RTEMS 6.1-rc4
Data Structures | Macros | Typedefs
grspw2-regs.h File Reference
This header file defines the GRSPW2 register block interface. More...
#include <stdint.h>
struct  grspw2_dma
 This structure defines the GRSPW2 DMA register block memory map. More...
struct  grspw2
 This structure defines the GRSPW2 register block memory map. More...
#define GRSPW2_DMACTRL_INTNUM_SHIFT   26
#define GRSPW2_DMACTRL_INTNUM_MASK   0xfc000000U
#define GRSPW2_DMACTRL_INTNUM_GET(_reg)
#define GRSPW2_DMACTRL_INTNUM_SET(_reg, _val)
#define GRSPW2_DMACTRL_INTNUM(_val)
#define GRSPW2_DMACTRL_RES_SHIFT   24
#define GRSPW2_DMACTRL_RES_MASK   0x3000000U
#define GRSPW2_DMACTRL_RES_GET(_reg)
#define GRSPW2_DMACTRL_RES_SET(_reg, _val)
#define GRSPW2_DMACTRL_RES(_val)
#define GRSPW2_DMACTRL_EP   0x800000U
#define GRSPW2_DMACTRL_TR   0x400000U
#define GRSPW2_DMACTRL_IE   0x200000U
#define GRSPW2_DMACTRL_IT   0x100000U
#define GRSPW2_DMACTRL_RP   0x80000U
#define GRSPW2_DMACTRL_TP   0x40000U
#define GRSPW2_DMACTRL_TL   0x20000U
#define GRSPW2_DMACTRL_LE   0x10000U
#define GRSPW2_DMACTRL_SP   0x8000U
#define GRSPW2_DMACTRL_SA   0x4000U
#define GRSPW2_DMACTRL_EN   0x2000U
#define GRSPW2_DMACTRL_NS   0x1000U
#define GRSPW2_DMACTRL_RD   0x800U
#define GRSPW2_DMACTRL_RX   0x400U
#define GRSPW2_DMACTRL_AT   0x200U
#define GRSPW2_DMACTRL_RA   0x100U
#define GRSPW2_DMACTRL_TA   0x80U
#define GRSPW2_DMACTRL_PR   0x40U
#define GRSPW2_DMACTRL_PS   0x20U
#define GRSPW2_DMACTRL_AI   0x10U
#define GRSPW2_DMACTRL_RI   0x8U
#define GRSPW2_DMACTRL_TI   0x4U
#define GRSPW2_DMACTRL_RE   0x2U
#define GRSPW2_DMACTRL_TE   0x1U
#define GRSPW2_DMAMAXLEN_RXMAXLEN_SHIFT   2
#define GRSPW2_DMAMAXLEN_RXMAXLEN_MASK   0x1fffffcU
#define GRSPW2_DMAMAXLEN_RXMAXLEN_GET(_reg)
#define GRSPW2_DMAMAXLEN_RXMAXLEN_SET(_reg, _val)
#define GRSPW2_DMAMAXLEN_RXMAXLEN(_val)
#define GRSPW2_DMAMAXLEN_RES_SHIFT   0
#define GRSPW2_DMAMAXLEN_RES_MASK   0x3U
#define GRSPW2_DMAMAXLEN_RES_GET(_reg)
#define GRSPW2_DMAMAXLEN_RES_SET(_reg, _val)
#define GRSPW2_DMAMAXLEN_RES(_val)
#define GRSPW2_DMATXDESC_DESCBASEADDR_SHIFT   0
#define GRSPW2_DMATXDESC_DESCBASEADDR_MASK   0xffffffffU
#define GRSPW2_DMATXDESC_DESCBASEADDR_GET(_reg)
#define GRSPW2_DMATXDESC_DESCBASEADDR_SET(_reg, _val)
