RTEMS 6.1-rc4
Data Structures | Macros | Typedefs
gptimer-regs.h File Reference
This header file defines the GPTIMER register block interface. More...
#include <stdint.h>
struct  gptimer_timer
 This structure defines the GPTIMER TIMER register block memory map. More...
struct  gptimer
 This structure defines the GPTIMER register block memory map. More...
#define GPTIMER_TCNTVAL_TCVAL_SHIFT   0
#define GPTIMER_TCNTVAL_TCVAL_MASK   0xffffffffU
#define GPTIMER_TCNTVAL_TCVAL_GET(_reg)
#define GPTIMER_TCNTVAL_TCVAL_SET(_reg, _val)
#define GPTIMER_TCNTVAL_TCVAL(_val)
#define GPTIMER_TRLDVAL_TRLDVAL_SHIFT   0
#define GPTIMER_TRLDVAL_TRLDVAL_MASK   0xffffffffU
#define GPTIMER_TRLDVAL_TRLDVAL_GET(_reg)
#define GPTIMER_TRLDVAL_TRLDVAL_SET(_reg, _val)
#define GPTIMER_TRLDVAL_TRLDVAL(_val)
#define GPTIMER_TCTRL_WS   0x100U
#define GPTIMER_TCTRL_WN   0x80U
#define GPTIMER_TCTRL_DH   0x40U
#define GPTIMER_TCTRL_CH   0x20U
#define GPTIMER_TCTRL_IP   0x10U
#define GPTIMER_TCTRL_IE   0x8U
#define GPTIMER_TCTRL_LD   0x4U
#define GPTIMER_TCTRL_RS   0x2U
#define GPTIMER_TCTRL_EN   0x1U
#define GPTIMER_TLATCH_LTCV_SHIFT   0
#define GPTIMER_TLATCH_LTCV_MASK   0xffffffffU
#define GPTIMER_TLATCH_LTCV_GET(_reg)
#define GPTIMER_TLATCH_LTCV_SET(_reg, _val)
#define GPTIMER_TLATCH_LTCV(_val)
#define GPTIMER_SCALER_SCALER_SHIFT   0
#define GPTIMER_SCALER_SCALER_MASK   0xffffU
#define GPTIMER_SCALER_SCALER_GET(_reg)
#define GPTIMER_SCALER_SCALER_SET(_reg, _val)
#define GPTIMER_SCALER_SCALER(_val)
#define GPTIMER_SRELOAD_SRELOAD_SHIFT   0
#define GPTIMER_SRELOAD_SRELOAD_MASK   0xffffU
#define GPTIMER_SRELOAD_SRELOAD_GET(_reg)
#define GPTIMER_SRELOAD_SRELOAD_SET(_reg, _val)
#define GPTIMER_SRELOAD_SRELOAD(_val)
#define GPTIMER_CONFIG_EV   0x2000U
#define GPTIMER_CONFIG_ES   0x1000U
#define GPTIMER_CONFIG_EL   0x800U
#define GPTIMER_CONFIG_EE   0x400U
#define GPTIMER_CONFIG_DF   0x200U
#define GPTIMER_CONFIG_SI   0x100U
#define GPTIMER_CONFIG_IRQ_SHIFT   3
#define GPTIMER_CONFIG_IRQ_MASK   0xf8U
#define GPTIMER_CONFIG_IRQ_GET(_reg)
#define GPTIMER_CONFIG_IRQ_SET(_reg, _val)
#define GPTIMER_CONFIG_IRQ(_val)
#define GPTIMER_CONFIG_TIMERS_SHIFT   0
#define GPTIMER_CONFIG_TIMERS_MASK   0x7U
#define GPTIMER_CONFIG_TIMERS_GET(_reg)
#define GPTIMER_CONFIG_TIMERS_SET(_reg, _val)
#define GPTIMER_CONFIG_TIMERS(_val)
#define GPTIMER_LATCHCFG_LATCHSEL_SHIFT   0
#define GPTIMER_LATCHCFG_LATCHSEL_MASK   0xffffffffU
#define GPTIMER_LATCHCFG_LATCHSEL_GET(_reg)
#define GPTIMER_LATCHCFG_LATCHSEL_SET(_reg, _val)
#define GPTIMER_LATCHCFG_LATCHSEL(_val)
typedef struct gptimer_timer gptimer_timer
typedef struct gptimer gptimer
