RTEMS 6.1-rc4
Macros | Enumerations | Functions
ftpfs.h File Reference
File Transfer Protocol file system (FTP client). More...
#include <sys/time.h>
#include <sys/ioctl.h>
#include <rtems/libio.h>
#define RTEMS_FTPFS_CTRL_PORT   21
 Well-known port number for FTP control connection.
#define RTEMS_FTPFS_MOUNT_POINT_DEFAULT   "/FTP"
 Default mount point for FTP file system.
enum  rtems_ftpfs_ioctl_numbers { RTEMS_FTPFS_IOCTL_GET_VERBOSE = _IOR( 'd', 1, bool *) , RTEMS_FTPFS_IOCTL_SET_VERBOSE = _IOW( 'd', 1, bool *) , RTEMS_FTPFS_IOCTL_GET_TIMEOUT = _IOR( 'd', 2, struct timeval *) , RTEMS_FTPFS_IOCTL_SET_TIMEOUT = _IOW( 'd', 2, struct timeval *) }
 FTP file system IO control requests.
rtems_status_code rtems_ftpfs_get_verbose (const char *mount_point, bool *verbose)
 Returns in verbose if the verbose mode is enabled or disabled for the file system at mount_point.
rtems_status_code rtems_ftpfs_set_verbose (const char *mount_point, bool verbose)
 Enables or disables the verbose mode if verbose is true or false respectively for the file system at mount_point.
rtems_status_code rtems_ftpfs_get_timeout (const char *mount_point, struct timeval *timeout)
 Returns the current timeout value in timeout for the file system at mount_point.
rtems_status_code rtems_ftpfs_set_timeout (const char *mount_point, const struct timeval *timeout)
 Sets the timeout value to timeout for the file system at mount_point.
int rtems_ftpfs_initialize (rtems_filesystem_mount_table_entry_t *mt_entry, const void *data)
 Do not call directly, use mount().