#define GRSPW2_DMATXDESC_DESCBASEADDR(_val)
#define GRSPW2_DMATXDESC_DESCSEL_SHIFT   4
#define GRSPW2_DMATXDESC_DESCSEL_MASK   0xfffffff0U
#define GRSPW2_DMATXDESC_DESCSEL_GET(_reg)
#define GRSPW2_DMATXDESC_DESCSEL_SET(_reg, _val)
#define GRSPW2_DMATXDESC_DESCSEL(_val)
#define GRSPW2_DMARXDESC_DESCBASEADDR_SHIFT   10
#define GRSPW2_DMARXDESC_DESCBASEADDR_MASK   0xfffffc00U
#define GRSPW2_DMARXDESC_DESCBASEADDR_GET(_reg)
#define GRSPW2_DMARXDESC_DESCBASEADDR_SET(_reg, _val)
#define GRSPW2_DMARXDESC_DESCBASEADDR(_val)
#define GRSPW2_DMARXDESC_DESCSEL_SHIFT   3
#define GRSPW2_DMARXDESC_DESCSEL_MASK   0x3f8U
#define GRSPW2_DMARXDESC_DESCSEL_GET(_reg)
#define GRSPW2_DMARXDESC_DESCSEL_SET(_reg, _val)
#define GRSPW2_DMARXDESC_DESCSEL(_val)
#define GRSPW2_DMAADDR_MASK_SHIFT   8
#define GRSPW2_DMAADDR_MASK_MASK   0xff00U
#define GRSPW2_DMAADDR_MASK_GET(_reg)
#define GRSPW2_DMAADDR_MASK_SET(_reg, _val)
#define GRSPW2_DMAADDR_MASK(_val)
#define GRSPW2_DMAADDR_ADDR_SHIFT   0
#define GRSPW2_DMAADDR_ADDR_MASK   0xffU
#define GRSPW2_DMAADDR_ADDR_GET(_reg)
#define GRSPW2_DMAADDR_ADDR_SET(_reg, _val)
#define GRSPW2_DMAADDR_ADDR(_val)
#define GRSPW2_CTRL_RA   0x80000000U
#define GRSPW2_CTRL_RX   0x40000000U
#define GRSPW2_CTRL_RC   0x20000000U
#define GRSPW2_CTRL_NCH_SHIFT   27
#define GRSPW2_CTRL_NCH_MASK   0x18000000U
#define GRSPW2_CTRL_NCH_GET(_reg)
#define GRSPW2_CTRL_NCH_SET(_reg, _val)
#define GRSPW2_CTRL_NCH(_val)
#define GRSPW2_CTRL_PO   0x4000000U
#define GRSPW2_CTRL_CC   0x2000000U
#define GRSPW2_CTRL_ID   0x1000000U
#define GRSPW2_CTRL_R   0x800000U
#define GRSPW2_CTRL_LE   0x400000U
#define GRSPW2_CTRL_PS   0x200000U
#define GRSPW2_CTRL_NP   0x100000U
#define GRSPW2_CTRL_PNPA_SHIFT   18
#define GRSPW2_CTRL_PNPA_MASK   0xc0000U
#define GRSPW2_CTRL_PNPA_GET(_reg)
#define GRSPW2_CTRL_PNPA_SET(_reg, _val)
#define GRSPW2_CTRL_PNPA(_val)
#define GRSPW2_CTRL_RD   0x20000U
#define GRSPW2_CTRL_RE   0x10000U
#define GRSPW2_CTRL_PE   0x8000U
#define GRSPW2_CTRL_R   0x4000U
#define GRSPW2_CTRL_TL   0x2000U
#define GRSPW2_CTRL_TF   0x1000U
#define GRSPW2_CTRL_TR   0x800U
#define GRSPW2_CTRL_TT   0x400U
#define GRSPW2_CTRL_LI   0x200U
#define GRSPW2_CTRL_TQ   0x100U
#define GRSPW2_CTRL_R   0x80U
#define GRSPW2_CTRL_RS   0x40U
