of frames in a pool
132
* Lengths must be sorted, starting with the smallest frame pool.
133
134
135
136
struct
grtc_ioc_assign_frm_pool
137
unsigned
int
frame_len;
/* The length of the pool to insert the frame into */
138
struct
grtc_frame
*frames;
/* Frames to assign to a pool */
139
140
141
enum
142
GRTC_MODE_RAW = 0,
143
GRTC_MODE_FRAME = 1
144
145
146
/* TC driver stats collected during receiving. The statistics is only available
147
* in FRAME mode. In RAW mode the user interprets the incoming frames and is
148
* therefore responsible for generating the staticstics.
149
150
struct
grtc_ioc_stats
151
unsigned
long
long
frames_recv;
/* Total number of non-erroneous frames received */
152
/* Errors related to incoming data */
153
unsigned
int
err;
/* total number of errors */
154
unsigned
int
err_hdr;
/* number of errors in Header */
155
unsigned
int
err_payload;
/* Number of errors in payload */
156
unsigned
int
err_ending;
/* Number of errors in end (Filler, end marker) */
157
unsigned
int
err_abandoned;
/* Number of abandoned frames, NOT IMPLEMENTED */
158
/* Errors related to the handling of incoming frames */
159
unsigned
int
dropped;
/* Number of dropped frames TC driver */
160
unsigned
int
dropped_no_buf;
/* Number of dropped frame caused by no buffers were available */
161
unsigned
int
dropped_too_long;
/* Number of dropped frames that was larger than any buffer available for driver */
162
163
164
/* Register GRTC driver at driver manager */
165
void
grtc_register_drv(
void
166
167
/* Register GRTC RMAP driver at driver manager */
168
void
grtc_rmap_register_drv (
void
169
170
#ifdef __cplusplus
171
172
#endif
173
174
#endif
/* __GRTC_H__ */
__attribute__
Definition:
xnandpsu_onfi.h:185
grtc_frame_pool
Definition:
grtc.c:236
grtc_frame
Definition:
grtc.h:111
grtc_hdr
Definition:
grtc.h:104
Definition:
grtc.h:136
grtc_ioc_buf_params
Definition:
grtc.h:69
grtc_ioc_config
Definition:
grtc.h:84
grtc_ioc_hw_status
Definition:
grtc.h:95
Definition:
grtc.h:129
grtc_ioc_stats
Definition:
grtc.h:150
grtc_list
Definition:
grtc.h:123
