RTEMS 6.1-rc4
The Time Test 27 (TM27) support is used to measure the timing of the interrupt processing. More...
Modules | |
Time Test 27 Default | |
Stuff for Time Test 27. | |
The TMS27 support should provide two software generated interrupt requests, one low priority request raised by Cause_tm27_intr() and one higher priority request raised by Lower_tm27_intr(). Both requests should be cleared by Clear_tm27_intr(). A handler provided by the test should be installed through Install_tm27_vector(). This function should initialize the system so that the software generated interrupt requests can be raised and cleared.
If the raise functions Cause_tm27_intr() and Lower_tm27_intr() do not trigger the interrupt immediately, then the TM27 support shall define MUST_WAIT_FOR_INTERRUPT to one, otherwise MUST_WAIT_FOR_INTERRUPT shall be defined to zero.
The TM27 support may define TM27_INTERRUPT_VECTOR_DEFAULT to indicate the interrupt vector of the interrupt request raised by Cause_tm27_intr().
The TM27 support may define TM27_INTERRUPT_VECTOR_ALTERNATIVE to provide an alternative software generated interrupt request which is raised by _TM27_Raise_alternative() and cleared by _TM27_Clear_alternative(). Both functions shall return an RTEMS status code. This interrupt vector may be used to test the interrupt controller support on targets which do not provide generic software generated interrupts.