#define GRSPW2_CTRL_PM   0x20U
#define GRSPW2_CTRL_TI   0x10U
#define GRSPW2_CTRL_IE   0x8U
#define GRSPW2_CTRL_AS   0x4U
#define GRSPW2_CTRL_LS   0x2U
#define GRSPW2_CTRL_LD   0x1U
#define GRSPW2_STS_NRXD_SHIFT   26
#define GRSPW2_STS_NRXD_MASK   0xc000000U
#define GRSPW2_STS_NRXD_GET(_reg)
#define GRSPW2_STS_NRXD_SET(_reg, _val)
#define GRSPW2_STS_NRXD(_val)
#define GRSPW2_STS_NTXD   0x2000000U
#define GRSPW2_STS_LS_SHIFT   21
#define GRSPW2_STS_LS_MASK   0xe00000U
#define GRSPW2_STS_LS_GET(_reg)
#define GRSPW2_STS_LS_SET(_reg, _val)
#define GRSPW2_STS_LS(_val)
#define GRSPW2_STS_AP   0x200U
#define GRSPW2_STS_EE   0x100U
#define GRSPW2_STS_IA   0x80U
#define GRSPW2_STS_RES_SHIFT   5
#define GRSPW2_STS_RES_MASK   0x60U
#define GRSPW2_STS_RES_GET(_reg)
#define GRSPW2_STS_RES_SET(_reg, _val)
#define GRSPW2_STS_RES(_val)
#define GRSPW2_STS_PE   0x10U
#define GRSPW2_STS_DE   0x8U
#define GRSPW2_STS_ER   0x4U
#define GRSPW2_STS_CE   0x2U
#define GRSPW2_STS_TO   0x1U
#define GRSPW2_DEFADDR_DEFMASK_SHIFT   8
#define GRSPW2_DEFADDR_DEFMASK_MASK   0xff00U
#define GRSPW2_DEFADDR_DEFMASK_GET(_reg)
#define GRSPW2_DEFADDR_DEFMASK_SET(_reg, _val)
#define GRSPW2_DEFADDR_DEFMASK(_val)
#define GRSPW2_DEFADDR_DEFADDR_SHIFT   0
#define GRSPW2_DEFADDR_DEFADDR_MASK   0xffU
#define GRSPW2_DEFADDR_DEFADDR_GET(_reg)
#define GRSPW2_DEFADDR_DEFADDR_SET(_reg, _val)
#define GRSPW2_DEFADDR_DEFADDR(_val)
#define GRSPW2_CLKDIV_CLKDIVSTART_SHIFT   8
#define GRSPW2_CLKDIV_CLKDIVSTART_MASK   0xff00U
#define GRSPW2_CLKDIV_CLKDIVSTART_GET(_reg)
#define GRSPW2_CLKDIV_CLKDIVSTART_SET(_reg, _val)
#define GRSPW2_CLKDIV_CLKDIVSTART(_val)
#define GRSPW2_CLKDIV_CLKDIVRUN_SHIFT   0
#define GRSPW2_CLKDIV_CLKDIVRUN_MASK   0xffU
#define GRSPW2_CLKDIV_CLKDIVRUN_GET(_reg)
#define GRSPW2_CLKDIV_CLKDIVRUN_SET(_reg, _val)
#define GRSPW2_CLKDIV_CLKDIVRUN(_val)
#define GRSPW2_DKEY_DESTKEY_SHIFT   0
#define GRSPW2_DKEY_DESTKEY_MASK   0xffU
#define GRSPW2_DKEY_DESTKEY_GET(_reg)
#define GRSPW2_DKEY_DESTKEY_SET(_reg, _val)
#define GRSPW2_DKEY_DESTKEY(_val)
#define GRSPW2_TC_TCTRL_SHIFT   6
#define GRSPW2_TC_TCTRL_MASK   0xc0U
#define GRSPW2_TC_TCTRL_GET(_reg)
#define GRSPW2_TC_TCTRL_SET(_reg, _val)
#define GRSPW2_TC_TCTRL(_val)
#define GRSPW2_TC_TIMECNT_SHIFT   0
