RTEMS 6.1-rc4
Modules | Files | Data Structures | Typedefs
GR740 Temperatur Sensor Controller
This group contains the GR740 Temperatur Sensor Controller interfaces. More...
 Control register (CTRL)
 This group contains register bit definitions.
 Status register (STATUS)
 Threshold register (THRES)
file  gr740-thsens-regs.h
 This header file defines the GR740 Temperatur Sensor Controller register block interface.
struct  gr740_thsens
 This structure defines the GR740 Temperatur Sensor Controller register block memory map. More...
typedef struct gr740_thsens gr740_thsens
