RTEMS 6.1-rc4
grcan_internal.h
2
3/*
4 * GRCAN driver
5 *
6 * COPYRIGHT (c) 2007-2019.
7 * Cobham Gaisler AB.
8 *
9 * Redistribution and use in source and binary forms, with or without
10 * modification, are permitted provided that the following conditions
11 * are met:
12 * 1. Redistributions of source code must retain the above copyright
13 * notice, this list of conditions and the following disclaimer.
14 * 2. Redistributions in binary form must reproduce the above copyright
15 * notice, this list of conditions and the following disclaimer in the
16 * documentation and/or other materials provided with the distribution.
17 *
18 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
19 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
20 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
21 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
22 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
23 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
24 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
25 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
26 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
27 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
28 * POSSIBILITY OF SUCH DAMAGE.
29 */
30
31#ifndef GRCAN_DEFAULT_BAUD
32 /* default to 500kbits/s */
33 #define GRCAN_DEFAULT_BAUD 500000
34#endif
35
36#ifndef GRCAN_SAMPLING_POINT
37 #define GRCAN_SAMPLING_POINT 80
38#endif
39
40#define WRAP_AROUND_TX_MSGS 1
41#define WRAP_AROUND_RX_MSGS 2
42#define GRCAN_MSG_SIZE sizeof(struct grcan_msg)
43
44struct grcan_msg {
45 unsigned int head[2];
46 unsigned char data[8];
47};
48
50 struct grcan_timing timing;
51 struct grcanfd_timing timing_fd;
52 struct grcan_selection selection;
53 int abort;
54 int silent;
55};
56
57struct grcan_priv {
58 struct drvmgr_dev *dev; /* Driver manager device */
59 char devName[52]; /* Device Name */
60 unsigned int baseaddr, ram_base;
61 struct grcan_regs *regs;
62 int irq;
63 int minor;
64 int open;
65 int started;
66 unsigned int channel;
67 int flushing;
68 unsigned int corefreq_hz;
69 int fd_capable;
70
71 /* Circular DMA buffers */
72 void *_rx, *_rx_hw;
73 void *_tx, *_tx_hw;
74 void *txbuf_adr;
75 void *rxbuf_adr;
76 struct grcan_msg *rx;
77 struct grcan_msg *tx;
78 unsigned int rxbuf_size; /* requested RX buf size in bytes */
79 unsigned int txbuf_size; /* requested TX buf size in bytes */
80
81 int txblock, rxblock;
82 int txcomplete, rxcomplete;
83
84 struct grcan_filter sfilter;
85 struct grcan_filter afilter;
86 int config_changed; /* 0=no changes, 1=changes ==> a Core reset is needed */
87 struct grcan_config config;
88 struct grcan_stats stats;
89
90 rtems_id rx_sem, tx_sem, txempty_sem, dev_sem;
91 SPIN_DECLARE(devlock);
92};
93
94#ifdef GRCAN_REG_BYPASS_CACHE
95#define READ_REG(address) grlib_read_uncached32((unsigned int)(address))
96#else
97#define READ_REG(address) (*(volatile unsigned int *)(address))
98#endif
99
100#ifdef GRCAN_DMA_BYPASS_CACHE
101#define READ_DMA_DOUBLE(address) grlib_read_uncached64((uint64_t *)(address))
102#define READ_DMA_WORD(address) grlib_read_uncached32((unsigned int)(address))
103#define READ_DMA_BYTE(address) grlib_read_uncached8((unsigned int)(address))
104#else
105#define READ_DMA_DOUBLE(address) (*(volatile uint64_t *)(address))
106#define READ_DMA_WORD(address) (*(volatile unsigned int *)(address))
107#define READ_DMA_BYTE(address) (*(volatile unsigned char *)(address))
108#endif
109
110extern int state2err[4];
111extern struct grlib_canbtrs_ranges grcan_btrs_ranges;
112extern struct grlib_canbtrs_ranges grcanfd_nom_btrs_ranges;
113extern struct grlib_canbtrs_ranges grcanfd_fd_btrs_ranges;
114
115int grcan_wait_rxdata(struct grcan_priv *pDev, int min);
116int grcan_wait_txspace(struct grcan_priv *pDev, int min);
117
118static inline unsigned int grcan_hw_rxavail(
119 unsigned int rp,
120 unsigned int wp,
121 unsigned int size)
122{
123 if (rp == wp) {
124 /* read pointer and write pointer is equal only
125 * when RX buffer is empty.
126 */
127 return 0;
128 }
129
130 if (wp > rp) {
131 return (wp - rp) / GRCAN_MSG_SIZE;
132 } else {
133 return (size - (rp - wp)) / GRCAN_MSG_SIZE;
134 }
135}
136
137static inline unsigned int grcan_hw_txspace(
138 unsigned int rp,
139 unsigned int wp,
140 unsigned int size)
141{
142 unsigned int left;
143
144 if (rp == wp) {
145 /* read pointer and write pointer is equal only
146 * when TX buffer is empty.
147 */
148 return size / GRCAN_MSG_SIZE - WRAP_AROUND_TX_MSGS;
149 }
150
151 /* size - 4 - abs(read-write) */
152 if (wp > rp) {
153 left = size - (wp - rp);
154 } else {
155 left = rp - wp;
156 }
157
158 return left / GRCAN_MSG_SIZE - WRAP_AROUND_TX_MSGS;
159}
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition: types.h:94
int open(const char *path, int oflag,...)
Definition: open.c:181
Definition: deflate.c:114
Definition: drvmgr.h:297
Definition: grcan_internal.h:49
Definition: grcan.h:131
Definition: grcan_internal.h:44
Definition: grcan_internal.h:57
Definition: grcan.h:54
Definition: grcan.h:125
Definition: grcan.h:98
Definition: grcan.h:109
Definition: grcan.h:117
Definition: canbtrs.h:52