#define GRSPW2_TC_TIMECNT_MASK   0x3fU
#define GRSPW2_TC_TIMECNT_GET(_reg)
#define GRSPW2_TC_TIMECNT_SET(_reg, _val)
#define GRSPW2_TC_TIMECNT(_val)
#define GRSPW2_INTCTRL_INTNUM_SHIFT   26
#define GRSPW2_INTCTRL_INTNUM_MASK   0xfc000000U
#define GRSPW2_INTCTRL_INTNUM_GET(_reg)
#define GRSPW2_INTCTRL_INTNUM_SET(_reg, _val)
#define GRSPW2_INTCTRL_INTNUM(_val)
#define GRSPW2_INTCTRL_RS   0x2000000U
#define GRSPW2_INTCTRL_EE   0x1000000U
#define GRSPW2_INTCTRL_IA   0x800000U
#define GRSPW2_INTCTRL_RES   0x2U
#define GRSPW2_INTCTRL_TQ_SHIFT   21
#define GRSPW2_INTCTRL_TQ_MASK   0x600000U
#define GRSPW2_INTCTRL_TQ_GET(_reg)
#define GRSPW2_INTCTRL_TQ_SET(_reg, _val)
#define GRSPW2_INTCTRL_TQ(_val)
#define GRSPW2_INTCTRL_AQ   0x100000U
#define GRSPW2_INTCTRL_IQ   0x80000U
#define GRSPW2_INTCTRL_RES   0x40000U
#define GRSPW2_INTCTRL_AA_SHIFT   16
#define GRSPW2_INTCTRL_AA_MASK   0x30000U
#define GRSPW2_INTCTRL_AA_GET(_reg)
#define GRSPW2_INTCTRL_AA_SET(_reg, _val)
#define GRSPW2_INTCTRL_AA(_val)
#define GRSPW2_INTCTRL_AT   0x8000U
#define GRSPW2_INTCTRL_IT   0x4000U
#define GRSPW2_INTCTRL_RES   0x2000U
#define GRSPW2_INTCTRL_ID_SHIFT   8
#define GRSPW2_INTCTRL_ID_MASK   0x1f00U
#define GRSPW2_INTCTRL_ID_GET(_reg)
#define GRSPW2_INTCTRL_ID_SET(_reg, _val)
#define GRSPW2_INTCTRL_ID(_val)
#define GRSPW2_INTCTRL_II   0x80U
#define GRSPW2_INTCTRL_TXINT   0x40U
#define GRSPW2_INTRX_RXIRQ_SHIFT   0
#define GRSPW2_INTRX_RXIRQ_MASK   0xffffffffU
#define GRSPW2_INTRX_RXIRQ_GET(_reg)
#define GRSPW2_INTRX_RXIRQ_SET(_reg, _val)
#define GRSPW2_INTRX_RXIRQ(_val)
#define GRSPW2_INTTO_INTTO_SHIFT   0
#define GRSPW2_INTTO_INTTO_MASK   0xffffffffU
#define GRSPW2_INTTO_INTTO_GET(_reg)
#define GRSPW2_INTTO_INTTO_SET(_reg, _val)
#define GRSPW2_INTTO_INTTO(_val)
#define GRSPW2_INTTOEXT_INTTOEXT_SHIFT   0
#define GRSPW2_INTTOEXT_INTTOEXT_MASK   0xffffffffU
#define GRSPW2_INTTOEXT_INTTOEXT_GET(_reg)
#define GRSPW2_INTTOEXT_INTTOEXT_SET(_reg, _val)
#define GRSPW2_INTTOEXT_INTTOEXT(_val)
#define GRSPW2_TICKMASK_MASK_SHIFT   0
#define GRSPW2_TICKMASK_MASK_MASK   0xffffffffU
#define GRSPW2_TICKMASK_MASK_GET(_reg)
#define GRSPW2_TICKMASK_MASK_SET(_reg, _val)
#define GRSPW2_TICKMASK_MASK(_val)
#define GRSPW2_AUTOACK_TICKMASKEXT_AAMASK_SHIFT   0
#define GRSPW2_AUTOACK_TICKMASKEXT_AAMASK_MASK   0xffffffffU
#define GRSPW2_AUTOACK_TICKMASKEXT_AAMASK_GET(_reg)
#define GRSPW2_AUTOACK_TICKMASKEXT_AAMASK_SET(_reg, _val)
#define GRSPW2_AUTOACK_TICKMASKEXT_AAMASK(_val)
#define GRSPW2_INTCFG_INTNUM3_SHIFT   26
#define GRSPW2_INTCFG_INTNUM3_MASK   0xfc000000U
#define GRSPW2_INTCFG_INTNUM3_GET(_reg)
#define GRSPW2_INTCFG_INTNUM3_SET(_reg, _val)
#define GRSPW2_INTCFG_INTNUM3(_val)
#define GRSPW2_INTCFG_INTNUM2_SHIFT   20
#define GRSPW2_INTCFG_INTNUM2_MASK   0x3f00000U
#define GRSPW2_INTCFG_INTNUM2_GET(_reg)
#define GRSPW2_INTCFG_INTNUM2_SET(_reg, _val)
#define GRSPW2_INTCFG_INTNUM2(_val)
#define GRSPW2_INTCFG_INTNUM1_SHIFT   14
#define GRSPW2_INTCFG_INTNUM1_MASK   0xfc000U
#define GRSPW2_INTCFG_INTNUM1_GET(_reg)
#define GRSPW2_INTCFG_INTNUM1_SET(_reg, _val)
#define GRSPW2_INTCFG_INTNUM1(_val)
#define GRSPW2_INTCFG_INTNUM0_SHIFT   8
#define GRSPW2_INTCFG_INTNUM0_MASK   0x3f00U
#define GRSPW2_INTCFG_INTNUM0_GET(_reg)
#define GRSPW2_INTCFG_INTNUM0_SET(_reg, _val)
#define GRSPW2_INTCFG_INTNUM0(_val)
#define GRSPW2_INTCFG_NUMINT_SHIFT   4
#define GRSPW2_INTCFG_NUMINT_MASK   0xf0U
#define GRSPW2_INTCFG_NUMINT_GET(_reg)
#define GRSPW2_INTCFG_NUMINT_SET(_reg, _val)
#define GRSPW2_INTCFG_NUMINT(_val)
#define GRSPW2_INTCFG_PR   0x8U
#define GRSPW2_INTCFG_IR   0x4U
#define GRSPW2_INTCFG_IT   0x2U
#define GRSPW2_INTCFG_EE   0x1U
#define GRSPW2_ISR_ISR_SHIFT   0
#define GRSPW2_ISR_ISR_MASK   0xffffffffU
#define GRSPW2_ISR_ISR_GET(_reg)
#define GRSPW2_ISR_ISR_SET(_reg, _val)
#define GRSPW2_ISR_ISR(_val)
#define GRSPW2_ISREXT_ISR_SHIFT   0
#define GRSPW2_ISREXT_ISR_MASK   0xffffffffU
#define GRSPW2_ISREXT_ISR_GET(_reg)
#define GRSPW2_ISREXT_ISR_SET(_reg, _val)
#define GRSPW2_ISREXT_ISR(_val)
#define GRSPW2_PRESCALER_R   0x80000000U
#define GRSPW2_PRESCALER_RL_SHIFT   0
#define GRSPW2_PRESCALER_RL_MASK   0x7fffffffU
#define GRSPW2_PRESCALER_RL_GET(_reg)
#define GRSPW2_PRESCALER_RL_SET(_reg, _val)
#define GRSPW2_PRESCALER_RL(_val)
#define GRSPW2_ISRTIMER_EN   0x80000000U
#define GRSPW2_ISRTIMER_RL_SHIFT   0
#define GRSPW2_ISRTIMER_RL_MASK   0x7fffffffU
#define GRSPW2_ISRTIMER_RL_GET(_reg)
#define GRSPW2_ISRTIMER_RL_SET(_reg, _val)
#define GRSPW2_ISRTIMER_RL(_val)
#define GRSPW2_IATIMER_EN   0x80000000U
#define GRSPW2_IATIMER_RL_SHIFT   0
#define GRSPW2_IATIMER_RL_MASK   0x7fffffffU
#define GRSPW2_IATIMER_RL_GET(_reg)
#define GRSPW2_IATIMER_RL_SET(_reg, _val)
#define GRSPW2_IATIMER_RL(_val)
#define GRSPW2_ICTIMER_EN   0x80000000U
#define GRSPW2_ICTIMER_RL_SHIFT   0
#define GRSPW2_ICTIMER_RL_MASK   0x7fffffffU
#define GRSPW2_ICTIMER_RL_GET(_reg)
#define GRSPW2_ICTIMER_RL_SET(_reg, _val)
#define GRSPW2_ICTIMER_RL(_val)
#define GRSPW2_PNPVEND_VEND_SHIFT   16
#define GRSPW2_PNPVEND_VEND_MASK   0xffff0000U
#define GRSPW2_PNPVEND_VEND_GET(_reg)
#define GRSPW2_PNPVEND_VEND_SET(_reg, _val)
#define GRSPW2_PNPVEND_VEND(_val)
#define GRSPW2_PNPVEND_PROD_SHIFT   0
#define GRSPW2_PNPVEND_PROD_MASK   0xffffU
#define GRSPW2_PNPVEND_PROD_GET(_reg)
#define GRSPW2_PNPVEND_PROD_SET(_reg, _val)
#define GRSPW2_PNPVEND_PROD(_val)
#define GRSPW2_PNPOA0_RA_SHIFT   0
#define GRSPW2_PNPOA0_RA_MASK   0xffffffffU
#define GRSPW2_PNPOA0_RA_GET(_reg)
#define GRSPW2_PNPOA0_RA_SET(_reg, _val)
#define GRSPW2_PNPOA0_RA(_val)
#define GRSPW2_PNPOA1_RA_SHIFT   0
#define GRSPW2_PNPOA1_RA_MASK   0xffffffffU
#define GRSPW2_PNPOA1_RA_GET(_reg)
#define GRSPW2_PNPOA1_RA_SET(_reg, _val)
#define GRSPW2_PNPOA1_RA(_val)
#define GRSPW2_PNPOA2_RA_SHIFT   0
#define GRSPW2_PNPOA2_RA_MASK   0xffffffffU
#define GRSPW2_PNPOA2_RA_GET(_reg)
#define GRSPW2_PNPOA2_RA_SET(_reg, _val)
#define GRSPW2_PNPOA2_RA(_val)
#define GRSPW2_PNPDEVID_DID_SHIFT   0
#define GRSPW2_PNPDEVID_DID_MASK   0xffffffffU
#define GRSPW2_PNPDEVID_DID_GET(_reg)
#define GRSPW2_PNPDEVID_DID_SET(_reg, _val)
#define GRSPW2_PNPDEVID_DID(_val)
#define GRSPW2_PNPUVEND_VEND_SHIFT   16
#define GRSPW2_PNPUVEND_VEND_MASK   0xffff0000U
#define GRSPW2_PNPUVEND_VEND_GET(_reg)
#define GRSPW2_PNPUVEND_VEND_SET(_reg, _val)
#define GRSPW2_PNPUVEND_VEND(_val)
#define GRSPW2_PNPUVEND_PROD_SHIFT   0
#define GRSPW2_PNPUVEND_PROD_MASK   0xffffU
#define GRSPW2_PNPUVEND_PROD_GET(_reg)
#define GRSPW2_PNPUVEND_PROD_SET(_reg, _val)
#define GRSPW2_PNPUVEND_PROD(_val)
#define GRSPW2_PNPUSN_USN_SHIFT   0
#define GRSPW2_PNPUSN_USN_MASK   0xffffffffU
#define GRSPW2_PNPUSN_USN_GET(_reg)
#define GRSPW2_PNPUSN_USN_SET(_reg, _val)
#define GRSPW2_PNPUSN_USN(_val)
typedef struct grspw2_dma grspw2_dma
typedef struct grspw2 grspw2
